12-23-2016 03:27 AM - edited 03-17-2019 09:01 AM
Hi all,
we are going to integrate a Cisco Call Manager 9.1.2 vers with a 3rd party SBC.
The requirement are as follow:
- Both audio and video call should be available
- Need to proxy both audio and video on a single IP address
- Need to allow Hold and Resum and Call Transfer
Involved hosts:
172.19.222.84 / 172.19.222.95 CUCM Subscriber
172.19.222.95 Cisco IOS MTP resources
172.25.248.82 SBC
172.25.248.83 SBC Media IP
We have configured a SIP trunk and associated a SIP Profile with the following settings:
SIP Profile:
- Require SDP INactive Exchange... not checked
- RFC 2543 Hold not checked
- Early Offer supporto for voice and video calls (insert MTP if needed) checked
- Send send-receive SDP in mid-call INVITE not checked
ON the MRGL list associated to the trunk we have included only a transcoder type of CISCO IOS Enhanced media Termination Point configured on a 2911 ISR running 15.3.3M5 ios version. It is configured in codec-passthrough.
Transcoder on CUCM is in trusted relay Point mode and this setting is also set as enabled on the trunk.
We have some problem with HOLD and RESUME and it would be fine to have early offer on re-invite for both HOLD and RESUME steps.
Is there a way to set attribute=sendonly and Connect IP = 0.0.0.0 on HOLD reINVITEs?
Do we need to perform SIP Normalization to obtain this? Is there any pre-configured script?
We did some test using both a Jabber or an IP-PHone 7941 running SCCP.41.9-3-1 SR4-1S and we observe this behavior.
CALL SETUP
Call setup from CUCM use early offer (SDP included in the INVITE) but after the ACK on the other party 200OK, CUCM sends another early offer INVITE including only one codec (g711 alaw).
EFFECT: call is up with audio on both party
1st Invite from CUCM:
Internet Protocol Version 4, Src: 172.19.222.85, Dst: 172.25.248.82
User Datagram Protocol, Src Port: 5060, Dst Port: 5080
Session Initiation Protocol (INVITE)
Request-Line: INVITE sip:8910@172.25.248.82:5080 SIP/2.0
Message Header
Via: SIP/2.0/UDP 172.19.222.85:5060;branch=z9hG4bK65c5c217e419d
From: <sip:4771@172.19.222.85>;tag=16819417~305cfde1-0d58-4b14-a9ef-7b3502d970ea-39612243
SIP from address: sip:4771@172.19.222.85
SIP from tag: 16819417~305cfde1-0d58-4b14-a9ef-7b3502d970ea-39612243
To: <sip:8910@172.25.248.82>
SIP to address: sip:8910@172.25.248.82
Date: Fri, 23 Dec 2016 10:37:45 GMT
Call-ID: d5bb6800-85c1fe79-65b74-55de13ac@172.19.222.85
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM9.1
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Cisco-Guid: 3585828864-0000065536-0000000225-1440617388
Session-Expires: 1800
P-Asserted-Identity: <sip:4771@172.19.222.85>
SIP PAI Address: sip:4771@172.19.222.85
Remote-Party-ID: <sip:4771@172.19.222.85>;party=calling;screen=yes;privacy=off
Contact: <sip:4771@172.19.222.85:5060>
Contact URI: sip:4771@172.19.222.85:5060
Max-Forwards: 70
Content-Type: application/sdp
Content-Length: 315
Message Body
Session Description Protocol
Session Description Protocol Version (v): 0
Owner/Creator, Session Id (o): CiscoSystemsCCM-SIP 16819417 1 IN IP4 172.19.222.85
Session Name (s): SIP Call
Connection Information (c): IN IP4 172.19.222.95
Bandwidth Information (b): TIAS:64000
Bandwidth Information (b): AS:64
Time Description, active time (t): 0 0
Media Description, name and address (m): audio 18620 RTP/AVP 8 0 18 101
Media Attribute (a): rtpmap:8 PCMA/8000
Media Attribute (a): ptime:20
Media Attribute (a): rtpmap:0 PCMU/8000
Media Attribute (a): rtpmap:18 G729/8000
