Cisco Unity Connection helpdesk Role
orellanas
Hi everyone,
Can you please help me with the following on Unity 10.5?
I'm trying to give access to the following options to a HelpDesk user :
- Search user
- Import users
- Sync users with LDAP (LDAP Directory Configuration)
I'm able to have the search user and Sync users with the roles Technician and HelpDesk Administrator but import users.
import users is just allowed for the role "User Administrator", but this role gives a ton of access that helpDesk team won't need.
can you please address me how to target this need.
I know that in Unity 11+ this is possible in easiest way.
thanks in advance,
Alberto
Alberto
Jaime Valencia
Unless you run CUC 11.5 or above, you're limited to the canned roles that are available, there is no workaround besides upgrading
Custom roles
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/11x/release/notes/b_Release_Notes_1151.html#id_18717
java
if this helps, please rate
Thanks Jaime, I read you about this in another post, I which to have something programmable path to target that task.
