ā05-15-2018 06:35 AM - edited ā03-17-2019 12:49 PM
dear i need clarification about some thing
my manager has cisco phone 7821 he always complain about quality of voice and he cant hear well
we have another phone 7945 installed in our office he tried and its fine .. so now the question is which phone should i order the same one 7945 or 7465 ? and which one is better ?
7945 that we have already is old and there is a new release? or its fine if i order another same one
7465 is latest or there is newer ?
what should i order ?
i already use cisco manager express cme for configurations and i have 25 seat licenses
can i have your kindly advice
thanks
ā05-21-2018 03:40 AM
dear i need to ask about the following coz im confused
Kindly note that the CP-7945G will be end of sale next June as shown in the following link:
https://www.cisco.com/c/en/us/support/collaboration-endpoints/unified-ip-phone-7945g/model.html
The replacement IP phone is CP-8841-K9=, so do you need to make an offer for it?
this what i received from cisco vendor company , so is it right ?
and which better 7945 or 8841 and should i order the new one or what ?
and what about its configuration on cme ?
thanks
ā05-21-2018 06:12 AM
ā05-21-2018 06:31 AM
okay thanks
now im asking about the phone 7945 cisco stop selling it ? and whats the instead of it on market?
what about brand that they mentioned to me 8xxx ?
cisco phone 7945 still available on market or not ?
ā05-21-2018 06:35 AM
ā05-21-2018 07:54 AM
so what do u prefer to me ? need ur advice ? should i go with 7945 or CP-8841-K9 ?
thanks alot for ur great help
ā05-21-2018 08:11 AM
ā06-06-2018 03:08 AM
m using sip78xx.12-1-1-12 also im using cme for configurations
Version 10.5
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip source-address 192.168.2.207 port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
max-ephones 58
max-dn 64
max-conferences 8 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 10
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
time-format 24
date-format dd-mm-yy
timezone 25 Egypt Standard/Daylight Time
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
web admin system name romani password cisco
web admin customer name romani1 password cisco
edit DN through Web: enabled.
edit TIME through web: enabled.
background save interval 10 minutes
Log (table parameters):
max-size: 150
retain-timer: 15
create cnf-files version-stamp 7960 Jun 03 2018 17:11:36
transfer-system full-consult dss
transfer-digit-collect new-call
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
Router(config-register-pool)#codec ?
g711alaw Use G.711 Alaw
g711ulaw Use G.711 ulaw
g722-64K Use G722-64K 64000 bps
g729r8 Use G.729
ilbc Use iLBC 13330 or 15200 bp
why it giving me busy tone when im trying make call after changing the codec of one phone to g722-64k ????
ā06-06-2018 07:49 AM
Is that busy tone while calling internal or external calls.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
ā06-06-2018 07:56 AM
any type of number ex or in - im just after typing the digits and press dial busy tone coming directly
ā06-06-2018 07:59 AM
Can you please share your full config, sh run
Hope this Helps
Cheers
Rath!
ā06-06-2018 08:40 AM - edited ā06-06-2018 04:20 PM
Router#show run
Building configuration...
