CME 11.0 and 2921 not registering any phones
markmanogamo
2921 with CME 11.0 LOADED.  2921 HAS An ETHER MODULE IN IT WHERE PHONES ARE SETUP AS ACCESS PORTS WITH VOICE VLAN, router has 2 VLANS, 1 FOR DATA, 1 FOR VOICE, has 2 different DHCVCP POOLS, exactly like a config seen on CCO.
no DHCP  handed out to phones, no CME  source addr.
collab#sh dhcp ser
DHCP server: 172.16.1.1
Leases: 0
Offers: 0 Requests: 0 Acks : 0 Naks: 0
Declines: 0 Releases: 0 Query: 0 Bad: 0
Forcerenews: 0 Failures: 0
DHCP server: 172.16.2.1
Leases: 0
collab#
-----Additional Debug------
*Jul 12 13:49:12.267: DHCP process ID -1 status 0
*Jul 12 13:49:12.267: DHCP Network Discovery is disabled
*Jul 12 13:49:12.267: DHCP NetDiscovery Informs 0 Discovers 0 Period 15
*Jul 12 13:49:12.267: DHCPC HA status is Active
*Jul 12 13:49:12.267: Checkpointing is Not active
Whenever I try to add IP SOURCE-ADDRESS  to telephony-service, it gives this error:
collab(config-telephony)#ip source-address 172.16.1.1
***  Configured ip address does not match any interface in given VRF. Pls configure a valid ip address
Even tried using loopback int IP adddr, says invalid , why ?
The CME  is not allowing an IP source address, and the 7962 and 9951 are not getting an IP addr from the  DHCP pool, is one causing the other, or unrelated ?
what can i try ?
collab#sh arp   (* shows valid IP addr in arp table )
Internet 172.16.1.1 - e05f.b995.3420 ARPA GigabitEthernet0/0.10
Internet 172.16.2.1 - e05f.b995.3420 ARPA GigabitEthernet0/0.100
Internet 172.16.3.1 - e05f.b995.3421 ARPA GigabitEthernet0/1.100
Internet 172.16.4.1 - e05f.b995.3421 ARPA GigabitEthernet0/1.10
SHOW IP INT BRIEF ( shows valid IP addr  used )
GigabitEthernet0/0 unassigned YES NVRAM up up
GigabitEthernet0/0.10 172.16.1.1 YES NVRAM up up
GigabitEthernet0/0.100 172.16.2.1 YES NVRAM up up
GigabitEthernet0/1 unassigned YES NVRAM up up
GigabitEthernet0/1.10 172.16.4.1 YES manual up up
GigabitEthernet0/1.100 172.16.3.1 YES manual up up
FastEthernet0/3/5 unassigned YES unset up up
FastEthernet0/3/6 unassigned YES unset up up
Loopback1 172.16.5.1 YES NVRAM up up
If I try a different IP addr, it takes it but shows a PARSER-ERROR.
partial config
boot-start-marker
boot system flash1:c2900-universalk9-mz.SPA.156-2.T3.bin
boot-end-marker
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.2.1 172.16.2.9
ip dhcp excluded-address 172.16.1.1 172.16.1.9
ip dhcp pool DATA_SCOPE
network 172.16.2.0 255.255.255.0
default-router 172.16.2.1
dns-server 4.2.2.2
ip dhcp pool VOICE_SCOPE
network 172.16.1.0 255.255.255.0
default-router 172.16.1.1
option 150 ip 172.16.1.1
no ip domain lookup
ip dhcp-server 172.16.1.1
ip dhcp-server 172.16.2.1
ip dhcp-client network-discovery informs 1 discovers 1 period 3
voice service voip
ip address trusted list
ipv4 192.168.30.1
ipv4 172.16.1.1
mode border-element license capacity 200
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
registrar server expires max 600 min 60
voice register global
mode cme
source-address 172.16.1.1 port 2000
max-dn 100
max-pool 5
load 9951 sip9951.9-4-2SR4-1.loads
authenticate register
authenticate realm all
voicemail 600
create profile sync 0010844474287101
voice register dn 1
number 3034
call-forward b2bua busy 600
call-forward b2bua noan 600 timeout 10
name Mark
mwi
voice register template 10
voice register pool 1
id mac 3462.88DB.18B5
type 9951
number 1 dn 1
username cisco password cisco
description mark
codec g711ulaw
no vad
interface Loopback1  - TREID USING THIS IP ADDRESS FOR CME ALSO - ERROR - INVALID.
