ā01-13-2012 03:55 AM - edited ā03-16-2019 08:59 AM
Hi there!
I recently got a request which will require a hunt group configured in a particular way and im wondering if you can help me out.
I am currently running Cisco Unified Call Manager Version 6. Is it possible to individually set the ring time between each member included in the hunt group?
E.g Ring on phone ext 1111 for X seconds - then phone 2222 for X seconds - and then phone 3333 for X seconds?
I am familiar with the "RNA revision timeout" which will configure a standard ring time between each line group member. I'm wondering if there is a similar setting but for the ring time between each member?
Cheers
Solved! Go to Solution.
ā01-13-2012 04:54 AM
Richard,
The only way I can think to achieve what you want is
to
1) create 3 LGs
2) Only 1 member per LG
3) Set the RNA to be different on each LG
PILOT = 6666
HLIST = OUR-TEAM
LG1 = MEM = 1111 RNA 15 SEC
LG2 = MEM = 2222 RNA 10 SEC
LG3 = MEM = 3333 RNA 20 SEC
Alex
ā01-13-2012 04:25 AM
I think is the RNA that you need
The Ring No Answer Reversion (RNAR) timeout speciļ¬es how long the hunting algorithm rings a member of the line group before it continues hunting according to the line group No Answer hunt option setting.
Tks.
ā01-13-2012 04:29 AM
Thanks for the reply. I am aware RNA will set a standard ring time between member in the group. I require different ring times between each memeber in the group. If the RNA was set to 10 then it would ring each phone for 10 seconds.
ā01-13-2012 04:44 AM
Hello Richard,
While hunting, the forwarding conļ¬guration of line group members is not used. If the hunting algorithm is ringing a phone and the call is not answered, the CFNA setting of that phone is ignored, and the hunting algorithm goes on to the next line group member.
You have the option No Answer Ring Duration ont the IP Phne but the CUCM ignored the settings on the IP Phone when the call is to the Hunt Pilot.
Richard,
to
1) create 3 LGs
PILOT = 6666
HLIST = OUR-TEAM
Alex
ā01-13-2012 05:00 AM
Very good tip Alex.
Leonardo
ā01-13-2012 06:07 AM
Thanks Alex, Great advice.
