Cisco881-FXS to FXS Transfer
david-lima
Level 4
Level 4
Hi all, I have a C881 with 4 FXS analog phones in a remote site, and a CME in the central site, calls between sites are working fine using H323, but I'm wondering if it is possible to transfer a call from one FXS phone to another FXS phone, with phones that are connected to the C881.
I was configuring timing hookflash-in X Y without results.
If is possible, please share the information.
Thanks a lot
David
paolo bevilacqua
Yes it is possible. Configure the ports in SCCP mode and register them to the CME.
paolo bevilacqua
Hi Paolo, thanks a lot, it works great.
Is it possible to activate SRST for this analog phones.
Thanks again
David
No, if you loose the link, and the ports are in SCCP mode, they will be unable to call each other.
I have a simple question, the 881SRTS router can be register with a CUCM 7 and work has a remote gateway (SCCP,MGCP or H323) with FXO lines ?
