02-01-2023 11:50 PM
Hello Team,
Am facing a unusual behavior of Cisco 840 ip Phone in CUCM version 14. All Phones are connecting in Aruba Wireless. 5 Ghz and 2.4 Ghz are enabled in Aruba Wireless. Wireless range are showing Fine in Mobiles and phones. No problem identified regarding a blind spot.
But,
i am facing a random issue in Cisco 840 Wireless phones. Sip Registration is failing at some point of time and phones reregister after some time. When i check packet capture in Phones its showing TCP session restart.
Does anyone faced this issue before?? please help if any info available.
02-02-2023 01:27 AM
Logs from CUCM and Phone will be required.
If you experience a problem with your phone, you can create a bundle of log reports that can help the system administrator troubleshoot the issue. It may take several minutes to generate the problem report and log files. You'll know that the report is complete when the phone vibrates twice.
Note |
If your phone's web browser is enabled, you can download the log bundle files to give to the system administrator. |
Step 1 |
Access the Cisco Phone
app. |
Step 2 |
Choose one of the following based on your phone's software version:
Step 3 |
Step 4 |
After the phone vibrates twice, contact your system administrator to provide a description of the issue and approximate time. |
Step 5 |
If your phone's web browser is enabled, download the log bundle from the Device Logs tab to provide to the system administrator. |
05-08-2023 09:19 AM
Did you find any resolution to this issue? I am running a very similar environment on version 14 with Aruba wireless. I haven't yet looked at traces, but my symptoms are exactly the same as you describe.
I would be very interested to hear about your resolution, and/or next steps in troubleshooting.
07-31-2023 10:07 AM
Having same issues with Cisco AP's. The phone will make a terrible loud ring tone type noise and then reconnect. Still working with Cisco.
12-15-2023 04:16 AM
Any more details? Resolution?
