CME 9.1 locale and fw configuration problem with 7975G
adrian.juan
Hi all,
I have a C5921-K9 with CME 9.1 and two 7975G phones in a LAN. I am trying to configure the Spanish locale and I am not able to do it. I followed the steps in http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmelocal.html under "Using the Locale Installer in Cisco Unified CME 9.0 and Later Versions". The first thing I couldn't do was the cnf-file location flash: command, I always receive an "Invalid file system option" message, so I cannot store the files in flash. I have no NTP server, nor Internet access.
Could someone give me a hand? Has someone found this problem before?
Thanks in advance,
Adrián
12 Replies 12
adrian.juan
Anyone who can help me?
adrian.juan
Please, any help?
Thanks!!
Brian Meade
Level 7
Level 7
Are you actually using a 5921 or are you using a 2921?  If 5921, it may have different storage options such as disk0:.  You'll need to look at the file system available to you on that platform.
Hi Brian,
Thanks for your reply laugh. It's actually a Mildef equipment with an embedded c5921-K9.
The options that it gives are flash0: and tftp, but it doesn't accept the command when trying to select the flash0: file system.
Any other clue?
Thanks again,
Adrián
What does "show file systems" show for available devices?
here are several outputs and responses:
R#show file systems
File Systems:
       Size(b)       Free(b)      Type  Flags  Prefixes
             -             -    opaque     rw   archive:
             -             -    opaque     rw   system:
        262144        254314     nvram     rw   nvram:
             -             -    opaque     rw   tmpsys:
   49545560064   48390352896      disk     rw   flash0:
*  49545560064   48390352896      disk     rw   unix:
             -             -   network     rw   snmp:
             -             -    opaque     rw   null:
             -             -   network     rw   tftp:
             -             -    opaque     ro   xmodem:
             -             -    opaque     ro   ymodem:
             -             -    opaque     wo   syslog:
             -             -   network     rw   rcp:
             -             -   network     rw   pram:
             -             -   network     rw   ftp:
             -             -   network     rw   http:
             -             -   network     rw   scp:
             -             -    opaque     ro   tar:
             -             -   network     rw   https:
             -             -    opaque     ro   cns:
R(config-telephony)#cnf-file location ?
  TFTP    Store CNF files to external TFTP server
  flash:  Store CNF files to flash:
R(config-telephony)#cnf-file location flash0:
% Invalid input detected at '^' marker.
It looks to me like it's possibly a bug or TFTP might be your only option.  Can you run a TFTP server on that Mildef box?
Hi Brian,
Are you saying as an external TFTP server? I don't know for sure, I will have to try because it is a CentOS.
I forgot to mention before, but the CLI doesn't accept this command:
Router(config-register-global)#user-locale 2 DE load CME-locale-de_DE-German-8.6.3.0.tar
It only accepts:
Do you think this could be a bug? If so, what could I do to fix it?
Adrián
I can't deploy a TFTP server on this device. Any other suggestion or do you know how to fix this bug?
Thanks for your cooperation,
Adrián
"flash:" and "flash0:" are the same its point to the same flash , if you had flash1: then it will be a different flash.
Use flash: on telephony service it will work.
R(config-telephony)#cnf-file location flash:
Manish
Hi Manish,
It doesn't work either, I receive an "Invalid file system option" message.
Thanks!
Adrián
adrian.juan
R#show file systems
File Systems:
             -             -    opaque     rw   null:
             -             -   network     rw   rcp:
             -             -   network     rw   ftp:
             -             -   network     rw   scp:
             -             -    opaque     ro   tar:
             -             -    opaque     ro   cns:
