CME 4.2 / Exchange 2010 UM / MWI
jpodplesky
I have CME 4.2 and Exchange 2010 Unified Messaging working great, but am lost with MWI. On each of the phones button 1 is the incoming pots line. I have unified messaging configured to pick up this line as a general mailbox. It works fine from both internal and outside callers but no mwi. The second line of each phone is the designated ephone-dn and ephone. I would like to configure MWI to light on either a message from line 1 or line 2. Is this possible and if it is can someone throw me a hint or 3?
Rob Huffman
Hi Jack,
I'm sorry but I can't help with your overall MWI issues, but this is the config to light the MWI for
secondary lines with CME;
In Cisco Unified CME 4.0 and later versions, you can designate a phone line other than the primary line to be associated with the MWI lamp.
Step 1
enable
Example:
Router> enable
Enables privileged EXEC mode.
Enter your password if prompted.
Step 2
configure terminal
Example:
Router# configure terminal
Enters global configuration mode.
Step 3
ephone phone-tag
Example:
Router(config)# ephone 36
Enters ephone configuration mode.
phone-tag Unique sequence number that identifies this ephone during configuration tasks.
Step 4
mwi-line line-number
Example:
Router(config-ephone)# mwi-line 3
Selects a phone line to receive MWI treatment; when a message is waiting for the selected line, the message waiting indicator is activated.
line-number Ephone line number. Range is 1 to 34. Default is 1.
Step 5
end
Example:
Router(config-ephone)# end
Cheers!
Rob
Thanks for the info Rob. That will definately come in handy once I get MWI working. Right now I don't have any MWI activity. So once I find out how to configure lighting the MWI I should be good to go with what you provided
Thanks!
