cme 10.5 installation file
Surat Teknoloji
Where can ı  find cme 10.5 installation file ? I can only find 10.5 gui file on cisco website.
Is there anyone encounter with this problem?
thanks in advance
5 Replies 5
Jaime Valencia
CME is embedded into IOS, simply use the IOS version that contains CME 10.5
java
if this helps, please rate
what do you mean exactly ? there is a file for all versions except 10.5 .
https://software.cisco.com/download/release.html?mdfid=277641082&flowid=45748&softwareid=282786567&release=10.5&relind=AVAILABLE&rellifecycle=&reltype=latest
I don't need to upload cme file to router ? but I can't see any phone firmware file in flash
I'm confused?
As Jaime already said - CME is bundled in IOS. You won't see any firmware in flash except one which you manually upload...but you probably won't need any because 10.5 is pretty actual CME right now...
HTH,
Dragan
HTH,
Dragan
then I should upload phone file manually?
then type a command?
tftp-server flash:SCCP11.7-2-1-0S.loads
Yes you should upload them manually and then put that "tftp-server..." command.
But - most phones have 5-6 files (jar, dsp, apps etc) which are complete firmware and you must put them all on flash plus you must repeat tftp-server command for every file...
BR,
Dragan
HTH,
Dragan
