Cisco unified Communications Manager 6.0 restart function
mferhai
Hi dear,
I need to restart both CUCM 6.0 servers...how to d it using the web browser http://<Ip_Address> ??
Thanks to help
Cheers
MF
Rob Huffman
Hi Mohamed,
You can access Cisco Unified Communications Operating System Administration directly by entering the following URL:
http://server-name/cmplatform
Enter your Administrator username and password.
Restart Current Version
To restart the system on the current partition without switching versions, follow this procedure:
Caution This procedure causes the system to restart and become temporarily out of service.
Procedure
Step 1 From the Cisco Unified Communications Operating System Administration window, navigate to Settings> Version.
The Version Settings window displays, which shows the software version on both the active and inactive partitions.
Step 2 To restart the system, click Restart, or to stop the operation, click Cancel.
If you click Restart, the system restarts on the current partition without switching versions.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/cucos/6_0_1/cucos/iptpch5.html
Hope this helps!
Rob
Rob Huffman
Hi Mohamed,
Procedure
Hope this helps!
Rob
