CME 8.6 GUI missing
raid.sameea
Hi Every Body
I have CME 8.6 and I tried to enable GUI - Web to use it in configuring the CME but unfortunately it seems that the GUI folder is missing or not existing when i run "sh flash" command. Can you please help me in downloading and installing the gui folder to my CME 8.6.
Thank you
2 Accepted Solutions
George Sotiropoulos
I would suggest the same post with the one Vaijanath did but also, upgrade your CME to a newer version.
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Dear Vaijanath
The link is helpful, but the problem is the GUI directory is missing!!!
Vaijanath Sonvane
Please follow below post for step by step procedure:
https://community.cisco.com/t5/collaboration-voice-and-video/enabling-gui-on-cme-step-by-step-procedure-configuration/ta-p/3153662
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Dear Vaijanath
George Sotiropoulos
George
