04-13-2009 03:17 PM - edited 03-15-2019 05:27 PM
guru's,
does cisco support CUBACS via VMWare?
cheers.
04-13-2009 05:47 PM
no, requirements are here:
Cisco Unified Business Attendant Console
VMWare is not a supported platform
java
if this helps, please rate
04-14-2009 05:49 AM
javalenc,
The doc gets the point across about a physical server or desktop pc,but if it is on vmware will TAC support it?
Thanks again.
04-14-2009 06:09 AM
NO
java
04-14-2009 06:26 AM
As you can see I was digging...thanks again!
04-14-2009 11:32 AM
So you have to deploy the CUBACS (Server app) on a seperate pc/server, thier is no way around this or an alternate installation method?
This means clients have to fork over a decent sized box just to support 1 little application?
To add, does thier have to be 1 CUBACS (Server) at each location of an Att console or can a centralized deployment model be used?
Thanks.
11-06-2009 01:02 AM
Hi Java,
If the Business attendant console is a rebaged ARC console how come ARC support the enterprise console in a virtual environment and cisco don't?
Also does the server have to be a standalone server or can you utilise a server with other applications on it?
Stafford
11-09-2009 08:05 AM
The CUBAC did not work out for our client, since you could not break out the CTI RP's and CTI Ports on the backend.
We had 3 seperate sites that wanted to stay seperate from an incoming call/ attendent perspective. So we moved forward with Arc Ent. which allowed us the flexibility we needed and as you mentioned above is supported on vmware.
Cheers.
