CME 2911 DEBUG VOICE CCAPI INOUT ANI=EMPTY CODE ERROR=28
fdamian01
hi
  I'm setting the integration of a Cisco 2911 and Avaya, Cisco calls to Avaya works
Incoming calls Avaya cisco not working
Stage:
Avaya extensions were created 4880,4881,4882
PSTN DID number 12345 reaches an extension Avaya 4889
89901 group receives a call distributes extensions in 4880,4881,4882
Sequence:
PSTN-AVAYA-CISCO
I have FXO ports on the Cisco and Avaya FXS
I have the following configuration
voice translation-rule 2   (89901 group convert it to the next extension of the operator (800)
rule 1 /89901/ /800/
voice translation-profile DID2
translate called 2
configure my dial-peer with the corresponding ports
dial-peer voice 503 pots
description DIDs Avaya to Cisco Unified Communicatios Manager Express
translation-profile incoming DID2
destination-pattern 800
incoming called-number 800
direct-inward-dial
port 0/1/3
dial-peer voice 507 pots
direct-inward-dial
port 0/2/3
My logic is well ??
my setup right?
http://www.cisco.com/c/en/us/td/docs/ios/voice/monitor/configuration/guide/12_4/vt_12_4_book/vt_ccodes_debug.html
which means exactly the error 28?
It means that the group does not reach me ??
apply debug voice ccapi inout
the source is empty
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
104319: *Jan 25 20:41:11.879 Mexico: //-1/188F7F4684E0/CCAPI/cc_api_call_setup_ind_common:
Interface=0x223BF8D0, Call Info(
Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Incoming Dial-peer=507, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
104320: *Jan 25 20:41:11.879 Mexico: //-1/188F7F4684E0/CCAPI/ccCheckClipClir:
In: Calling Number=800(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
104321: *Jan 25 20:41:11.879 Mexico: //-1/188F7F4684E0/CCAPI/ccCheckClipClir:
Out: Calling Number=800(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
104322: *Jan 25 20:41:11.879 Mexico: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
104323: *Jan 25 20:41:11.879 Mexico: :cc_get_feature_vsa malloc success
104324: *Jan 25 20:41:11.879 Mexico: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
104325: *Jan 25 20:41:11.879 Mexico: cc_get_feature_vsa count is 1
104326: *Jan 25 20:41:11.879 Mexico: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
104327: *Jan 25 20:41:11.879 Mexico: :FEATURE_VSA attributes are: feature_name:0,feature_time:1010532864,feature_id:5460
104328: *Jan 25 20:41:11.879 Mexico: //6633/188F7F4684E0/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=800(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
104329: *Jan 25 20:41:11.879 Mexico: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
104330: *Jan 25 20:41:11.879 Mexico: :Inside cc_build_feature_vsa
104331: *Jan 25 20:41:11.879 Mexico: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
104332: *Jan 25 20:41:11.879 Mexico: feature call basic
104333: *Jan 25 20:41:11.879 Mexico: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
104334: *Jan 25 20:41:11.879 Mexico: cc_build_feature_vsa attr is fn:TWC,ft:01/25/2016 20:41:11.879,cgn:800,cdn:,frs:0,fid:5460,fcid:188F7F46C30D11E584E0F1D02AE27486,legID:19E9
104335: *Jan 25 20:41:11.879 Mexico: //6633/188F7F4684E0/CCAPI/cc_process_call_setup_ind:
Event=0x40D2A440
104336: *Jan 25 20:41:11.879 Mexico: //6633/188F7F4684E0/CCAPI/ccCallSetContext:
Context=0x3ADAFC38
104337: *Jan 25 20:41:11.879 Mexico: //6633/188F7F4684E0/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 6633 with tag 507 to app "_ManagedAppProcess_Default"
104338: *Jan 25 20:41:11.883 Mexico: //6633/188F7F4684E0/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
104339: *Jan 25 20:41:11.883 Mexico: //6633/188F7F4684E0/CCAPI/ccCallDisconnect:
Cause Value=28, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
104340: *Jan 25 20:41:11.883 Mexico: //6633/188F7F4684E0/CCAPI/ccCallDisconnect:
Cause Value=28, Call Entry(Responsed=TRUE, Cause Value=28)
104341: *Jan 25 20:41:11.883 Mexico: //6633/188F7F4684E0/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
104342: *Jan 25 20:41:13.883 Mexico: //6633/188F7F4684E0/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x223BF8D0, Tag=0x0, Call Id=6633,
Call Entry(Disconnect Cause=28, Voice Class Cause Code=0, Retry Count=0)
104343: *Jan 25 20:41:13.883 Mexico: //6633/188F7F4684E0/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
104344: *Jan 25 20:41:13.883 Mexico: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
104345: *Jan 25 20:41:13.883 Mexico: :cc_free_feature_vsa freeing 3C3B81F8
104346: *Jan 25 20:41:13.883 Mexico: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
104347: *Jan 25 20:41:13.883 Mexico: vsacount in free is 0
104348: *Jan 25 20:42:01.495 Mexico: //-1/3622E91A84E4/CCAPI/cc_api_display_ie_subfields:
attached sh run and sh loggin
Regards.
destination-pattern <dialed number which you are dialing>=====>
incoming called-number .
direct-inward-dial
port 0/2/3
and on voice port add connection plar with destined
voice-port 0/2/3
connection plar <the number which is being sent from Avaya>
make this change and re-collect the same debugs
Br, Nadeem Please rate all useful post.
