Cisco VG224
Neville Price
I have a VG224 that has been working with no issues whatsoever, but now the devices on the Call Manager are showing as unregistered, after logging onto the VG via console cable shows the VG freezing at the same point constantly (See attached log)  just before it freezes the devices register for a couple of seconds then become unregistered.  HELP!!
7 Replies 7
Leonardo Santana
Hello Neville,
Did you check if your VG is with high cpu utilization?
Use the show processes cpu to check this.
Any changes on the VG like ios upgrade?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
I cant input any commands to the VG, It freezes on the point of load in the attached doc.  No changes made to the VG's at all, only powering on and off with power tests as it is located in a new build.
Hello Neville,
Take a look on this doc.
You might facing and software error, or a console fault or worst a VG fault.
http://www.cisco.com/c/en/us/td/docs/routers/access/vg224/hardware/installation/guide/hig/higpow.html
Do you have an valid support contract?
Leonardo Santana
Leonardo Santana
Got to the bottom of it, the Compact Flash Memory Card is faulty.
Do you have logs sent to syslog server? This might be helpful
Andrew West
Level 4
Level 4
Any firewalls in your path?
Nadeem Ahmed
Do you see any crashinfo file getting or traceback . can you please post the same.
Br,
nadeem
Br, Nadeem Please rate all useful post.
