Cisco SBC - adjancency sip: under remote-address/signalling peer is DNS instead of static IP possible?
Netmart
Level 3
Level 3
Cisco SBC [ASR 1006]
I was wondering, whether it is possible to use DNS entry instead of static IPs under remote-address and signaling-peer. We have one partner using DNS instead of IP since the peer IP is frequently changing.
Please advise.
Thanks.
Example:
adjacency sip TEST
nat force-off
signaling-address ipv4 150.100.0.1
statistics method summary
signaling-port 5060
remote-address ipv4 40.0.0.1 255.255.255.255
signaling-peer 40.0.0.1
ping-enable
realm outside
attach
Chris Deren
I would think so, type in the commend, i.e. "remote-address ?" to see if you get dns option instead of ipv4.
genius!
Please remember to rate useful posts, by clicking on the stars below.
Thank you for your intellectual input.
Basically, I wanted to know whether DNS-Based routing is possible - and the answer is probably no.
Hence, are their alternatives or workarounds to apply when it is required to route traffic to DNS-based destinations rather than to IPs?