5 Replies 5
Nadeem Ahmed
direct-inward-dial
port 0/1/3
direct-inward-dial
port 0/2/3
why you are having multiple dial-peer for same destined number also no need for incoming dial-peer 800 just make it  dot (.) . looks it matching 507 dial-peer with ANI and again re-routing with 503 dial-peer . just make one dial-peer with called number as destined number and test call.
this time call debug vpm signal and debug voice vtsp all along ccapi
Br,
Nadeem Ahmed
How to interpret this debug.
different scenarios
translate called 2
voice-port 0/2/3
supervisory disconnect dualtone pre-connect
supervisory answer dualtone
no battery-reversal
input gain 8
echo-cancel coverage 32
cptone MX
timeouts interdigit 5
timeouts call-disconnect 3
timeouts wait-release 2
caller-id enable
no dial-peer voice 507 pots
destination-pattern .
direct-inward-dial
port 0/2/3
106033: *Jan 25 23:14:18.219 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x0 timestamp=61487 systime=12929896
106034: *Jan 25 23:14:18.219 Mexico: htsp_process_event: [0/2/3, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
106035: *Jan 25 23:14:18.219 Mexico: htsp_timer - 125 msec
106036: *Jan 25 23:14:18.347 Mexico: htsp_process_event: [0/2/3, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
106037: *Jan 25 23:14:18.347 Mexico: htsp_timer - 10000 msec
106038: *Jan 25 23:14:18.347 Mexico: htsp_timer3 - 5600 msec
106039: *Jan 25 23:14:18.347 Mexico: [0/2/3] htsp_start_caller_id_rx:Mode BELLCORE. Alerting 0x1
106040: *Jan 25 23:14:18.347 Mexico: htsp_start_caller_id_rx create dsp_stream_manager
106041: *Jan 25 23:14:18.347 Mexico: [0/2/3] htsp_dsm_create_success returns 1
106042: *Jan 25 23:14:19.275 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x4 timestamp=62541 systime=12930002
106043: *Jan 25 23:14:19.275 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_DSP_SIG_0100]
106044: *Jan 25 23:14:19.275 Mexico: fxols_ringing_not
106045: *Jan 25 23:14:19.275 Mexico: htsp_timer_stop
106046: *Jan 25 23:14:19.275 Mexico: htsp_timer - 10000 msec
106047: *Jan 25 23:14:23.223 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x0 timestamp=951 systime=12930397
106048: *Jan 25 23:14:23.223 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_DSP_SIG_0000]
106049: *Jan 25 23:14:23.947 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_HTSP_EVENT_TIMER3]fxols_snoop_clid_stop
106050: *Jan 25 23:14:23.947 Mexico: htsp_timer_stop3
106051: *Jan 25 23:14:24.275 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x4 timestamp=2006 systime=12930502
106052: *Jan 25 23:14:24.275 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_DSP_SIG_0100]
106053: *Jan 25 23:14:24.275 Mexico: fxols_ringing_not
106054: *Jan 25 23:14:24.275 Mexico: htsp_timer_stop
106055: *Jan 25 23:14:24.275 Mexico: htsp_timer_stop3
106056: *Jan 25 23:14:24.275 Mexico: [0/2/3] htsp_stop_caller_id_rx. message length 0htsp_setup_ind
106057: *Jan 25 23:14:24.275 Mexico: [0/2/3] get_fxo_caller_id:Caller ID receive failed. parseCallerIDString:no data.
106058: *Jan 25 23:14:24.275 Mexico: [0/2/3] get_local_station_id calling num= calling name= calling time=01/25 23:14 orig called=
106059: *Jan 25 23:14:24.283 Mexico: [0/2/3] htsp_dsm_close_done
106060: *Jan 25 23:14:24.283 Mexico: htsp_process_event: [0/2/3, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
106061: *Jan 25 23:14:24.283 Mexico: fxols_wait_setup_ack:
106062: *Jan 25 23:14:24.283 Mexico: [0/2/3] set signal state = 0xC timestamp = 0fxols_check_auto_call
106063: *Jan 25 23:14:24.283 Mexico: htsp_process_event: [0/2/3, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
106064: *Jan 25 23:14:24.283 Mexico: htsp_timer - 120000 msec
106065: *Jan 25 23:14:24.287 Mexico: htsp_pre_connect_disconnect, cdb = 3C3B2970 cause = 1C
106066: *Jan 25 23:14:24.287 Mexico: htsp_process_event: [0/2/3, FXOLS_PROCEEDING, E_HTSP_PRE_CONN_DISC]
106067: *Jan 25 23:14:24.611 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x6 timestamp=2337 systime=12930536
106068: *Jan 25 23:14:24.611 Mexico: htsp_process_event: [0/2/3, FXOLS_OFFHOOK, E_DSP_SIG_0110]
106069: *Jan 25 23:14:24.611 Mexico: htsp_timer_stop2
106070: *Jan 25 23:14:26.287 Mexico: htsp_process_event: [0/2/3, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
106071: *Jan 25 23:14:26.287 Mexico: htsp_timer_stop
106072: *Jan 25 23:14:26.287 Mexico: htsp_timer_stop2
106073: *Jan 25 23:14:26.287 Mexico: htsp_timer_stop3
106074: *Jan 25 23:14:26.287 Mexico: [0/2/3] set signal state = 0x4 timestamp = 0
106075: *Jan 25 23:14:26.287 Mexico: htsp_timer - 2000 msec
106076: *Jan 25 23:14:26.559 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x6 timestamp=4288 systime=12930730
106077: *Jan 25 23:14:26.559 Mexico: htsp_process_event: [0/2/3, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
106078: *Jan 25 23:14:28.195 Mexico: %SYS-5-CONFIG_I: Configured from console by Administrator on vty0 (192.168.1.30)
106079: *Jan 25 23:14:28.287 Mexico: htsp_process_event: [0/2/3, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
106080: *Jan 25 23:14:28.291 Mexico: htsp_dsp_message: RESP_SIG_STATUS: state=0x4 timestamp=0 systime=12930904
