06-13-2014 11:11 AM - edited 03-16-2019 11:06 PM
I know this has to be possible, but I am still new to Unity Connection and I bet I have overlooked it a dozen times trying to get this setup.
How can I turn off the forward to voicemail during business hours? She wants her staff to answer the call, not let it go to voicemail.
06-13-2014 11:41 AM
You can configure the schedule in CUC, and configure the behavior you desire (route to someone else, no VM, etc.)
06-13-2014 11:54 AM
Ok, I found where I can create a new schedule, assign times to it, etc.
I even found in the user information where I can assign that schedule to the extension. It does not seem to do anything. For example, I made the times on the schedule I created (test_schedule) between 1:00 pm and 4:00 pm.
I then went to my test extension and assigned the "test_schedule" to it and placed a call. It went to voicemail.
06-13-2014 11:58 AM
And have you configured the schedule and the closed greeting as desired??
06-13-2014 12:07 PM
I have the schedule created. I don't know what to do with the greetings, though.
If I want the phone to ring until someone picks it up between 8 am and 5 pm, what greeting would I change? She only wants voicemail after hours.
06-14-2014 05:18 PM
This is not up to CUC. CUCM makes the decision when to stop ringing the DN and send it to voicemail based on the CFNA Timer. There are two ways I can think of accomplishing this with slightly different caller experiences:
Also note that scenario one would allow the switchboard to send a caller directly to voicemail still. Whether this is desired or not may depend on your environment.
