Cisco Unity Connection with LDAP Problem
Younes Chafi
I have a CUCM and Cisco Unity and an LDAP Server 2008,
When I configure CUCM with LDAP, users are imported, but when I did the same method for integrating Cisco Unity with ldap does not work, when I click "Import User" via LDAP I find a user who call "Token_User_8b191a06-5041-4b41-bd5f-0575fde674e3" without extension, and no user is imported
Unity Version : 9.0
CUCM Version : 9.0
LDAP : Windows 2008 Server
Younes CHAFI.
Please attached the full capture..I cant make anything of the screen capture
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
15 Replies 15
islam.kamal
Level 10
Level 10
Hi Younis
1- Regarding AD 2008 , did you follow Cisco guide as the below:-
**When you are configuring Connection for Microsoft Active Directory 2008 Lightweight Directory Services, select
Microsoft Active Directory Application
2- Did you try  to delete the LDAP integration and re-create it again?.
Please rate all useful information
I followed the guide and I selected Microsoft Active Directory
and I deleted/recreated the integration but the same problem
Younes CHAFI.
Can you post a screen shot of your LDAP config, including the search base..Do you have the same search base configured as with CUCM?
Yes, it is the same configuration in CUCM,
I configure CUCM with LDAP, users are imported.
attached the error message and the LDAP config
try this for your search base,
ou=users,dc=lab,dc=ma
Hi ,
does not work, I get an error message
"directory.error.userbase"
What is your setup in AD? Do you have a container called users?
Can you try this again..
user search base dc=lab,dc=ma
here is my LDAP configuration,
I tried this syntax cn=Users,dc=lab,dc=ma , but without result
Younes CHAFI.
Users are usuallually in Orbanisation units hence referneced by OU not CN (containers)
Try and use the whole domain,  dc=lab, dc=ma
I tried this syntax dc=lab,dc=ma , but the same problem,
Younes CHAFI
Ok, there sre two things to do now..
1. Restart CUC..If you have already done that, then do opion 2
Utils service system restart
2. Take captures from cuc.. (once you start the capture, then go and try and force the ldap sync)
https://supportforums.cisco.com/docs/DOC-11599
Instead of using RTMT to collect the files, you can also use a SFTP tool like free FTPD..
Example below:
admin: utils network capture file mycap count 100000 size all host all 10.5.244.10
Executing command with options:
size=all count=100000 interface=eth0
src= dest= port=
ip=10.3.2.21
The trace continues until you press Ctrl-C.
Step 3: Download the Trace File
OK, so now you have a file somewhere on the system with the data that you would really like to view.  You have to download it to your machine.  You will need a running SFTP server on the target machine.  You can use openSSH on linux/unix, freeFTPd, copSSH, or something similar.
admin:file get activelog platform/cli/newcap.cap
Collect the capture and attach here
I followed the procedure described in your response and I found that Unity is surrendering response ldap
attached the error message on wireshark.
I think the attribute "Extension" is not the attribute "telephoneNumber" LDAP?
Younes CHAFI.
Ok,
Here's the download link traces
http://www.sendspace.com/file/2tp1nf
Younes CHAF