Current configuration : 13806 bytes
! Last configuration change at 16:56:24 UTC Wed Jun 6 2018 by amr
! NVRAM config last updated at 16:56:12 UTC Wed Jun 6 2018 by amr
version 15.4
hostname Router
boot-start-marker
boot-end-marker
logging buffered 4096
enable secret 5 $1$l9ha$dHLj/scp8Qm8C77UcUa/K0
enable password cisco1
no aaa new-model
clock timezone UTC 2 0
ip dhcp relay information trust-all
ip dhcp excluded-address 192.168.2.207
ip dhcp pool voice
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.207
option 150 ip 192.168.2.207
dns-server 8.8.8.8 8.8.4.4
ip dhcp global-options
dns-server 163.121.128.134 163.121.128.135
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
trunk group Mobile
trunk group pstn
cts logging verbose
crypto pki trustpoint TP-self-signed-2728187941
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2728187941
revocation-check none
rsakeypair TP-self-signed-2728187941
crypto pki certificate chain TP-self-signed-2728187941
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32373238 31383739 3431301E 170D3135 30333231 31333235
31375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 37323831
38373934 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C184 ACFFFB46 C4C5B385 CBE1A6C9 0CD5DA07 385B1D99 C8AD86D5 9CFAA109
CACAA786 2AE1D32F CC3AC285 BBA7B419 04B2482A 0B7DD955 99130F92 48B2A075
E8B170CA 230036B1 73D4F8FF 26E2B556 6FD337BE 3A8B341B 0A80C612 6737B714
96CFA520 995A0E45 993F558D 1DFC222A 3F587ABE E3E1F038 3CA3152F F0222271
00330203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14AEA7B2 0A72790D BDCE8BF7 9C2D6CF2 C1C8A393 5B301D06
03551D0E 04160414 AEA7B20A 72790DBD CE8BF79C 2D6CF2C1 C8A3935B 300D0609
2A864886 F70D0101 05050003 81810072 94945FF4 84A78DF0 CF361867 79566C0F
D6FB48FD 3ACB218F 800D5CA1 54F4F4E2 5ED04E26 4A5DC612 097EE5D0 5A26618A
80DB770F 30768D27 C5F7679A D5E81483 C3993CC4 15CFF495 39F11F9D 7EE9054D
DC5CDEEE B3E35F53 09DB553A EACEE590 D128A220 52EE5C32 FCA5A626 BDAD34D5
6DABFE4F F30D63A5 5C92E27A 7E3EE0
quit
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol pass-through g711ulaw
h323
sip
registrar server
voice register global
mode cme
source-address 192.168.2.207 port 5060
max-dn 64
max-pool 58
load 7821 sip78xx.12-1-1-12.loads
timezone 25
date-format D/M/Y
tftp-path flash:
create profile sync 0165464226868521
network-locale GB
voice register dn 1
voice register dn 5
number 100
name Inas AlMahalawi
label Inas AlMahalawi
mwi
voice register dn 6
number 101
name Meeting Room A
label Meeting Room A
mwi
voice register dn 7
number 102
call-forward b2bua noan 5 timeout 20
name Walid Hifny
auto-answer
label Walid Hifny
mwi
mobility
voice register dn 8
translation-profile incoming AMR
translation-profile outgoing AMRALRAZZAZ
number 103
name Amr Al-RaZzAz
auto-answer
label Amr Al-RaZzAz
mwi
mobility
voice register dn 9
number 104
name Khaled Elgarhy
label Khaled Elgarhy
mwi
voice register dn 10
number 105
name Sales 2
label Sales 2
mwi
voice register dn 11
number 107
name Amr Ismail
label Amr Ismail
mwi
voice register dn 12
number 108
name Mohammed Abdella
label Mohammed Abdella
mwi
voice register dn 13
number 109
name Sales 1
label Sales 1
mwi
voice register dn 14
number 110
name Karim Habib
label Karim Habib
mwi
voice register dn 15
number 114
name Tamer Mazen
label Tamer Mazen
mwi
voice register dn 16
number 115
name Meeting Room B
label Meeting Room B
mwi
voice register dn 17
number 106
name Conference Room
label Conference Room
mwi
voice register dn 18
number 112
name Omar Mohamed
label Omar Mohamed
mwi
voice register dn 19
number 113
name Tarek Aldessouky
label Tarek Aldessouky
mwi
mobility
voice register pool 5
busy-trigger-per-button 1
id mac 5067.AE21.4E6E
type 7821
number 1 dn 5
cor incoming mobile-long default
presence call-list
dtmf-relay rtp-nte
username romani password cisco
codec g711ulaw
voice register pool 6
pin 4100
id mac 5067.AE21.4EA5
type 7821
number 1 dn 6
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 7
id mac 5067.AE21.9A74
type 7821
number 1 dn 7
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 8
id mac 5067.AE21.9A5A
type 7821
number 1 dn 8
no digit collect kpml
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 9
id mac 5067.AE21.99AC
type 7821
number 1 dn 9
