Cluster ID
What is the impact if I need to change the CUCM Cluster ID from its default "StandAloneCluster" to "NYC" for instance?. Provided that the same cluster is integrated to Unity, UCCX, IM&P, CUEAC.
Any impact on certificates?
Version 9.1.2
Per Cisco documentation, the Cluster ID is much relevant in the CDR records.
6 Replies 6
Deepak Mehta
There shouldn't be any problem for certificates unless cluster are in mixed mode .
Ayodeji Okanlawon
There is really no impact on changing it from default standalone cluster.
Please rate all useful posts
Jaime Valencia
Aside from CDR, that is used as a unique identifier for ILS for example, I don't believe that is used anywhere in the communication with other products.
java
if this helps, please rate
If i rename the cluster ID, a pop-up comes up "Restart all the services....." And the only option is "OK" Attached the screenshot.
Can we rename the cluster ID during production hours?
You still have to restart the services sometime.  Just schedule a cluster reboot.
George Sotiropoulos
Apart from the CDR records, there is no impact on changing the cluster ID. I have done it various times, without any loss of service.
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