106081: *Jan 25 23:14:28.291 Mexico: htsp_process_event: [0/2/3, FXOLS_ONHOOK, E_DSP_SIG_0100]
106165: *Jan 25 23:18:38.023 Mexico: //-1/xxxxxxxxxxxx/VTSP:(0/2/3):-1:-1:-1/vtsp_allocate_cdb:
CDB=0x3C3B1830
106166: *Jan 25 23:18:38.023 Mexico: //-1/xxxxxxxxxxxx/VTSP:(0/2/3):-1:-1:-1/vtsp_do_call_setup_ind:
Event=E_TSP_SETUP_IND
Progress Indication=3, CarrierIDCode=, Info Trans Capability=144, Source Carrier ID=, tg_label_flag=0
106167: *Jan 25 23:18:38.023 Mexico: //-1/16E7D02C859B/VTSP:(0/2/3):-1:-1:-1/vtsp_do_normal_call_setup_ind:
106168: *Jan 25 23:18:38.023 Mexico: //-1/16E7D02C859B/VTSP:(0/2/3):-1:-1:-1/vtsp_timer:
Timer Start Time=12955877, Timer Value=180000(ms)
106169: *Jan 25 23:18:38.023 Mexico: //-1/16E7D02C859B/VTSP:(0/2/3):-1:-1:-1/vtsp_do_normal_call_setup_ind:
IC State Machine (ICSM) Added
106170: *Jan 25 23:18:38.023 Mexico: //-1/16E7D02C859B/VTSP:(0/2/3):-1:-1:-1/vtsp_insert_cdb:
106171: *Jan 25 23:18:38.027 Mexico: //-1/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_dsm_opened_cb:
106172: *Jan 25 23:18:38.027 Mexico: //-1/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
[state:S_SETUP_IND_PEND, event:E_VTSP_DSM_OPEN_SUCCESS]
106173: *Jan 25 23:18:38.031 Mexico: //-1/16E7D02C859B/VTSP:(0/2/3):-1:1:1/act_setup_ind_pend_success:
106174: *Jan 25 23:18:38.031 Mexico: //-1/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_realloc_cdb:
CDB=0x3C3B1830
106175: *Jan 25 23:18:38.031 Mexico: //-1/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_indicate_call:
106176: *Jan 25 23:18:38.031 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_insert_cdb:
106177: *Jan 25 23:18:38.031 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_timer:
Timer Start Time=12955878, Timer Value=180000(ms)
106178: *Jan 25 23:18:38.031 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
[state:S_SETUP_INDICATED, event:E_CC_PROCEEDING]
106179: *Jan 25 23:18:38.031 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/act_proceeding:
Progress Indication=0
106180: *Jan 25 23:18:38.031 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_timer_stop:
Timer Stop Time=12955878
106181: *Jan 25 23:18:38.031 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
[state:S_PROCEEDING, event:E_CC_DISCONNECT]
106182: *Jan 25 23:18:38.031 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/act_pre_con_disconnect:
Cause Value=28, Hairpin=FALSE
106183: *Jan 25 23:18:38.031 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_timer_stop:
106184: *Jan 25 23:18:38.031 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_ring_noan_timer_stop:
106185: *Jan 25 23:18:38.031 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/act_pre_con_disconnect:
[Number Unobtainable]-Tone Played In Direction [Network]
106186: *Jan 25 23:18:38.035 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_timer:
Timer Start Time=12955878, Timer Value=2000(ms)
106187: *Jan 25 23:18:38.035 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/act_pre_con_disconnect:
Tone=Number Unobtainable, Tone Timeout=2(s), Progress Indication Sent=0
106188: *Jan 25 23:18:40.035 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
[state:S_WAIT_RELEASE_NC, event:E_TIMER]
106189: *Jan 25 23:18:40.035 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/act_pre_con_disc_rel:
106190: *Jan 25 23:18:40.035 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/act_pre_con_disc_rel:
Cause Value=28
106191: *Jan 25 23:18:40.035 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
[state:S_WAIT_RELEASE_RESP, event:E_TSP_DISCONNECT_CONF]
106192: *Jan 25 23:18:40.035 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/act_wrelease_release:
106193: *Jan 25 23:18:40.035 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_play_busy_timer_stop:
Timer Stop Time=12956078
106194: *Jan 25 23:18:40.035 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_timer_stop:
106195: *Jan 25 23:18:40.035 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_do_call_history:
106196: *Jan 25 23:18:40.035 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_do_call_history:
Coder Rate=-1
106197: *Jan 25 23:18:40.035 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:1:1/vtsp_is_valid_dsm_handle:
DMGR=0x3E58FB78, VTSP CDB=0x3C3B1830
106198: *Jan 25 23:18:40.035 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:-1:-1/vtsp_dsm_closed_cb:
106199: *Jan 25 23:18:40.035 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:-1:-1/vtsp_process_event:
[state:S_CLOSE_DSPRM, event:E_VTSP_DSM_CLOSE_COMPLETE]
106200: *Jan 25 23:18:40.035 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:-1:-1/act_terminate:
106201: *Jan 25 23:18:40.035 Mexico: //6795/16E7D02C859B/VTSP:(0/2/3):-1:-1:-1/vtsp_timer_stop:
106202: *Jan 25 23:18:40.035 Mexico: //-1/16E7D02C859B/VTSP:(0/2/3):-1:-1:-1/vtsp_free_cdb:
CDB=0x3C3B1830
GNP_GATEWAY#
translate called 2
voice-port 0/2/3
no battery-reversal
input gain 8
cptone MX
caller-id enable
direct-inward-dial
port 0/2/3
106329: *Jan 25 23:30:19.459 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x0 timestamp=39715 systime=13026020
