CUCM - Phone address book
angelito_mas
Hi everyone,
I have a CUCM 11.5 with no LDAP server. I need to create an Phone book for all my users.
Is it possible? How can I do it?
Thanks!
5 Replies 5
b.winter
Phone book is automatically created with the local users in the "end user" page.
So if you need a new phone book entry, you need to add a new local user in cucm.
And the phone book services are normally available per default for every hardphone.
since I have to add just emergency numbers, can I create a separate group or folder?
No.
You could create Local End User accounts with the needed information for these Emergency Numbers. You would configure the accounts with no password or PIN or Access Control Groups, so the accounts couldn't "do" anything. But they would show up in the Corporate Directory like any other End User.
Maren
DaviRocK!
You can only create a phone book from user management, end users.
You can create entry list how end user, example
Name Peter Phone Number 3001
Name Emergency Phone Number 911
Best regards
