CME and FXO configuration
Hi how can i tie a voice port to an ephone-dn with a trunk-group PSTN configured i mean i only have one Dial peer voice ?
11 Replies 11
allan.thomas
Level 8
Level 8
Essentially you should have a POTS DialPeer configured, on the DP you can also apply a translation profile in order to transform the incoming digits if at all necessary.
If you have a vic2-4fxo module, you can configure them as trunk-group, and apply these to your outgoing DP.
Depending on the incoming number on the FXO voice-port you could specify an OPX number and configure a DP with session target to the CCM.
voice-port 0/0/0
trunk-group VIC2-4FXO
connection plar opx 1XXX (DN)
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
dial-peer voice 100 pots
description *** PSTN Dial Peer ***
trunkgroup VIC2-4FXO
destination-pattern 9T
incoming called-number .
dial-peer voice 101 voip
description CallManager Desination Pattern
destination-pattern 1...
session target ipv4:192.168.1.1
dtmf-relay h245-alphanumeric
no vad
Or in your example configure the ephone-dn with the called number, if telco is send four digits say 1234 then this would be your number for your ephone-dn
ephone-dn 1 dual-line
number 1XXX
Allan.
Hey thanks for your post but let me rephrase my purpose with an example:
I have configured 3 voice ports to PSTN connection with trunk-group cmd and as a common destination pattern 9T and i want for the ephone-dn 1 when he dial a PSTN number (he compose 9+ external phone number) he will use the first port of the FXO card, and for another one he will use the second port of the FXO card.
One solution which comes to mind is using different trunk access codes for a given User or DN.
Here the translation profile is applied to the ephone-template this ensure that when that particular user say User1 dials 9+ then this will transformed to 91 and then user the appropriate trunk.
voice-port 0/0/0
trunk-group User1
voice-port 0/0/1
trunk-group User2
voice-port 0/0/2
trunk-group User3
voice translation-rule 1
rule 1 /^9/ /91/
voice translation-rule 2
rule 1 /^9/ /92/
voice translation-rule 3
rule 1 /^9/ /93/
voice translation-profile User1
translate called 1
voice translation-profile User2
translate called 2
voice translation-profile User3
translate called 3
ephone-dn-template 1
translation-profile outgoing User1
ephone-dn-template 2
translation-profile outgoing User2
ephone-dn-template 3
translation-profile outgoing User3
ephone-dn 1
number 1...
ephone-dn 2
number 1...
ephone-dn 3
number 1...
dial-peer voice 1001 pots
destination-pattern 91.T
trunkgroup User1
dial-peer voice 1002 pots
destination-pattern 92.T
trunkgroup User2
dial-peer voice 1003 pots
destination-pattern 93.T
trunkgroup User3
Allan.
HI Mr Allan, i have tried the same configuration that you proposed but it doesn't work, it seems like my translation profile doesn't work with my ephone but when i test my translation rules under my router with the cmd:
test voice tranlation-rule 1 600
it's ok he convert it to 9100 but when i type under my phone =6+telephone number i hear a kind of disconnect tone or a busy tone.thanks for helping me out
You will find in attach a copy of my confi
I suspect your POTS dial-peers are overlapping as you have a destination-pattern of 9T.
If I understand correctly the user associated with ephone-dn 1 dials 6........, this should then be translated to 91........ and then subsequently routed out the respective trunk port for 91.
Can you debug voice ccapi inout and post the output when an outgoing call is made by this user.
You can also test by running 'show dialplan number 9100.......'
Allan.
thanks for all i really appreciate your help, here is a copy of the result of debug command.
Kindly
Kindly
Hello, as mentioned in my post above, the standard solution for this does not require any translation, just the trunk command.
this is done with trunk command under ephone-dn. I prepends the digits you set, then configure a pots DP to send the call on the port you want:
ephone-dn 10
trunk AA
dial-peer voice 10 pots
destination-pattern ^AA....T
port x/y
This example use special DTMF digits so the port cannot be seized from by other ephones.
Thanks but sorry i can't understood this method like what did you mean by AA and how can i configure a destination-pattern like 9T to acces to the FXO port ...
thanks for providing me more details
What is being proposed is a simpler approach where you can specify the trunk directly on the ephone-dn which is specifically tied to a pots dial-peer.
ephone-dn 10
trunk 91
ephone-dn 11
trunk 92
destination-pattern ^91....T
port x/y
dial-peer voice 11 pots
destination-pattern ^92....T
port x/y
Allan.
