CME 8.6 with Cisco Conf 7937G Registration Issue, phone keep on rebooting
Hello All,
We have CME 8.6 (c2900-universalk9-mz.SPA.151-4.M1.bin)  and Cisco conference station 7937G with firmware (load 7937 apps37sccp.1-4-4-0.bin). But the phone not getting registered with CME and phone keep on rebooting. Please advise your input on this issue..
Thanks & Regards,
Naveen.S
6 Replies 6
ronpatel
Level 8
Level 8
HI
It would be good to send us configuration.
Are you using any localization.
Ronak Patel
rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak,
Thanks a lot your reply, i have attached the CME configuration file and we are not using any localization ( its default english)
Thanks & Regards,
Naveen.S
hi Naveen.S
We have exactly the same problem, CME 8.6, IOS 15.1(4)M4, 7937G apps37sccp.1-4-4-0,
7937 keeps rebooting, I think this might be caused by some bug, did you find out how to solve this problem?
Brad
Hi Brad,
the issue fixed upgarding the phone firmwares...
Thanks & Regards,
Naveen.S
hi Naveen.S
Thanks  for the reply, but as I know  apps37sccp.1-4-4-0 is already  the latest firmware, did you mean upgrade the CME ?
Brad
Hi, Excuse me, but how do you resolve this issue?