106330: *Jan 25 23:30:19.459 Mexico: htsp_process_event: [0/2/3, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
106331: *Jan 25 23:30:19.459 Mexico: htsp_timer - 125 msec
106332: *Jan 25 23:30:19.587 Mexico: htsp_process_event: [0/2/3, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
106333: *Jan 25 23:30:19.587 Mexico: htsp_timer - 10000 msec
106334: *Jan 25 23:30:19.587 Mexico: htsp_timer3 - 5600 msec
106335: *Jan 25 23:30:19.587 Mexico: [0/2/3] htsp_start_caller_id_rx:Mode BELLCORE. Alerting 0x1
106336: *Jan 25 23:30:19.587 Mexico: htsp_start_caller_id_rx create dsp_stream_manager
106337: *Jan 25 23:30:19.587 Mexico: [0/2/3] htsp_dsm_create_success returns 1
106338: *Jan 25 23:30:20.515 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x4 timestamp=40770 systime=13026126
106339: *Jan 25 23:30:20.515 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_DSP_SIG_0100]
106340: *Jan 25 23:30:20.515 Mexico: fxols_ringing_not
106341: *Jan 25 23:30:20.515 Mexico: htsp_timer_stop
106342: *Jan 25 23:30:20.515 Mexico: htsp_timer - 10000 msec
106343: *Jan 25 23:30:24.463 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x0 timestamp=44715 systime=13026521
106344: *Jan 25 23:30:24.463 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_DSP_SIG_0000]
106345: *Jan 25 23:30:25.187 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_HTSP_EVENT_TIMER3]fxols_snoop_clid_stop
106346: *Jan 25 23:30:25.187 Mexico: htsp_timer_stop3
106347: *Jan 25 23:30:25.515 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x4 timestamp=45770 systime=13026626
106348: *Jan 25 23:30:25.527 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_DSP_SIG_0100]
106349: *Jan 25 23:30:25.527 Mexico: fxols_ringing_not
106350: *Jan 25 23:30:25.527 Mexico: htsp_timer_stop
106351: *Jan 25 23:30:25.527 Mexico: htsp_timer_stop3
106352: *Jan 25 23:30:25.527 Mexico: [0/2/3] htsp_stop_caller_id_rx. message length 0htsp_setup_ind
106353: *Jan 25 23:30:25.527 Mexico: [0/2/3] get_fxo_caller_id:Caller ID receive failed. parseCallerIDString:no data.
106354: *Jan 25 23:30:25.527 Mexico: [0/2/3] get_local_station_id calling num= calling name= calling time=01/25 23:30 orig called=
106355: *Jan 25 23:30:25.527 Mexico: //-1/xxxxxxxxxxxx/VTSP:(0/2/3):-1:-1:-1/vtsp_allocate_cdb:
CDB=0x3C3B23B0
106356: *Jan 25 23:30:25.527 Mexico: //-1/xxxxxxxxxxxx/VTSP:(0/2/3):-1:-1:-1/vtsp_do_call_setup_ind:
106357: *Jan 25 23:30:25.527 Mexico: //-1/BC9C57B085B1/VTSP:(0/2/3):-1:-1:-1/vtsp_do_normal_call_setup_ind:
106358: *Jan 25 23:30:25.527 Mexico: //-1/BC9C57B085B1/VTSP:(0/2/3):-1:-1:-1/vtsp_timer:
Timer Start Time=13026627, Timer Value=180000(ms)
106359: *Jan 25 23:30:25.527 Mexico: //-1/BC9C57B085B1/VTSP:(0/2/3):-1:-1:-1/vtsp_do_normal_call_setup_ind:
106360: *Jan 25 23:30:25.527 Mexico: //-1/BC9C57B085B1/VTSP:(0/2/3):-1:-1:-1/vtsp_insert_cdb:
106361: *Jan 25 23:30:25.595 Mexico: //-1/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_dsm_opened_cb:
106362: *Jan 25 23:30:25.595 Mexico: //-1/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
106363: *Jan 25 23:30:25.595 Mexico: //-1/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/act_setup_ind_pend_success:
106364: *Jan 25 23:30:25.595 Mexico: //-1/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_realloc_cdb:
CDB=0x3C3B23B0
106365: *Jan 25 23:30:25.595 Mexico: //-1/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_indicate_call:
106366: *Jan 25 23:30:25.595 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_insert_cdb:
106367: *Jan 25 23:30:25.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_timer:
Timer Start Time=13026634, Timer Value=180000(ms)
106368: *Jan 25 23:30:25.599 Mexico: [0/2/3] htsp_dsm_close_done
106369: *Jan 25 23:30:25.599 Mexico: htsp_process_event: [0/2/3, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
106370: *Jan 25 23:30:25.599 Mexico: fxols_wait_setup_ack:
106371: *Jan 25 23:30:25.599 Mexico: [0/2/3] set signal state = 0xC timestamp = 0fxols_check_auto_call
106372: *Jan 25 23:30:25.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
106373: *Jan 25 23:30:25.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/act_proceeding:
106374: *Jan 25 23:30:25.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_timer_stop:
Timer Stop Time=13026634
106375: *Jan 25 23:30:25.599 Mexico: htsp_process_event: [0/2/3, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
106376: *Jan 25 23:30:25.599 Mexico: htsp_timer - 120000 msec
106377: *Jan 25 23:30:25.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
106378: *Jan 25 23:30:25.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/act_pre_con_disconnect:
106379: *Jan 25 23:30:25.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_timer_stop:
106380: *Jan 25 23:30:25.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_ring_noan_timer_stop:
106381: *Jan 25 23:30:25.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/act_pre_con_disconnect:
106382: *Jan 25 23:30:25.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_timer:
Timer Start Time=13026634, Timer Value=2000(ms)