ip address 172.16.5.1 255.255.255.0
interface GigabitEthernet0/0.10
description ROUTER INTERFACE FOR VOICE VLAN
encapsulation dot1Q 10
ip address 172.16.1.1 255.255.255.0
ip helper-address 172.16.2.1
interface GigabitEthernet0/0.100
description ROUTER INTERFACE FOR DATA VLAN
encapsulation dot1Q 100
ip address 172.16.2.1 255.255.255.0
**  BACK TO BACK WITH GIG E 0/1.10  AND GIG E 0/1.100  SO INT IS UP/UP
interface FastEthernet0/3/5
description 9951 SIP PHONE
switchport access vlan 100
switchport voice vlan 10
no ip address
spanning-tree portfast
interface FastEthernet0/3/6
description 7962 SCCP PHONE
no ip address
i
interface Vlan1
no ip address
shutdown
ip default-gateway 172.16.2.1
ip default-network 172.16.2.1
tftp-server flash0:/cme/cme-2/apps42.9-3-1TH2-5.sbn alias apps42.9-3-1TH2-5.sbn
tftp-server flash0:/cme/CME-2/dsp42.9-3-1TH2-5.sbn alias dsp42.9-3-1TH2-5.sbn
tftp-server flash0:/cme/CME-2/SCCP42.9-3-1-1S.loads alias SCCP42.9-3-1-1S.loads
tftp-server flash0:cme/cme-2/jar42sccp.9-3-1TH2-5.sbn alias jar42sccp.9-3-1TH2-5.sbn
tftp-server flash0:/cme/CME-2/cmterm-9951.9-4-2SR4-1.k3.cop.sgn alias cmterm-9951.9-4-2SR4-1.k3.cop.sgn
tftp-server flash0:/cme/CME-2/cnu42.9-3-1TH2-5.sbn alias cnu42.9-3-1TH2-5.sbn
tftp-server flash0:/cme/CME-2/term62.default.loads alias term62.default.loads
tftp-server flash0:/cme/cme-2/sip9951.9-4-2SR4-1.loads alias sip9951.9-4-2SR4-1.loads
telephony-service
NO IP SOURCE ADDRESS ( UNKNOWN) -------
conference transfer-pattern
max-ephones 24
max-dn 48
load 7962 SCCP42.9-3-1-1S.loads
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 11 dual-line
number 1001
name Marko
ephone 1
mac-address F0B2.E58E.87ED
type 7962
button 1:11
10 Replies 10
Rajan
Hi Mark,
As per the below link, "All SCCP phones in Cisco Unified CME must register through the global voice VRF and must be added to the VRF group on the global voice VRF only."
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmevrf.html
It seems like an issue with VRF configuration. Could you check and confirm whether you are adhering to this and other limitations mentioned for CME with VRF config in the above link.
Rajan
Please rate all useful posts by clicking the star below and mark solutions as accepted wherever applicable
***  Configured ip address does not match any interface in given VRF. Pls configure a valid ip address. Do you have any VRF configured on this router ?
Can you share your complete config.
Response Signature
I( do not have VRF  configured at first, but after that error, I added a dummy VRF calleed CME  just for grins, but it had no effect.  why is CME  even looking for a VRF if there is none ?
i pasted in mostly the entire config, except for trivial unrelated config.
TRIED adding a vrf = CME, and thne use vrf config, and still get that error:
MES-collab#conf t
Enter configuration commands, one per line. End with CNTL/Z.
MES-collab(config)#telep
MES-collab(config)#telephony-service
MES-collab(config-telephony)#group ?
<1-5> group tag
MES-collab(config-telephony)#group 1 ?
vrf define vrfname for group
<cr>
MES-collab(config-telephony)#group 1 vrf CME
VRF "CME" does not exists.
MES-collab(config-telephony)#ip source-address 172.16.5.1
MES-collab(config-telephony)#ip source-address 172.16.1.1
MES-collab(config-telephony)#END
MES-collab#SH
*Jul 14 14:41:08.271: %SYS-5-CONFIG_I: Configured from console by console VRF
Name Default RD Protocols Interfaces
CME <not set>
NOtice i have a CME  config for SIP PHONE, in voice global, and also the standrd SCCP CME config in telephony-service,  is that allowed to run  CME for SCCP AND FOR SIP  in same CME ROUTER ?
Never configured a CME with  VRF. I have sites running CME  without  no issues. if you need VRF follow below guide.
Response Signature
I have never needed a VRF in a CME router. So i did not configure it and it is not needed.
The question this whole time is about what that error message means and why the router will not accept an ip address for the source address for cme? I have tried some debugs and do not see phones attempting to send a DHCP request, and i don't know if that's related to the cme router not having an ip address either.
I need some suggestions and alternatives to try. I wondered if it was the Fast E subinterfaces as the CME IP router, but the error occurs when i use the loopback IP address also.
The ip addresses in the router are clearly defined and seen in the mac table and the ARP table. There is no good explanation for why this router is acting this way with that error message.
I have a customer site who use sub interface for CME. Remove the VRF, reload the router and try.
Response Signature
removed all VRF config,  reload, same problem,  invalid IP address.
