11-08-2017 04:29 AM - edited 03-17-2019 11:33 AM
I know this has been discussed before but i can't see that any of the previous answers my issue.
We have IMP 11.5 and CUCM 11.5. I just installed the IMP, single node.
Alle the services starts but Cisco Presence Engine[STARTING]. It hangs there. I have tried to restart the service and the whole server without any luck.
admin:show tech network hosts
this produces the same out put on CUCM as on IMP, therefore i assume that host file is not the problem.
Running the "trouble shooter" in GUI returnes no error messages besides the Presence engine.
Where do i go from here?
"Utils service restart Cisco Presence Engine" makes it go like this forever:
/T
Solved! Go to Solution.
11-08-2017 08:10 AM
11-08-2017 04:50 AM
11-08-2017 04:57 AM - edited 11-08-2017 04:58 AM
Hi Slavik
I've just installed it, so everything would be new :)
The troubleshooter only has one warning:
Restarting it via CLI or GUI gives same out put. Rebooting the whole server does not help either.
/T
11-08-2017 05:12 AM
Let's start with verifying few things:
11-08-2017 05:19 AM
Hi Slavik
I agree, lets get the basics confimed.
1. Yes they are on the same subnet, aka no firewall between CUCM and IMP.
2. Neither CUCM nor IMP is configured with DNS.
3. Yes, its there in the Presence Redundancy Group.
BTW: I am able to sync users from CUCM to IMP.
/T
11-08-2017 05:22 AM
11-08-2017 05:52 AM
Hi Slavik
You might be right but i can't stop the engine, neither though GUI nor CLI. The other services : Cisco SIP, Proxy, Cisco XCP Router, Cisco Sync Agent and Cisco Client Profile Agent stops as expected.
There were a Domain in the "system domain" section, so i added a domain in the "admin section" but it didnt do anything so i'm rebooting the server now.
/T
11-08-2017 05:56 AM
11-08-2017 07:31 AM - edited 11-08-2017 07:36 AM
Hi Slavik
I have this error message:
The IM Address Scheme is currently not set to Directory URI and as a result the domains listed below are not in use. To change this setting, please go to the following page, AdvancedPresence Settings.
But since i'm not able to stop the Precense Enginge i'm not able to change it.
/T
11-08-2017 08:10 AM
11-08-2017 09:02 AM
Since CUCM is not using DNS then the install guide says i shouldnt be using DNS on the IMP either.
But i'm thinking a fresh start, a reinstall, would be the way to go.
/T
11-08-2017 09:44 AM
11-08-2017 09:55 AM
Here it is:
--snip--
DNS requirements
If you are using DNS in your deployment, note the following requirements:
Mixed-mode DNS deployments not supported—Cisco does not support mixed-mode deployments. Both Cisco Unified Communications Manager (Unified Communications Manager) and IM and Presence must either use or not use DNS.
--snip--
And Cisco recommends NOT using DNS in CUCM, therefore we have not used DNS on the CUCM.
/T
11-08-2017 10:47 AM
11-09-2017 04:27 AM
Hi Slavik
A reinstall did it. I have no idea why. I noticed that the first time you log in through CLI it gives a warning that you might have to restart the "service manager" just to get the services up and running and this is a known bug...
The service was restarted several times in fact and it took "forever" to get every service back up running. 30 minutes or more.
Thanks for your assistance, Slavik
