CME 8.6 and 9951 SIP
david.sua
Hi all!
I am trying to configure the 9951 cisco phone. I know that is supported only in SIP.
I am following this discussion
https://supportforums.cisco.com/thread/2063506
but i cant set the command "load 9951 ...." because is not present for this model.
Router(config-register-global)#load ?
  3911       Select the firmware load file for 3911
  3951       Select the firmware load file for 3951
  7905       Select the firmware load file for 7905
  7906       Select the firmware load file for TNP 7906 phone
  7911       Select the firmware load file for TNP 7911 phone
  7912       Select the firmware load file for 7912
  7941       Select the firmware load file for TNP 7941 phones
  7941GE     Select the firmware load file for TNP 7941GE phones
  7942       Select the firmware load file for TNP 7942 phones
  7945       Select the firmware load file for TNP 7945 phones
  7960-7940  Select the firmware load file for Telecaster 7960 & 7940 phones
  7961       Select the firmware load file for TNP 7961 phones
  7961GE     Select the firmware load file for TNP 7961GE phones
  7962       Select the firmware load file for TNP 7962 phones
  7965       Select the firmware load file for TNP 7965 phones
  7970       Select the firmware load file for TNP 7970 phones
  7971       Select the firmware load file for TNP 7971 phones
  7975       Select the firmware load file for TNP 7975 phones
  ATA        Select the firmware load file for ATA
I have a CISCO2921/K9 with IOS c2900-universalk9-mz.SPA.151-2.T2.bin
Are there a solution without upgrade IOS? I don´t have a service contract...
Thanks in advance
gossa1973
Hi David,
  You are trying to load firmware in telephony-service section, this section is intended for global setings for phones with SCCP protocol, if you want to load firmware for phones based on SIP protocol you must use another section voice register global , for example, use this CLI commands
configure terminal
load 9971 sip9971.9-2-1.loads
before you use this CLI command you need to copy firmware files to TFTP server and register firmware files with TFTP server.
tftp-server flash:/phones/9971/kern9971.9-2-1.sebn alias kern9971.9-2-1.sebn
tftp-server flash:/phones/9971/rootfs9971.9-2-1.sebn alias rootfs9971.9-2-1.sebn
tftp-server flash:/phones/9971/skern9971.022809R2-9-2-1.sebn alias skern9971.022809R2-9-2-1.sebn
tftp-server flash:/phones/9971/sboot9971.031610R1-9-2-1.sebn alias sboot9971.031610R1-9-2-1.sebn
tftp-server flash:/phones/9971/sip9971.9-2-1.loads alias sip9971.9-2-1.loads
but load command is not necessay for configuring 9971 phone, phone already have firmware and work correctly
if you want to register 9971 to your CME
you need first enable SIP in your infrastructure
use next commands for that
voice service voip
     allow-connections h323 to sip
     allow-connections sip to h323
     allow-connections sip to sip
     supplementary-service h450.12
     h323
     sip
          registrar server
then you must configure global setings for SIP phones
     mode cme
     source-address YOUR ROUTER IP ADDRESS port 5060
     max-dn 12
     max-pool 12
     authenticate register
     timezone 28
     time-format 24
     date-format D/M/Y
     tftp-path flash:
     camera
     video
then you add DN for SIP phone
here is example
voice register dn  1
      number 101
      name Jonh Smith
      label 101 JOHN SMITH
the you need to register your phone to the system with next few commands
voice register pool  1
id mac aaaa.bbbb.cccc  <- here you enter MAC of your phone
type 9971
number 1 dn 1
dtmf-relay sip-notify
username xxxx password yyyyy
camera
and that is not all
phone ask tru TFTP your CME for configuration files SEPaaaa.bbbb.cccc.cfg.xml , so you need to force system to create profiles for SIP phones
enter next few commands
conf term
no cre pro  <- this commad delete old profiles
cre pro  <- this command create profile=configuration files
you can debug tftp server to see if phone downloaded configuration with command
debug tftp events
and this is in short how to register 9971 to CME
do not forget to rate this replay
allan.paula
I had the same problem with the 6911/6941 I updated to a C2900-Ios-universalk9 mz.SPA.151 4.M.bin appeared and all loads.
Checks if this can help you.
Allan de Paula
Thank you Allan.
I hate the new contract policy of cisco... I bought a NEW router that is provided with a old IOS version and if I want to upgrade it because the phones that i bought is not present in this old IOS I need to buy a Smarnet... frustrating
gossa1973
Hi David,
configure terminal
voice service voip
     h323
     sip
          registrar server
     mode cme
     max-dn 12
     max-pool 12
     timezone 28
     time-format 24
     date-format D/M/Y
     tftp-path flash:
     camera
     video
here is example
voice register dn  1
      number 101
      name Jonh Smith
type 9971
number 1 dn 1
camera
and that is not all
conf term
debug tftp events
Thank you gossa, your info was very useful!
Only one appointment, I think that upgrade IOS is mandatory because until y set type 9951 under voice register pool the CME don't create the xml config file for the phone.
Thank you again.
Regards.