Media Attribute (a): rtpmap:101 telephone-event/8000
Media Attribute (a): fmtp:101 0-15
2nd Invite from CUCM
Request-Line: INVITE sip:8910@172.25.248.83:5080;transport=udp SIP/2.0
Message Header
Via: SIP/2.0/UDP 172.19.222.85:5060;branch=z9hG4bK65c5e4f6dd9b0
To: <sip:8910@172.25.248.82>;tag=D2D2yaHZ40Z4H
SIP to tag: D2D2yaHZ40Z4H
Date: Fri, 23 Dec 2016 10:37:46 GMT
Route: <sip:172.25.248.82:5080;lr;ftag=16819417~305cfde1-0d58-4b14-a9ef-7b3502d970ea-39612243;did=cf7.f88ab87>
Min-SE: 1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Supported: Geolocation
Session-Expires: 1800;refresher=uac
Content-Length: 241
Message Body
Owner/Creator, Session Id (o): CiscoSystemsCCM-SIP 16819417 2 IN IP4 172.19.222.85
Media Description, name and address (m): audio 18620 RTP/AVP 8 101
CALL HOLD FROM CISCO SIDE
When we make and Hold from CISCO Side, CUCM send 1st an Early Offer with media inactive attribute and then a Delayed offer including send-only attribute on the ACK to the SBC's 200OK answer.
EFFECT: the holded party DOES NOT HEAR ANY MOH stream.
CUCM HOLD's 1st Early OFFER INVITE
Message Header
Via: SIP/2.0/UDP 172.19.222.85:5060;branch=z9hG4bK65c646a694d0
Date: Fri, 23 Dec 2016 10:38:01 GMT
Min-SE: 1800
CSeq: 103 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 247
Message Body
Owner/Creator, Session Id (o): CiscoSystemsCCM-SIP 16819417 3 IN IP4 172.19.222.85
Connection Information (c): IN IP4 0.0.0.0
Media Attribute (a): inactive
CUCM's ACK to SBC's 200OK on delayed offer INVITE:
Session Initiation Protocol (ACK)
Request-Line: ACK sip:8910@172.25.248.83:5080;transport=udp SIP/2.0
Message Header
Via: SIP/2.0/UDP 172.19.222.85:5060;branch=z9hG4bK65c677ae3fdf
Max-Forwards: 70
CSeq: 104 ACK
Content-Length: 195
Message Body
Owner/Creator, Session Id (o): CiscoSystemsCCM-SIP 16819417 4 IN IP4 172.19.222.85
Media Description, name and address (m): audio 4000 RTP/AVP 8
Media Attribute (a): X-cisco-media:umoh
Media Attribute (a): sendonly
CALL RESUME FROM CISCO SIDE
For the RESUME from CUCM side, it performs the same procedure used for HOLD except the fact that in the delayed offer ack it does not put any attribute in order to resum the media.
EFFECT: no audio at all from/to both parties.
Thanks for Help
Francesco
12-25-2016 07:39 PM
Hi Francesco,
From the snippets, after the hold, it breaks the already setup media with 0.0.0.0 and then a DO re-invite which in turn has ACK with SDP and I can see the CUCM sending attribute as sendonly, connection information as 172.19.222.95 (CUCM as MOH server ) and port as 4000 which is perfect for streaming MOH to SBC.
Do you have the MOH in the MRGL of the SIP Trunk?
Can you hardcode the SIP trunk with "MTP required" checkbox checked and then test.
Also, if that does not work, please post a packet capture from MOH and CCM trace (set to detailed) from all nodes for a test call on hold.
Hitesh
01-02-2017 02:31 AM
Hello Hitesh,
thanks for you quick answer and sorry for my late reply.
By the way I have some question for you:
1. On the other side (SBC cube is connecting to) prefer early offer on re-invite, is it possibile to force it from cube or also from my cucm side?
2. I'm going to add MOH server to MRGL list since it is missing now. Should I expect moh stream flowing from CUCM to SBC or should cube proxy it?
3. If I'm going to hardcode MTP Required on CUCM SIP trunk side, will video calls be supported?
4. If I'm using media flow through on cube, will video calls be supported?
I'm going to test moh and keep you updated.