106383: *Jan 25 23:30:25.599 Mexico: htsp_pre_connect_disconnect, cdb = 3C3B23B0 cause = 1C
106384: *Jan 25 23:30:25.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/act_pre_con_disconnect:
106385: *Jan 25 23:30:25.599 Mexico: htsp_process_event: [0/2/3, FXOLS_PROCEEDING, E_HTSP_PRE_CONN_DISC]
106386: *Jan 25 23:30:25.923 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x6 timestamp=46177 systime=13026667
106387: *Jan 25 23:30:25.923 Mexico: htsp_process_event: [0/2/3, FXOLS_OFFHOOK, E_DSP_SIG_0110]
106388: *Jan 25 23:30:25.923 Mexico: htsp_timer_stop2
106389: *Jan 25 23:30:27.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
106390: *Jan 25 23:30:27.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/act_pre_con_disc_rel:
106391: *Jan 25 23:30:27.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/act_pre_con_disc_rel:
Cause Value=28
106392: *Jan 25 23:30:27.599 Mexico: htsp_process_event: [0/2/3, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
106393: *Jan 25 23:30:27.599 Mexico: htsp_timer_stop
106394: *Jan 25 23:30:27.599 Mexico: htsp_timer_stop2
106395: *Jan 25 23:30:27.599 Mexico: htsp_timer_stop3
106396: *Jan 25 23:30:27.599 Mexico: [0/2/3] set signal state = 0x4 timestamp = 0
106397: *Jan 25 23:30:27.599 Mexico: htsp_timer - 2000 msec
106398: *Jan 25 23:30:27.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
106399: *Jan 25 23:30:27.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/act_wrelease_release:
106400: *Jan 25 23:30:27.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_play_busy_timer_stop:
Timer Stop Time=13026834
106401: *Jan 25 23:30:27.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_timer_stop:
106402: *Jan 25 23:30:27.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_do_call_history:
106403: *Jan 25 23:30:27.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_do_call_history:
Coder Rate=-1
106404: *Jan 25 23:30:27.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:1:1/vtsp_is_valid_dsm_handle:
DMGR=0x42731810, VTSP CDB=0x3C3B23B0
106405: *Jan 25 23:30:27.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:-1:-1/vtsp_dsm_closed_cb:
106406: *Jan 25 23:30:27.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:-1:-1/vtsp_process_event:
106407: *Jan 25 23:30:27.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:-1:-1/act_terminate:
106408: *Jan 25 23:30:27.599 Mexico: //6808/BC9C57B085B1/VTSP:(0/2/3):-1:-1:-1/vtsp_timer_stop:
106409: *Jan 25 23:30:27.599 Mexico: //-1/BC9C57B085B1/VTSP:(0/2/3):-1:-1:-1/vtsp_free_cdb:
CDB=0x3C3B23B0
106410: *Jan 25 23:30:27.871 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x6 timestamp=48125 systime=13026862
106411: *Jan 25 23:30:27.871 Mexico: htsp_process_event: [0/2/3, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
GNP_GATEWAY#
translate called 2
voice-port 0/2/3
no battery-reversal
input gain 8
cptone MX
caller-id enable
incoming called-number 89901
direct-inward-dial
port 0/2/3
106578: *Jan 25 23:34:36.959 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x0 timestamp=35076 systime=13051770
106579: *Jan 25 23:34:36.959 Mexico: htsp_process_event: [0/2/3, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
106580: *Jan 25 23:34:36.959 Mexico: htsp_timer - 125 msec
106581: *Jan 25 23:34:37.087 Mexico: htsp_process_event: [0/2/3, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
106582: *Jan 25 23:34:37.087 Mexico: htsp_timer - 10000 msec
106583: *Jan 25 23:34:37.087 Mexico: htsp_timer3 - 5600 msec
106584: *Jan 25 23:34:37.087 Mexico: [0/2/3] htsp_start_caller_id_rx:Mode BELLCORE. Alerting 0x1
106585: *Jan 25 23:34:37.087 Mexico: htsp_start_caller_id_rx create dsp_stream_manager
106586: *Jan 25 23:34:37.087 Mexico: [0/2/3] htsp_dsm_create_success returns 1
106587: *Jan 25 23:34:38.011 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x4 timestamp=36131 systime=13051876
106588: *Jan 25 23:34:38.011 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_DSP_SIG_0100]
106589: *Jan 25 23:34:38.015 Mexico: fxols_ringing_not
106590: *Jan 25 23:34:38.015 Mexico: htsp_timer_stop
106591: *Jan 25 23:34:38.015 Mexico: htsp_timer - 10000 msec
106592: *Jan 25 23:34:41.959 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x0 timestamp=40076 systime=13052270
106593: *Jan 25 23:34:41.959 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_DSP_SIG_0000]
106594: *Jan 25 23:34:42.687 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_HTSP_EVENT_TIMER3]fxols_snoop_clid_stop
106595: *Jan 25 23:34:42.687 Mexico: htsp_timer_stop3
106596: *Jan 25 23:34:43.015 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x4 timestamp=41131 systime=13052376
106597: *Jan 25 23:34:43.015 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_DSP_SIG_0100]
106598: *Jan 25 23:34:43.015 Mexico: fxols_ringing_not
106599: *Jan 25 23:34:43.015 Mexico: htsp_timer_stop
106600: *Jan 25 23:34:43.015 Mexico: htsp_timer_stop3
106601: *Jan 25 23:34:43.015 Mexico: [0/2/3] htsp_stop_caller_id_rx. message length 0htsp_setup_ind
106602: *Jan 25 23:34:43.015 Mexico: [0/2/3] get_fxo_caller_id:Caller ID receive failed. parseCallerIDString:no data.
