CME 8.5 with 9951
epasqualotto
Hi all, the ip phone 9951 is marked as supported with CME version 8.5 but anyone have idea how to configure it?
I can't find any docs on the Cisco site.
Enrico.
dksingh
Hello there,
99xx are SIP endpoints and here's a sample config to get it up and working with CUCME....
Pl. see doc ref. below and tweak the config as needed....
voice service voip
allow-connections sip to sip
voice register global
mode cme
source-address X.X.X.X port 5060  !(X.X.X.X is the CME IP)
max-dn 5
max-pool 5
load 9951 sip9951.9-1-1SR1.loads  !<- make sure this matches with the firmware file on flash
authenticate register
authenticate realm all
timezone 13
voicemail 600
tftp-path flash:
create profile
voice register dn  1
number 666
call-forward b2bua busy 600
call-forward b2bua noan 600 timeout 10
name Joe Blo
mwi
voice register pool  1
id mac HHHH.HHHH.HHHH  !<-- Phone's MAC
type 9951
number 1 dn 1
username cisco password cisco
description JoeBlo
codec g711ulaw
no vad
Cisco Unified Communications Manager Express: SIP Implementation Guide
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps4625/products_configuration_example09186a00808f33eb.shtml
DK
6 Replies 6
phooghen
The 9951 is a SIP phone.
You should configure CME for SIP and maybe download the phone TAR file on CCO.
Pierre.
dksingh
Hello there,
voice service voip
mode cme
max-dn 5
max-pool 5
timezone 13
voicemail 600
tftp-path flash:
create profile
voice register dn  1
number 666
name Joe Blo
mwi
type 9951
number 1 dn 1
description JoeBlo
codec g711ulaw
no vad
DK
@DK
You did make me google for the loads command "load 9951 sip9951.9-1-1SR1.loads" regarding the suffix "loads"
·         When   configuring the load command:
-          In Cisco   Unified CME 7.0 and earlier versions, do not include the .sbin or .loads file suffix except for the Cisco ATA and Cisco Unified IP Phone   7905 and 7912.
-          In   Cisco Unified CME 7.0(1) and later versions, use the complete   filename, including the file suffix, when you configure the load command   for phone firmware versions later than version 8-2-2 for all phone types.
·         When   configuring the load command for   IP phones such as the Cisco Unified IP Phone 7906G,   7911G, 7941G, 7941GE, 7961G, 7961GE, 7970G, and 7971G, configure only the filenames that are marked with   an asterisk (*) in the table below.
·         Only SCCP phones can be   configured as agent phones for Unified CCX 5.0 in   Cisco Unified CME 4.2 and later versions. The Cisco VG224 Analog Phone Gateway and analog and SIP phones are   supported as usual in Cisco Unified CME, however, not as Unified CCX agent phones.
·         When   upgrading phone load version, first upgrade phone load 8.0.4 to 8.0.5   followed by phone load 8.0.5 to 8.1.1. Once your phone load version is   upgraded to 8.1.1 you should upgrade it to version 8.1.2.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme85spc.htm.html
Now its all good .
ha! ha! Thx God for Google!
Yeah, I included .loads suffix as 9951 isn't supported until CME 8.5
and I knew u were gonna need it...
One more thing that I shd add is that currently CME does not support
video on 99xx and its planned for future release (8.6 Mar 2011)
Pl. rate/mark thread as answered if your concerns have been addressed.
DK
Ok, now the phone is registered with the CME. What about the expansion module on CME? is supported?
jilfersalam
HI Guys,
I have tried to register 9951 in in CME 8.5, and the phones are unregistered. here is the configuration snippet.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
fax protocol t38 nse version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
sip
  registrar server expires max 3600 min 120
mode cme
source-address 10.1.1.170 port 5060
max-dn 40
max-pool 42
load 9951 sip9951.9-1-1SR1<<>>>
tftf-path flash:
timezone 31
create profile sync 020131905538081A
voice register dn  1
number 8002
pickup-group 40
name User1
shared-line max-calls 6
label user1
id mac 1CAA.07E2.C2DE
type 9951
number 1 dn 1
cor incoming INTERNATIONAL default
presence call-list
dtmf-relay rtp-nte
no vad
tftp-server flash:dkern9951.100609R2-9-1-1SR1.sebn
tftp-server flash:kern9951.9-1-1SR1.sebn
tftp-server flash:rootfs9951.9-1-1SR1.sebn
tftp-server flash:sboot9951.031610R1-9-1-1SR1.sebn
tftp-server flash:skern9951.022809R2-9-1-1SR1.sebn
tftp-server flash:sip9951.9-1-1SR1.loads
When i am Giving the command tftp-path flash:
i get the following error
CME(config-register-global)#tftp-path flash:
%Error deleting flash:/SIPDefault.cnf (File not found)
%Error deleting flash:/syncinfo.xml (File not found)
%Error deleting flash:/softkeyDefault.xml (File not found)
%Error deleting flash:/softkeyDefault_kpml.xml (File not found)
%Error deleting flash:/featurePolicyDefault.xml (File not found)
%Error deleting flash:/SEP1CAA07E2C2DE.cnf.xml (File not found)
These files though i can see in the flash
I am also attaching the show voice register global command. Any ideas why the phones are not registering
