Cisco Unity v.10 delete voicemail messages
smith606306
I have a user who has over 100 messages in his voicemail box.
What is the easiest way of deleting these all at once?
Manish Gogna
Please check the following:
http://www.ciscounitytools.com/Applications/CxN/BulkUserDelete/Help/ConnectionBulkUserDelete.htm#_Toc239146397
http://www.ciscounitytools.com/Applications/CxN/BulkUserDelete/BulkUserDelete.html
Manish
Thanks Manish for the great link (+5)!!
Due to security on our network i cant install that tool and it would take weeks to get it approved. Does anyone know a simpler way apart from me just deleting and re-adding the voicemail box
Login via PCA/Inbox and remove them.
java
if this helps, please rate