106603: *Jan 25 23:34:43.015 Mexico: [0/2/3] get_local_station_id calling num= calling name= calling time=01/25 23:34 orig called=
106604: *Jan 25 23:34:43.015 Mexico: //-1/xxxxxxxxxxxx/VTSP:(0/2/3):-1:-1:-1/vtsp_allocate_cdb:
CDB=0x3C3B2C50
106605: *Jan 25 23:34:43.015 Mexico: //-1/xxxxxxxxxxxx/VTSP:(0/2/3):-1:-1:-1/vtsp_do_call_setup_ind:
106606: *Jan 25 23:34:43.015 Mexico: //-1/5615E56285BD/VTSP:(0/2/3):-1:-1:-1/vtsp_do_normal_call_setup_ind:
106607: *Jan 25 23:34:43.015 Mexico: //-1/5615E56285BD/VTSP:(0/2/3):-1:-1:-1/vtsp_timer:
Timer Start Time=13052376, Timer Value=180000(ms)
106608: *Jan 25 23:34:43.015 Mexico: //-1/5615E56285BD/VTSP:(0/2/3):-1:-1:-1/vtsp_do_normal_call_setup_ind:
106609: *Jan 25 23:34:43.015 Mexico: //-1/5615E56285BD/VTSP:(0/2/3):-1:-1:-1/vtsp_insert_cdb:
106610: *Jan 25 23:34:43.019 Mexico: //-1/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_dsm_opened_cb:
106611: *Jan 25 23:34:43.019 Mexico: //-1/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
106612: *Jan 25 23:34:43.019 Mexico: //-1/5615E56285BD/VTSP:(0/2/3):-1:1:1/act_setup_ind_pend_success:
106613: *Jan 25 23:34:43.019 Mexico: //-1/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_realloc_cdb:
CDB=0x3C3B2C50
106614: *Jan 25 23:34:43.019 Mexico: //-1/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_indicate_call:
106615: *Jan 25 23:34:43.019 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_insert_cdb:
106616: *Jan 25 23:34:43.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_timer:
Timer Start Time=13052377, Timer Value=180000(ms)
106617: *Jan 25 23:34:43.023 Mexico: [0/2/3] htsp_dsm_close_done
106618: *Jan 25 23:34:43.023 Mexico: htsp_process_event: [0/2/3, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
106619: *Jan 25 23:34:43.023 Mexico: fxols_wait_setup_ack:
106620: *Jan 25 23:34:43.023 Mexico: [0/2/3] set signal state = 0xC timestamp = 0fxols_check_auto_call
106621: *Jan 25 23:34:43.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
106622: *Jan 25 23:34:43.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/act_proceeding:
106623: *Jan 25 23:34:43.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_timer_stop:
Timer Stop Time=13052377
106624: *Jan 25 23:34:43.023 Mexico: htsp_process_event: [0/2/3, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
106625: *Jan 25 23:34:43.023 Mexico: htsp_timer - 120000 msec
106626: *Jan 25 23:34:43.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
106627: *Jan 25 23:34:43.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/act_pre_con_disconnect:
106628: *Jan 25 23:34:43.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_timer_stop:
106629: *Jan 25 23:34:43.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_ring_noan_timer_stop:
106630: *Jan 25 23:34:43.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/act_pre_con_disconnect:
106631: *Jan 25 23:34:43.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_timer:
Timer Start Time=13052377, Timer Value=2000(ms)
106632: *Jan 25 23:34:43.023 Mexico: htsp_pre_connect_disconnect, cdb = 3C3B2C50 cause = 1C
106633: *Jan 25 23:34:43.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/act_pre_con_disconnect:
106634: *Jan 25 23:34:43.023 Mexico: htsp_process_event: [0/2/3, FXOLS_PROCEEDING, E_HTSP_PRE_CONN_DISC]
106635: *Jan 25 23:34:43.343 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x6 timestamp=41462 systime=13052409
106636: *Jan 25 23:34:43.343 Mexico: htsp_process_event: [0/2/3, FXOLS_OFFHOOK, E_DSP_SIG_0110]
106637: *Jan 25 23:34:43.343 Mexico: htsp_timer_stop2
106638: *Jan 25 23:34:45.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
106639: *Jan 25 23:34:45.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/act_pre_con_disc_rel:
106640: *Jan 25 23:34:45.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/act_pre_con_disc_rel:
Cause Value=28
106641: *Jan 25 23:34:45.023 Mexico: htsp_process_event: [0/2/3, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
106642: *Jan 25 23:34:45.023 Mexico: htsp_timer_stop
106643: *Jan 25 23:34:45.023 Mexico: htsp_timer_stop2
106644: *Jan 25 23:34:45.023 Mexico: htsp_timer_stop3
106645: *Jan 25 23:34:45.023 Mexico: [0/2/3] set signal state = 0x4 timestamp = 0
106646: *Jan 25 23:34:45.023 Mexico: htsp_timer - 2000 msec
106647: *Jan 25 23:34:45.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
106648: *Jan 25 23:34:45.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/act_wrelease_release:
106649: *Jan 25 23:34:45.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_play_busy_timer_stop:
Timer Stop Time=13052577
106650: *Jan 25 23:34:45.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_timer_stop:
106651: *Jan 25 23:34:45.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_do_call_history:
106652: *Jan 25 23:34:45.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_do_call_history:
Coder Rate=-1
106653: *Jan 25 23:34:45.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:1:1/vtsp_is_valid_dsm_handle:
DMGR=0x3E58FB78, VTSP CDB=0x3C3B2C50
106654: *Jan 25 23:34:45.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:-1:-1/vtsp_dsm_closed_cb:
106655: *Jan 25 23:34:45.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:-1:-1/vtsp_process_event:
106656: *Jan 25 23:34:45.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:-1:-1/act_terminate:
106657: *Jan 25 23:34:45.023 Mexico: //6811/5615E56285BD/VTSP:(0/2/3):-1:-1:-1/vtsp_timer_stop:
106658: *Jan 25 23:34:45.023 Mexico: //-1/5615E56285BD/VTSP:(0/2/3):-1:-1:-1/vtsp_free_cdb:
CDB=0x3C3B2C50
106659: *Jan 25 23:34:45.295 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x6 timestamp=43412 systime=13052604
106660: *Jan 25 23:34:45.295 Mexico: htsp_process_event: [0/2/3, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
GATEWAY#
Regards.
