12-15-2015 10:28 PM - edited 03-17-2019 05:14 AM
we are using version 15.3(1)T1 for our voice GW we need to upgrade to new version.
My q? what is the suitable version to upgrade it
The suggested is 15.3 and 15.4 but the last version is 15.6.....your support PLS
Zaineb
12-15-2015 11:13 PM
Go to 15.4(3)M4. That's the golden release at this time. When you navigate to the specific router's IOS download page, on the left hand side, you will see releases that have a star next to them. These are the stable ones that can be upgraded to.
12-16-2015 11:37 PM
Thanks Sree to replay
Just one issue ..how can I know that this new release not contains any bugs.
BR
12-28-2015 04:12 AM
No release does not contain bugs. And if it says there's no bugs then whether the feedback community is not doing its job or no one uses the software.
To answer your question, Sreekanth gave you "the golden release" which means it contains the fewest bugs so far. But you have to know that tomorrow more bugs will be reported and another software release will be more stable. This is the life.
12-28-2015 06:47 AM
You can review the release notes to see if there are any bugs that could affect your deployment:
http://www.cisco.com/c/en/us/td/docs/ios/15_4m_and_t/release/notes/15_4m_and_t/154-3MCAVS.html