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 10
id mac 5067.AE21.9A52
type 7821
number 1 dn 10
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 11
id mac 5067.AE21.9A1D
type 7821
number 1 dn 11
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 12
id mac 5067.AE21.4F10
type 7821
number 1 dn 12
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 13
id mac 5067.AE21.4E15
type 7821
number 1 dn 13
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 14
id mac 5067.AE21.4DF7
type 7821
number 1 dn 14
presence call-list
dtmf-relay sip-kpml sip-notify
codec g711ulaw
voice register pool 15
id mac 5067.AE21.4EAD
type 7821
number 1 dn 15
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 16
id mac 5067.AE21.4E9D
type 7821
number 1 dn 16
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 17
id mac 5067.AE21.4DD6
type 7821
number 1 dn 17
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 18
id mac 5067.AE21.4F96
type 7821
number 1 dn 18
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 19
id mac 5067.AE21.4F9C
type 7821
number 1 dn 19
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
no vad
license udi pid CISCO2911/K9 sn FCZ190360AM
license accept end user agreement
hw-module pvdm 0/0
username ,,,, password ,,,,, cish:
username ........ secret 5 $1$5Klr$GneBF.AwmAgvMY4lW/Ylk1
username aa
username Acc
username aiiiii privilege 15 secret 9 $9$eSfWH2ACcyEpgU$kBe69JmDRjwR01pDNDUjBF17G2JI8hOCafvoaptS8f6
redundancy
process-max-time 50
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.2.207 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
ip address 192.168.1.207 255.255.255.0
ip flow ingress
ip flow egress
ip nat outside
ip rip advertise 100
ip rip receive version 2
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
router rip
network 192.168.1.0
network 192.168.2.0
ip default-gateway 192.168.2.207
ip forward-protocol nd
ip http server
ip http secure-server
ip http path flash:
ip flow-export source GigabitEthernet0/0
ip flow-export version 9
ip flow-export destination 192.168.2.195 9996
ip flow-top-talkers
top 60
sort-by packets
ip dns view default
dns forwarder 8.8.8.8
ip dns server
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip nat inside source list 150 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
snmp-server community public RO
tftp-server flash:cmterm-78xx.12-1-1-12/kern78xx.12-1-1-12.sbn alias kern78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/rootfs2.78xx.12-1-1-12.sbn alias rootfs2.78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/rootfs78xx.12-1-1-12.sbn alias rootfs78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sboot2.78xx.12-1-1-12.sbn alias sboot2.78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sboot78xx.12-1-1-12.sbn alias sboot78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sip78xx.12-1-1-12.loads alias sip78xx.12-1-1-12.loads
tftp-server flash:cmterm-78xx.12-1-1-12/kern2.78xx.12-1-1-12.sbn alias kern2.78xx.12-1-1-12.sbn
access-list 1 permit 192.168.2.0
access-list 150 permit ip any any
control-plane
voice-port 0/0/0
trunk-group Mobile
connection plar opx 100
description Configured by 2911 4 FXO-0/0/0-Custom
caller-id enable
voice-port 0/0/1
trunk-group Mobile
description Configured by 2911 4 FXO-0/0/1-Custom
caller-id enable
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
mgcp profile -long
dial-peer cor custom
name internal
name pstn
name long
name mobile
name international
dial-peer cor list internal
member internal
dial-peer cor list mobile-long
member internal
member pstn
member long
member mobile
dial-peer cor list manager
member internal
member pstn
member long
member mobile
member international
dial-peer voice 8 pots
trunkgroup long
trunkgroup Mobile
corlist outgoing mobile-long
destination-pattern 904......T
prefix 04
dial-peer voice 9 pots
trunkgroup long
trunkgroup Mobile
destination-pattern 905......T
prefix 05
dial-peer voice 22 pots
service stcapp
port 0/0/2
dial-peer voice 10 pots
trunkgroup long
trunkgroup Mobile
trunkgroup Inter
trunkgroup international
corlist outgoing manager
description **Cairo**
destination-pattern 900T
prefix 00
dial-peer voice 2 pots
trunkgroup Mobile
trunkgroup PSTN
trunkgroup long
description **shortcut No**
destination-pattern 91[16789]...