changing the port settings
voice-port 0/2/3
no battery-reversal
input gain 8
cptone MX
caller-id enable
caller-id alerting ring 4
direct-inward-dial
port 0/2/3
107535: *Jan 26 00:13:21.934 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x0 timestamp=826 systime=13284268
107536: *Jan 26 00:13:21.934 Mexico: htsp_process_event: [0/2/3, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
107537: *Jan 26 00:13:21.934 Mexico: htsp_timer - 125 msec
107538: *Jan 26 00:13:22.062 Mexico: htsp_process_event: [0/2/3, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
107539: *Jan 26 00:13:22.062 Mexico: htsp_timer - 10000 msec
107540: *Jan 26 00:13:22.062 Mexico: htsp_timer3 - 5600 msec
107541: *Jan 26 00:13:22.062 Mexico: [0/2/3] htsp_start_caller_id_rx:Mode BELLCORE. Alerting 0x1
107542: *Jan 26 00:13:22.062 Mexico: htsp_start_caller_id_rx create dsp_stream_manager
107543: *Jan 26 00:13:22.062 Mexico: [0/2/3] htsp_dsm_create_success returns 1
107544: *Jan 26 00:13:22.986 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x4 timestamp=1880 systime=13284373
107545: *Jan 26 00:13:22.986 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_DSP_SIG_0100]
107546: *Jan 26 00:13:22.986 Mexico: fxols_ringing_not
107547: *Jan 26 00:13:22.986 Mexico: htsp_timer_stop
107548: *Jan 26 00:13:22.986 Mexico: htsp_timer - 10000 msec
107549: *Jan 26 00:13:26.934 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x0 timestamp=5826 systime=13284768
107550: *Jan 26 00:13:26.934 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_DSP_SIG_0000]
107551: *Jan 26 00:13:27.662 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_HTSP_EVENT_TIMER3]fxols_snoop_clid_stop
107552: *Jan 26 00:13:27.662 Mexico: htsp_timer_stop3
107553: *Jan 26 00:13:27.990 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x4 timestamp=6881 systime=13284874
107554: *Jan 26 00:13:27.990 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_DSP_SIG_0100]
107555: *Jan 26 00:13:27.990 Mexico: fxols_ringing_not
107556: *Jan 26 00:13:27.990 Mexico: htsp_timer_stop
107557: *Jan 26 00:13:27.990 Mexico: htsp_timer - 10000 msec
107558: *Jan 26 00:13:31.934 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x0 timestamp=10826 systime=13285268
107559: *Jan 26 00:13:31.934 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_DSP_SIG_0000]
107560: *Jan 26 00:13:32.990 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x4 timestamp=11880 systime=13285374
107561: *Jan 26 00:13:32.990 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_DSP_SIG_0100]
107562: *Jan 26 00:13:32.990 Mexico: fxols_ringing_not
107563: *Jan 26 00:13:32.990 Mexico: htsp_timer_stop
107564: *Jan 26 00:13:32.990 Mexico: htsp_timer - 10000 msec
107565: *Jan 26 00:13:36.934 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x0 timestamp=15826 systime=13285768
107566: *Jan 26 00:13:36.934 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_DSP_SIG_0000]
107567: *Jan 26 00:13:37.986 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x4 timestamp=16880 systime=13285873
107568: *Jan 26 00:13:37.986 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_DSP_SIG_0100]
107569: *Jan 26 00:13:37.986 Mexico: fxols_ringing_not
107570: *Jan 26 00:13:37.986 Mexico: htsp_timer_stop
107571: *Jan 26 00:13:37.986 Mexico: htsp_timer - 10000 msec
107572: *Jan 26 00:13:41.934 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x0 timestamp=20826 systime=13286268
107573: *Jan 26 00:13:41.934 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_DSP_SIG_0000]
107574: *Jan 26 00:13:42.986 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x4 timestamp=21880 systime=13286373
107575: *Jan 26 00:13:42.990 Mexico: htsp_process_event: [0/2/3, FXOLS_RINGING, E_DSP_SIG_0100]
107576: *Jan 26 00:13:42.990 Mexico: fxols_ringing_not
107577: *Jan 26 00:13:42.990 Mexico: htsp_timer_stop
107578: *Jan 26 00:13:42.990 Mexico: htsp_timer_stop3
107579: *Jan 26 00:13:42.990 Mexico: [0/2/3] htsp_stop_caller_id_rx. message length 0htsp_setup_ind
107580: *Jan 26 00:13:42.990 Mexico: [0/2/3] get_fxo_caller_id:Caller ID receive failed. parseCallerIDString:no data.
107581: *Jan 26 00:13:42.990 Mexico: [0/2/3] get_local_station_id calling num= calling name= calling time=01/26 00:13 orig called=
107582: *Jan 26 00:13:42.990 Mexico: //-1/xxxxxxxxxxxx/VTSP:(0/2/3):-1:-1:-1/vtsp_allocate_cdb:
CDB=0x3C3B20D0
107583: *Jan 26 00:13:42.990 Mexico: //-1/xxxxxxxxxxxx/VTSP:(0/2/3):-1:-1:-1/vtsp_do_call_setup_ind:
107584: *Jan 26 00:13:42.990 Mexico: //-1/C8D1DD468617/VTSP:(0/2/3):-1:-1:-1/vtsp_do_normal_call_setup_ind:
107585: *Jan 26 00:13:42.990 Mexico: //-1/C8D1DD468617/VTSP:(0/2/3):-1:-1:-1/vtsp_timer:
Timer Start Time=13286374, Timer Value=180000(ms)
107586: *Jan 26 00:13:42.990 Mexico: //-1/C8D1DD468617/VTSP:(0/2/3):-1:-1:-1/vtsp_do_normal_call_setup_ind:
107587: *Jan 26 00:13:42.990 Mexico: //-1/C8D1DD468617/VTSP:(0/2/3):-1:-1:-1/vtsp_insert_cdb:
107588: *Jan 26 00:13:42.994 Mexico: //-1/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_dsm_opened_cb:
107589: *Jan 26 00:13:42.994 Mexico: //-1/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
107590: *Jan 26 00:13:42.994 Mexico: //-1/C8D1DD468617/VTSP:(0/2/3):-1:1:1/act_setup_ind_pend_success:
107591: *Jan 26 00:13:42.994 Mexico: //-1/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_realloc_cdb:
CDB=0x3C3B20D0
107592: *Jan 26 00:13:42.994 Mexico: //-1/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_indicate_call:
