Cisco wifi Phone keep Rebooting
arif58812
Hello Guys
i am having trouble with cisco phone 8821, firmware version active load :sip8821.11-0-2SR2-1, bootload sb28821.HE-01-019, keep rebooting while on the desk or roaming. and it is showing network busy when dialing out.
the cucm ver: System version: 11.0.1.20000-2
anyone can help
Adarsh Chauhan
Level 3
Level 3
Is it happening with all 8821 phones or with one in particular?
As a proactive step if its happening on all you can upgrade one to cmterm-8821-sip.11-0-3-6.k3.cop.sgn and see if there is any improvement.
Also you can attach console logs from one of the 8221 here to for us to review.
Please do mention the timestamp when it reboots.
Please rate and mark correct if helpful
Adarsh Chauhan
Adarsh Chauhan
hi Adarsh
thanks for your reply,
it is happening to all phones 8821
here the console log attaching which happened around 12:43
didnt see any difference after the new code installation .
thanks
I had a look at the console logs and it seems to be in a loop where it's connecting to
selected BSS 70:e4:22:aa:c9:74 ssid='TALK2'
again and again.
I did a bug scrub and got couple of hits but not convincing and some were resolved in the latest version.
8821 is a fairly new phone and I would suggest you to open a TAC case.
Adarsh Chauhan
Adarsh Chauhan
Bobby Stojceski
The Network Busy issue is a known defect on the 8821 handset. TAC told me to disable ACM on the WLC (Wireless tab > 802.11a/n/ac or b/g > Media and then the Call Admission Control checkbox as a workaround. I didn't do it as I prefer having it on and the issue wasn't regular enough to worry about for now.
