CME: assign extension to sip trunk
JonnyNet
Instead of using a prefix to use a separate sip trunk, I would like an IP phone to use a separate sip trunk for it's 2nd line.
So I have configured a 2nd line on an IP Phone to use extention 96:
ephone 1
 mac-address ****
 name ***
 button 2:96
ephone-dn 96 dual-line
 number 432
and then I would like this extention (with number ending in 432) to always use a certain SIP server.
I believe I need a dial-peer to achieve this, similar to:
dial-peer voice 432 voip
 destination-pattern ???
 voice-class codec 1
 voice-class sip dtmf-relay force rtp-nte
 session protocol sipv2
 session target sip-server
 dtmf-relay rtp-nte
 no vad
How do I join the dial-peer to the extention? (for analogue I would put "trunk 1 monitor *voice port number* " on the extention).
Any help much appreciated,
Jonathan
Hi.
You can try with answer-address 432 under your dial-peer 432.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi.
Carlo