107593: *Jan 26 00:13:42.994 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_insert_cdb:
107594: *Jan 26 00:13:42.994 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_timer:
107595: *Jan 26 00:13:42.994 Mexico: [0/2/3] htsp_dsm_close_done
107596: *Jan 26 00:13:42.994 Mexico: htsp_process_event: [0/2/3, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
107597: *Jan 26 00:13:42.994 Mexico: fxols_wait_setup_ack:
107598: *Jan 26 00:13:42.994 Mexico: [0/2/3] set signal state = 0xC timestamp = 0fxols_check_auto_call
107599: *Jan 26 00:13:42.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
107600: *Jan 26 00:13:42.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/act_proceeding:
107601: *Jan 26 00:13:42.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_timer_stop:
Timer Stop Time=13286374
107602: *Jan 26 00:13:42.998 Mexico: htsp_process_event: [0/2/3, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
107603: *Jan 26 00:13:42.998 Mexico: htsp_timer - 120000 msec
107604: *Jan 26 00:13:42.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
107605: *Jan 26 00:13:42.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/act_pre_con_disconnect:
107606: *Jan 26 00:13:42.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_timer_stop:
107607: *Jan 26 00:13:42.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_ring_noan_timer_stop:
107608: *Jan 26 00:13:42.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/act_pre_con_disconnect:
107609: *Jan 26 00:13:42.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_timer:
Timer Start Time=13286374, Timer Value=2000(ms)
107610: *Jan 26 00:13:42.998 Mexico: htsp_pre_connect_disconnect, cdb = 3C3B20D0 cause = 1C
107611: *Jan 26 00:13:42.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/act_pre_con_disconnect:
107612: *Jan 26 00:13:42.998 Mexico: htsp_process_event: [0/2/3, FXOLS_PROCEEDING, E_HTSP_PRE_CONN_DISC]
107613: *Jan 26 00:13:43.318 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x6 timestamp=22211 systime=13286406
107614: *Jan 26 00:13:43.318 Mexico: htsp_process_event: [0/2/3, FXOLS_OFFHOOK, E_DSP_SIG_0110]
107615: *Jan 26 00:13:43.318 Mexico: htsp_timer_stop2
107616: *Jan 26 00:13:44.546 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_get_levels:
CALL_ERROR_INFORMATIONAL; DSP Timeout
107617: *Jan 26 00:13:44.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
107618: *Jan 26 00:13:44.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/act_pre_con_disc_rel:
107619: *Jan 26 00:13:44.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/act_pre_con_disc_rel:
Cause Value=28
107620: *Jan 26 00:13:44.998 Mexico: htsp_process_event: [0/2/3, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
107621: *Jan 26 00:13:44.998 Mexico: htsp_timer_stop
107622: *Jan 26 00:13:44.998 Mexico: htsp_timer_stop2
107623: *Jan 26 00:13:44.998 Mexico: htsp_timer_stop3
107624: *Jan 26 00:13:44.998 Mexico: [0/2/3] set signal state = 0x4 timestamp = 0
107625: *Jan 26 00:13:44.998 Mexico: htsp_timer - 2000 msec
107626: *Jan 26 00:13:44.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_process_event:
107627: *Jan 26 00:13:44.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/act_wrelease_release:
107628: *Jan 26 00:13:44.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_play_busy_timer_stop:
Timer Stop Time=13286574
107629: *Jan 26 00:13:44.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_timer_stop:
107630: *Jan 26 00:13:44.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_do_call_history:
107631: *Jan 26 00:13:44.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_do_call_history:
Coder Rate=-1
107632: *Jan 26 00:13:44.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:1:1/vtsp_is_valid_dsm_handle:
DMGR=0x42731810, VTSP CDB=0x3C3B20D0
107633: *Jan 26 00:13:44.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:-1:-1/vtsp_dsm_closed_cb:
107634: *Jan 26 00:13:44.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:-1:-1/vtsp_process_event:
107635: *Jan 26 00:13:44.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:-1:-1/act_terminate:
107636: *Jan 26 00:13:44.998 Mexico: //6874/C8D1DD468617/VTSP:(0/2/3):-1:-1:-1/vtsp_timer_stop:
107637: *Jan 26 00:13:44.998 Mexico: //-1/C8D1DD468617/VTSP:(0/2/3):-1:-1:-1/vtsp_free_cdb:
CDB=0x3C3B20D0
107638: *Jan 26 00:13:45.270 Mexico: htsp_dsp_message: SEND_SIG_STATUS: state=0x6 timestamp=24162 systime=13286602
107639: *Jan 26 00:13:45.270 Mexico: htsp_process_event: [0/2/3, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
107640: *Jan 26 00:13:46.998 Mexico: htsp_process_event: [0/2/3, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
107641: *Jan 26 00:13:46.998 Mexico: htsp_dsp_message: RESP_SIG_STATUS: state=0x4 timestamp=0 systime=13286774
107642: *Jan 26 00:13:46.998 Mexico: htsp_process_event: [0/2/3, FXOLS_ONHOOK, E_DSP_SIG_0100]
107643: *Jan 26 00:14:14.894 Mexico: %VOICE_IEC-3-GW: Application Framework Core: Internal Error (Toll fraud call rejected): IEC=1.1.228.3.31.0 on callID 6875 GUID=F297C8D60B55E66341D278EDB56F6B24
107644: *Jan 26 00:15:28.702 Mexico: %VOICE_IEC-3-GW: Application Framework Core: Internal Error (Toll fraud call rejected): IEC=1.1.228.3.31.0 on callID 6876 GUID=E61D225595983FAA9B50F255AC80FF18
GNP_GATEWAY#
direct-inward-dial
port 0/2/3
voice-port 0/2/3
You are right a connection PLAR longer works.
I did not know that FXO not have any ani is received only in digital trunks.
thanks for the help
Regards.
