IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6058 Views
  • 14 replies
Hi,is anyone came accross of CUWL equal to how many DLU?When we generate the licens to load into the CM for CUWL, it did not go according to User.cisco do provide with DLU.is anyonw aware of CUWL Entry = how many DLU? CUWL Standard = how many DLU? CU...
cheaseung by Level 1
  • 2406 Views
  • 2 replies
Call Manager 8.6.1Just took over the network this week.  First question of ultimate importance.  Can you make it so I can dial the missed calls on my phone without having to dial an 8?My first thought was to make a line that didn't need to dial the 8...
Hi all,                   We want to configure MD’s phone in such way that when external calls came on MD’s number it will first land to his secretary then by another secretary & then by floor operator.Could you please help us to full fill above requ...
I am suddenly having issues forward calls.  I am able to dial the internal ext fine but when I attempt a call forward all to the number...I receive a call cannot be completed as dialed as soon as the second digit of the extension is entered.
Hi guys,We have phones that with long extension. We are using last 4 digit for internal usage in CUCM operation. But in SRST mode, we could't operate last 4 digit instead of entire extension. We have to dial entire extension. It is possible to do som...
Bar1s by Level 1
  • 601 Views
  • 3 replies
                   We are looking into paging on our VOIP network and I just started reading about it. The App that was purchased uses a single IP address for the multicast and they create groups under a control point. My question is this...if the pr...
gp1200x by Level 2
  • 9572 Views
  • 4 replies
Hi All,Looking for some help.  I'm kind of new to the whole cisco VOIP world coming from mainly TDM.I setup a TDM to IP link between an Avaya PBX and NEC switch like so: Avaya -> h323 -> Cisco 2911 -> qsig T1 -> NEC.  Links are working perfectly, but...
I recently took over the Call Mananger server for my group.  SIP Trunk service has been ordered.  The provider has advised they will be supplying a session border controller that will be our connection point to their service.  Their session border co...
Resolved! Meet me problem
Hello , I already  configured meetme confrernce  in my CUCM.The meetme is configured that every one use , I want to add option of  system announce the participante name when he join to confrence (it will be recorded right before he join ).
                   Hi Experts;I have 2nd lines on our service desk ip phones. when agents try to make a call from their 2nd lines, i need to hide their numbers on called ip phones' screens. moreover, i need to hide their numbers in missed, received d...
Hi,My voice gateway is equipped with 8 FXO port hence 8 analogue lines. All numbers are being used for incoming and outgoing. For outgoing, one trunk group is fine to switch the line.Now, if one user has established call outside on port 1. Simultaneo...
techguy by Level 4
  • 1729 Views
  • 3 replies
