Cisco Unity Express (CUE) Default Prompt Location or Download Inquiry
Andrew Chandler
If a CUE Default prompt is accidentally recorded over or erased how may it be recovered or downloaded versus a full factory default reset of the CUE?
you can tell your cue version so some one can attach it to you
i've CUE Version 8.0.5 and i need these default prompts urgently
thx in advance
paolo bevilacqua
Which default prompt are you referring to ?
