Cisco Unity Connection Serviceability reports
Jerrytech1
Trying to run Call Handler Report. The date range maxes out at 2020. Can't select today's date 3/8/2022
Ratheesh Kumar
Hi there
its a known bug impacted all releases i.e 10.5 ,11.5, 12.0 and 12.5. You won’t be able to select year 2021 or later
You can install a COP file to fix this
link - https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvw93402
Hope this Helps
Cheers
Rath!
***Please rate helpful posts and if applicable mark "Accept as a Solution"***
Ratheesh Kumar
Hi there
Hope this Helps
Cheers
Rath!
Jerrytech1
Thanks. That worked.
dkikko2
Cisco Unity Connection Serviceability: Version 12.5.1.17900-31
Still running into same issues but the year is stuck on 2023 for call handler and all other reports.
Wondering if 2024 will materialize???
