Cisco Unified Attendant Console Standard Installation
sabir.bedi1
Hello Team ,
Please let me know how can we download the CUAC Standard application and how can we use it ?
when does the license part comes in picture
I need the procedure to download the CUAC please
Manish Gogna
Hi Sabir,
You can download it from here
http://cisco-ac.arcsolutions.com/UserWebSite/cisco/ciscodefault.aspx
Its an exe file that you need to execute on the PC like RTMT or any other exe setups.
You can read the installation guides for more details depending on the version to get a clear idea of the requirements and installation procedure
http://www.cisco.com/c/en/us/support/unified-communications/unified-attendant-consoles/products-installation-guides-list.html
Manish
Jaime Valencia
The license is installed in the PC where the operator is installed, and you use the same site www.cisco.com/go/ac to get the license.
java
if this helps, please rate