forward-digits 5
dial-peer voice 3 pots
trunkgroup long
trunkgroup PSTN
description ** Services **
destination-pattern 91[1245].
forward-digits 3
prefix 013
dial-peer voice 7 pots
trunkgroup long
trunkgroup Mobile
description **Alex**
destination-pattern 903......T
prefix 03
dial-peer voice 15 pots
dial-peer voice 2000 voip
description ** Sedestination-pattern 9013.T
destination-pattern 402
b2bua
session protocol sipv2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 1 pots
trunkgroup pstn
trunkgroup Mobile
description ** Inside Cairo **
destination-pattern 902.......T
no digit-strip
forward-digits 8
prefix 02
no register e164
dial-peer voice 4 pots
trunkgroup Mobile
description ** Mobile **
destination-pattern 901[012]........
forward-digits 11
dial-peer voice 6 pots
trunkgroup long
trunkgroup Mobile
description **Kaluobia**
prefix 013
dial-peer voice 11 pots
trunkgroup long
trunkgroup Mobile
prefix 00
dial-peer voice 12 pots
prefix 00
dial-peer voice 21 pots
service stcapp
port 0/0/1
dial-peer voice 13 pots
trunkgroup Mobile
trunkgroup PSTN
trunkgroup long
description **Vodafone**
destination-pattern 92[47].
forward-digits 3
dial-peer voice 5 pots
trunkgroup long
trunkgroup Mobile
description **sharm alsheikh**
destination-pattern 9069......T
prefix 069
presence
gatekeeper
shutdown
telephony-service
max-ephones 58
max-dn 64
time-zone 25
time-format 24
dn-webedit
time-webedit
ephone-dn 1 dual-line
number 111 no-reg primary
label 111
description Mr. Amr Ismaeil
name Mr. Amr Ismaeil
ephone 1
video
mac-address 1CE8.5DC8.D374
username "aa"
paging-dn 1
type 7945
button 1:1
pin 4100
ephone 2
ephone 5
line con 0
password ,,,,,,
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
ā06-07-2018 05:52 AM
This sounds similar to an earlier bug with 9971 versions in CME. When G.722 codec is forced, that ends up in busy call. You can try the workaround on a phone as mentioned or your best bet is TAC
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtu39847/?rfs=iqvred
Hope this Helps
Cheers
Rath!
ā05-21-2018 08:14 AM
Hi there
Cisco ip phones 7945, 7965, 7975 and 7916, Great set of phones, sadly got End of Sale by June 18,2018. But still you can still purchase these models in the next one more month and Cisco will ship till September 16, 2018.
But couple of things you have to consider, in another year, by June 18, 2019 Cisco stops supporting the software maintenance release for these phones. This is also very important. After this date Cisco will not develop, repair, maintain, or test the product software. So assume if you face any hardware or software bugs in these phones after June 18, 2019, you donāt get any hot fixes.
Cisco 7945G & 7965G are still my personal favourite but if I am in your position I go ahead with Ciscoās replacement models for future planning.
Replacement for 7945G is 8841 and 8851 for 7965.
Hope this Helps
Cheers
Rath!
ā05-22-2018 03:05 AM
thanks for great answer..
have some questions :-
1- what if i get 7945G even if cisco stop selling it ?it will keep working fine even after cisco not supporting?
2- what difference between 7945G and 8841 ? 8841 is better and has more option and quality of voice is better or no difference between them ?
3- im using cme for configuration, so 8841 same configuration like 7xxx?
any how if i found 7945 phone and bought it ,it will work fine even if no support from cisco ?
ā05-22-2018 03:20 AM
another important q?
what difference between 7945 and 8841? what about voice quality and level of sound is it loud like 7xxx?
also need to know the difference the main one ?
last advice please if u were in my place what u will bring 7945 or 8841 ?
thanks alot im confused :)
