CME and one FXO line Question
Yazen Alaa
Dear All
I have CME  with one analog line(FXO) , and one ATA (FAX) with one cisco phone , my question is :
can i configure this scenario? :
incoming call >>>>go to cisco phone and after 5 rings go to>>>>> fax(ATA)  . and additional i want  fax receive and send directly through the same analog line .
how  the configuration it will be ?
i heard that this feature is not available in CME , is it right ?
thanks and regards
paolo bevilacqua
Yes, that can be done.
bendatcrox
You have 2 ways you can achieve this-
Option 1 -
Connection plar on the FXO port to the extension, the. On the extension set a call-forward to answer to the FXS/ATA after 5 rings
Option 2 -
Create a hunt group.
Send me your config with clearly labeled phones and I will send it back to you.
Thanks.
