02-06-2013 07:04 AM - edited 03-16-2019 03:33 PM
All,
When I add the Unified Messaging account to the end user in unity connection I get this error saying " unable to locate an Exchange Server at which to access "user@domain.com", but in the SMTP stuff I have the IP address of the hosted exchange. The message I'm seeing below:
"Then in Unity Connection I'm getting this "Currently, this user does not have an SMTP proxy address that matches the Exchange email address that you specified in the Account Information section. We recommend that you add an SMTP proxy address so SMTP messages sent to the Connection server and addressed to the Exchange email address can be routed to the corresponding Connection user. "
So when I go and check this it says it's already configured on this object
Here are my settings:
02-08-2013 06:06 AM
Kindly you caheck the permission of Cisco Unity accout on your Actiive directory permissions.
02-08-2013 06:14 AM
Shouldn't the Cisco Unity account be an administrator or just a user?
02-08-2013 06:24 AM
kindly find the attached files
02-08-2013 08:02 AM
Yes i've reviewed over the documentation, and I think what's screwing me up is the PowerShell stuff. I tried running these commands but keep failing.
02-08-2013 08:21 AM
use this gain and try your scinario and check the output agian yo must have a error code , other thing i notice that the user name which you type is account is HDV\unityconn , did you create with the same syntax or it is just unityconn.Please review this point.
Step 1 In Cisco Unity Connection Administration, expand Tools, then select Task Management.
Step 2 On the Task Definitions page, select Check System Configuration.
Step 3 Select Run Now.
Step 4 Select Refresh to display links to the latest results.
02-08-2013 08:44 AM
Severity | Issue | Recommendation | Details |
![]() | The validation results for the user unified messaging service account khayes@mydomain.com with service Exchange10 are the following: | Service "Exchange10": AuthenticationMode=Basic [use HTTPS/no-validate] Search Domain=[bluprd0612.outlook.com] Site=[.] Types=[Exchange 2007/2010] [use LDAP] Username=[unitycon@mydomain.com] | |
![]() | Searching the network | Successfully connected to Exchange CAS server (https://bluprd0612.outlook.com/autodiscover/autodiscover.xml) from cache | |
![]() | Found Exchange server | khayes@mydomain.com will be accessed at Exchange CAS server bluprd0612.outlook.com | |
![]() | Server cannot be contacted by pinging. | Confirm that the systems service ports are functioning. | This check uses a low level protocol, such as ICMP ECHO, and may not work through firewalls. |
![]() | Failed accessing khayes@mydomain.com on bluprd0612.outlook.com | . | Diagnostic=[] Verb=[] url=[] request=[] response=[] |
02-08-2013 09:40 AM
I will tell you about troubleshoot , i think it will be useful
1- If you lookup inyor snapshots , try to modify in snapshot no3 ,5 the username to ( UnityConn) without HDV\ or @...., after that do the same task management, after that replace the UnityConn to khayes and try again the task management. Finally please shae tis troubleshoot
02-08-2013 10:08 AM
That's a Snapshot of my Unified Messaging Account status.
02-08-2013 10:47 AM
Dear
please change the username to the name .of the user Khayes which is needed to test , but please only typr the user name . After that please check.If you use LDAP between CUC and your active diretory , please check the validate credentials between CUC and Active directory.
02-08-2013 10:51 AM
Same results.
02-08-2013 10:55 AM
ignore serch DNS , and use the specify Exchange hostname , maybe some thing errors in your DNS .
02-08-2013 11:25 AM
![]() | The validation results for unified messaging service Exchange10 are the following: | Service "Exchange10": AuthenticationMode=[Basic] [use HTTPS/no-validate] Server=[bluprd0612.outlook.com] Type=[Exchange 2007/2010] Username=[unitycon@hostedatandvoice.com] | |
![]() | The server domain name can be resolved. | ||
![]() | Server bluprd0612.outlook.com cannot be contacted by pinging. | Confirm that the systems service ports are functioning. | This check uses a low level protocol, such as ICMP ECHO, and may not work through firewalls. |
![]() | This test does not test all aspects of the configuration of the service. To complete testing, add a unified messaging account for a user and test the account using the Test button on the Edit Unified Messaging Account page. |
02-08-2013 11:26 AM
I did what you suggested and that's the error I got.
02-08-2013 11:45 AM
Ok , let's do some thing else go back to your configuration with serch for DNS . The problem that it cannot reach to 365 exchange . Make sure that your account on Active diirectory is same which you type on CUC. Do not use encrypt uncheck the vlidate using LDAP.
use the below
--set network dns
– set network dns options
recommend that you configure Connection to use the same DNS environment in which the .Active Directory environment is publishing its records
02-08-2013 12:03 PM
Should it be my local DNS or Public DNS?
