Cisco Unity Connection doesn't recognize DTMF buttons when pressed
rferriolo
When I dial the Unity Connection AutoAttendant and hear the recording (Press 1 for Sales Press 2 for Support, etc... there is no response when I press any of the DTMF buttons to reach the different departments. It just keeps playing the recording.
I created a System Call Handler for the Auto Attendant recording. under EDIT - GREETINGS - ALTERNATE , I unchecked the box to Ignore Caller Input.
Also for the first Call Handler that was created under the aforementioned Call Handler, when I Edit Caller Input for KEY #1, it is UNLOCKED and forEDIT - CALLER INPUT - when I select the 1 KEY, the Call Handler Radio Button is selected to go to the Consumer Sales System Call Handler that was created, however when I press 1 on the phone, there is no response...
        ##### ALL CONFIGURATIONS ARE SCCP #####
Any ideas?
thanks,
Ron
Please add this to your config...
dial-peer voice 100 voip
dtmf-relay rtp-nte sip-kpml
dial-peer voice 101 voip
dtmf-relay rtp-nte
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
6 Replies 6
Jaime Valencia
Is this an internal or external call??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jamie:
It's an inbound call from a PSTN phone. Internally, the call works fine..
In that case whats type of gateway are you using sip or h323?.Can you attach your sh run?
It is a SIP gateway. Please see below...
thanks
CorpHQ#sh run
Building configuration...
Current configuration : 6846 bytes
! No configuration change since last restart
version 12.4
no service pad
no service timestamps debug uptime
no service timestamps log uptime
hostname CorpHQ
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone PST -8
clock summer-time PDT recurring
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 177.1.11.1 177.1.11.14
ip dhcp excluded-address 177.1.11.21 177.1.11.254
ip dhcp excluded-address 177.2.11.1 177.2.11.14
ip dhcp excluded-address 177.2.11.21 177.2.11.254
ip dhcp pool CorpHQ-Phones
   network 177.1.11.0 255.255.255.0
   option 150 ip 177.1.10.10 177.1.10.20
   default-router 177.1.11.1
   dns-server 177.1.100.110
ip dhcp pool Branch1-Phones
   network 177.2.11.0 255.255.255.0
   default-router 177.2.11.1
no ip domain lookup
ip multicast-routing
no ipv6 cef
isdn switch-type primary-ni
voice service voip
fax protocol cisco
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice translation-rule 1
rule 1 // // type any subscriber plan any isdn
voice translation-rule 2
rule 1 // // type any national plan any isdn
voice translation-rule 3
rule 1 // // type any international plan any isdn
voice translation-rule 10
rule 1 /^[2-9].........$/ /9&/
rule 2 /^1[2-9].........$/ /9&/
rule 3 /^011/ /9&/
voice translation-rule 20
rule 1 // /+1/ type subscriber subscriber
rule 2 // /+1/ type national national
rule 3 // /+/ type international international
voice translation-profile GlobalizeInboundANI
translate calling 20
voice translation-profile MakeInternational
translate called 3
voice translation-profile MakeNational
translate called 2
voice translation-profile MakeSubscriber
translate called 1
voice translation-profile Prefix9_InFrom_CUCM
translate called 10
voice-card 0
dsp services dspfarm
archive
log config
  hidekeys
controller T1 0/0/0
pri-group timeslots 1-3,24
description == Voice Circuit to PSTN
interface Loopback0
ip address 177.1.254.1 255.255.255.255
ip pim dense-mode
interface FastEthernet0/0
description == To CorpHQ-Switch
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
description == Server VLAN
encapsulation dot1Q 10
ip address 177.1.10.1 255.255.255.0
ip pim dense-mode
interface FastEthernet0/0.11
description == Voice VLAN
encapsulation dot1Q 11
ip address 177.1.11.1 255.255.255.0
ip helper-address 177.1.10.10
ip nbar protocol-discovery
ip pim dense-mode
interface FastEthernet0/0.12
description == Data VLAN
encapsulation dot1Q 12
ip address 177.1.12.1 255.255.255.0
interface FastEthernet0/0.13
description == PSTN PHONE VLAN
encapsulation dot1Q 13
ip address 177.1.13.1 255.255.255.0
interface FastEthernet0/1
description === To PSTN
ip address 177.1.19.254 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/1/0
description == Frame-Relay Circuit to WAN
no ip address
encapsulation frame-relay
fair-queue 64 256 36
cdp enable
frame-relay lmi-type ansi
ip rsvp bandwidth
interface Serial0/1/0.1 point-to-point
description == FR To BR1
bandwidth 384
ip address 177.0.101.1 255.255.255.0
ip pim dense-mode
snmp trap link-status
frame-relay interface-dlci 101
ip rsvp bandwidth 136
interface Serial0/1/0.2 point-to-point
description == FR To BR2
ip address 177.0.201.1 255.255.255.0
frame-relay interface-dlci 102
router ospf 1
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 177.1.19.1
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0.10
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:23
translation-profile incoming GlobalizeInboundANI
voice-port 0/3/0
voice-port 0/3/1
ccm-manager music-on-hold
sccp local Loopback0
sccp ccm 177.1.10.10 identifier 1 priority 1 version 5.0.1
sccp ccm 177.1.10.20 identifier 2 priority 2 version 5.0.1
sccp ccm 177.1.254.3 identifier 3 priority 3 version 5.0.1
sccp
sccp ccm group 1
bind interface Loopback0
associate ccm 2 priority 1
associate ccm 1 priority 2
associate ccm 3 priority 3
associate profile 1 register CorpHQ-729-MTP
associate profile 2 register CorpHQ-711-MTP
associate profile 3 register CorpHQ-HW-Xcode
dspfarm profile 3 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
codec ilbc
maximum sessions 2
associate application SCCP
dspfarm profile 1 mtp
codec g729ar8
codec g729r8
rsvp
maximum sessions software 10
dspfarm profile 2 mtp
codec g711ulaw
rsvp
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 10 pots
translation-profile outgoing MakeSubscriber
destination-pattern 911
no digit-strip
port 0/0/0:23
dial-peer voice 11 pots
destination-pattern 9[2-9]..[2-9]......$
port 0/0/0:23
dial-peer voice 12 pots
translation-profile outgoing MakeNational
destination-pattern 91[2-9]..[2-9]......$
port 0/0/0:23
forward-digits 11
dial-peer voice 13 pots
translation-profile outgoing MakeInternational
destination-pattern 9011T
port 0/0/0:23
prefix 011
description == Inbound/Outbound SIP PSTN GW From/To CUCM Pub
translation-profile incoming Prefix9_InFrom_CUCM
destination-pattern ^2065011...$
voice-class codec 1
session protocol sipv2
session target ipv4:177.1.10.10
ip qos dscp cs3 signaling
description == Outbound SIP PSTN GW To CUCM Sub
voice-class codec 1
session target ipv4:177.1.10.20
dial-peer hunt 1
sip-ua
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous level 0 limit 20
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
logging synchronous
no login
line vty 5 15
exec-timeout 0 0
privilege level 15
logging synchronous
no login
scheduler allocate 20000 1000
ntp source Loopback0
ntp master 2
ntp server 177.1.254.254
end
dtmf-relay rtp-nte
Thanks a million. I have to research those commands.
