Cisco Unity Connection CUC Roles and Reset PIN Privilege
milkboy33
Hello Everyone,
   Question:
   Which other roles does a user who has the Helpdesk role be able to change their password/PIN? For example we know a Helpdesk role user cannot change the password of other Helpdesk role users nor System Admin role users.
Roles in CUC 8.6:
Audio Text Admin
Audit Admin
Greeting Admin
Help Desk Admin
Mailbox Access Delegate
Remote Admin
System Admin
Technician
User Admin
Thanks!
Tom
The version I have tested with is 8.6.1.20006-2 and you're just 1 update away from the latest 8.6 version. I would have to assume that this is not a bug but instead it's how Cisco wants it to work. I would reach out to TAC and see if there is a way to either, modify the HD Admin role or provide you with a special update to change this functionality.
Yosh
HTH Regards, Yosh
18 Replies 18
milkboy33
Bump.
Anybody?
You want to know which other roles aside from the "Help Desk" role is allowed to change users password/pin but is also limited in performing other changes?
Yosh
HTH Regards, Yosh
Hello Tom,
I believe you asked this question a couple of days ago, and you do not want to add the System Role administrator.
Yes I did ask this a few days before and no we do not want to give Helpdesk Technicians the Systems Administrator role.
THIS Question however is different. What we want to know is ... for example if a user is a greetings administrator, will our Helpdesk Technician (having the Helpdesk role) be able to reset his/her PIN?
Does my question make sense or am I talking duck?
Tom
The Helpdesk will be able to reset the PIN.
Yosh
HTH Regards, Yosh
Thanks for the responses.
If this is correct then that means there's something else going on here, because our Helpdesk Tech cannot reset users with Greeting Admin role, nore Helpdesk/Systems Admin roles...
If you guys have any idea possibly why and could send us troubleshooting in the right direction, we'd really appreciate it.
If not thanks again for your help.
-Tom
Does your "Help Desk Administrator Roles" look like this:
Yosh
HTH Regards, Yosh
Rob Huffman
Hi Tom,
I think the only way we'll know for sure how this works is by some
more in depth testing.
I thought this was an interesting question so I took one of my test users
and made him a Helpdesk admin (role) and took another and made him
a Greetings admin (role).
My tests were exactly like yours - the Helpdesk admin role could not reset
the PIN for the user who had the Greetings admin role. Once I removed the
Greetings admin role then the PIN could be reset from the Helpdesk admin user.
Is there another we should test?
Cheers!
Rob
"Seek it out and ye shall find  "
- OneRepublic
This is interesting...
I tried initially with CUC 7.0.1 and the Help Desk user was able to successfully reset a Sys Admin and or Greeting Admin password/PIN.
I tried the same thing with CUC 8.6 and now I get the message "Unathorized"
The funny thing is that the "Role Privileges" haven't changed between versions.
Yosh
HTH Regards, Yosh
Rob Huffman
Thanks for verifying Yosh!
+5 for this! I guess this does vary from version to version
so Tom will have to test on his specific CUC build There
were some "escalation" bugs in the earlier CUC versions.
Cheers!
Rob
- OneRepublic
+5 Rob you always go above and beyond
Yosh
HTH Regards, Yosh
Awesome thank you guys. Yes we're running 8.6.
Try having two Helpdesk role users reset each other and have them try to reset a Sys Admin role. Should all be Not Authorized.
Last question. Do you guys know if there's a patch in 8.6 that fixed this?
Thanks.
What exact version of 8.6 are you running?
Yosh
HTH Regards, Yosh
