IP Telephony and Phones
watch here Journey banner_1
Labels
Hi,The following link states that XNTP enables NTP client only and it cannot serve as Server, so you cannot synch TO it.http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008009470f.shtmlI am running XNTP on all Call Manager...
dknov by Level 3
  • 291 Views
  • 1 replies
I've sort of inherited a problem with a fax machine in Italy. It has never worked and I don't have access to the designer, I have just been asked to make it work. The following is the relevant config details, I can provide more info if required. vo...
Greetings, ive been trying to setup an ATA186 for connection to a fax machine, we are using SIP as our primary voip method and i have configured the following parameters in CCME, im aware that there are issues with SIP and Faxing as most providers do...
Hi,I'm running CCME and CUE on a 2811 routers which is also an Internet gateway and running Zone Based Firewall.Under normal conditions everything works fine. Except when people start downloading (25+ mbps) the routers CPU jumps up to 100% and phones...
In ccm 6.1, is there a way to have callmgr prefix a '91' in front of the user tel number that show when using phone directory key?No AD integration, customer uses ccm ldap and user numbers are in it as full number, such as, 212-555-1212.customer want...
rvincent by Level 1
  • 458 Views
  • 2 replies
Good Afternoon all! :)I was wondering if anyone could lend me some assistance. I have installed my FXO module within my 2611 router and would now like to upgrade the ios so that it can support the voice but so far all the images seem to be way too hu...
