CME Cause i = 0x809C - Invalid number format (incomplete number)
ciscoceci
-when i try to send fax i see the follow error in debug isdn:
-I use the dial-peer..
dial-peer voice 12 pots
description SORTIDES GLOBAL
translation-profile outgoing OutPSTN
destination-pattern 9[01]T
port 0/0/0:23
-Voice-port
voice-port 0/1/1
station-id name FAX2
station-id number 1533
caller-id enable
-If i delete  the translation-profile in dial-peer the same error.
-Incoming fax works
thanks
Anna.
8 Replies 8
ciscoceci
sorry, i forget debug
debug isdn q931 is              ON.
C6_PRE_E602858#
Dec 17 11:09:18.731: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 2125467889
Dec 17 11:09:18.735: ISDN Se0/0/0:23 Q931: Sending SETUP  callref = 0x00C2 callID = 0x8432 switch = primary-ni interface = User
Dec 17 11:09:18.735: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x00C2
        Sending Complete
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98396
                Exclusive, Channel 22
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x2180, '2127823675'
                Plan:ISDN, Type:National
        Called Party Number i = 0x80, '011'
                Plan:Unknown, Type:Unknown
Dec 17 11:09:18.771: ISDN Se0/0/0:23 Q931: RX <- STATUS pd = 8  callref = 0x80C2
        Cause i = 0x80E3A1 - Information element not implemented
        Call State i = 0x01
Dec 17 11:09:18.819: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80C2
I don't think 011 is a valid phone number anywhere in the PSTN.
Send a correct called number.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thanks Jaime,
We have tried with another number in USA (NY) and see the same error. The number is 164xxxxxxx and it exists. Here the logs:
Dec 17 17:25:54.237: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x00D5
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98397
                Exclusive, Channel 23
        Called Party Number i = 0x80, '164'
Dec 17 17:25:54.321: ISDN Se0/0/0:23 Q931: RX <- STATUS pd = 8  callref = 0x80D5
        Call State i = 0x01
Dec 17 17:25:54.325: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80D5
Again you are sending only 164 as the number, your dial-peers must be stripping the digits, post your full config.
Chris
Thanks Chris,
is it you need??
the called ext: DN: 1533 (FAX)
Anna
voice translation-rule 1
rule 1 /^1526$/ /2127558839\1/
rule 2 /^1527$/ /2127558843\1/
rule 3 /^1528$/ /2127558865\1/
rule 4 /^1529$/ /2127559405\1/
rule 5 /^1530$/ /2127559490\1/
rule 6 /^1531$/ /2127553382\1/
rule 7 /^1532$/ /2127558837\1/
rule 8 /^152\(.*\)/ /212755883\1/
rule 9 /^1503$/ /2127823330\1/
rule 10 /^150\(.*\)/ /212782333\1/
rule 11 /^1533$/ /2127823675\1/
rule 12 /^....$/ /2127823335\1/
voice translation-rule 2
rule 1 /^2127558839$/ /1526/
rule 2 /^2127558843$/ /1527/
rule 3 /^2127558865$/ /1528/
rule 4 /^2127559405$/ /1529/
rule 5 /^2127559490$/ /1530/
rule 6 /^2127553382$/ /1531/
rule 7 /^2127558837$/ /1532/
rule 8 /^2127823675$/ /1533/
rule 9 /^212755883\(.*\)/ /152\1/
rule 10 /^212782333\(.*\)/ /150\1/
rule 11 /^2122975888$/ /1520/
rule 12 /^2122975889$/ /1520/
rule 13 /^212297588\(.*\)/ /1500/
rule 14 /^212297589\(.*\)/ /1520/
voice translation-profile InPSTN
translate called 2
voice translation-profile OutPSTN
translate calling 1
voice-port 0/1/0
ring frequency 50
station-id name FAX
station-id number 1532
caller-id enable
voice-port 0/1/1
caller-id enable
mgcp fax t38 ecm
dial-peer voice 10 pots
description ENTRADES GLOBAL
translation-profile incoming InPSTN
incoming called-number .T
direct-inward-dial
dial-peer voice 11 pots
description SORTIDES AREA CODE 212
destination-pattern 91(212)T
port 0/0/0:23
port 0/0/0:23
Please post "debug voice translation" and "debug voice dialpeer"
Chris
Hi Chris,
Here the log:
calling: 1533
called: 9 011 93 50 82 011
Anna.
Dec 17 18:18:41.895: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgroup_internal:
   Voice port 0x496B11C4 dsl=-1 timeslot=0 does not belong to any trunk group
Dec 17 18:18:41.895: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=1533, Called Number=, Voice-Interface=0x496B11C4,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=1533
Dec 17 18:18:41.899: //-1/66F277ED9BC2/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x49CA3738; count=1
Dec 17 18:18:41.899: //-1/66F277ED9BC2/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4CC59160
Dec 17 18:18:41.903: //-1/66F277ED9BC2/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x49CA3738; count=1
Dec 17 18:18:44.383: //-1/66F277ED9BC2/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=9, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=9
   Result=Partial Matches(1) after DP_MATCH_DEST
Dec 17 18:18:44.383: //-1/66F277ED9BC2/DPM/dpMatchPeersMoreArg:
   Result=MORE_DIGITS_NEEDED(1)
Dec 17 18:18:44.647: //-1/66F277ED9BC2/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=90, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=90
Dec 17 18:18:44.651: //-1/66F277ED9BC2/DPM/dpMatchPeersMoreArg:
Dec 17 18:18:44.919: //-1/66F277ED9BC2/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=901, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=901
Dec 17 18:18:44.919: //-1/66F277ED9BC2/DPM/dpMatchPeersMoreArg:
Dec 17 18:18:45.191: //-1/66F277ED9BC2/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=9011, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=9011
   Result=Success(0) after DP_MATCH_DEST
Dec 17 18:18:45.191: //-1/66F277ED9BC2/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=10002
     2: Dial-peer Tag=10001
     3: Dial-peer Tag=10003
Dec 17 18:18:45.195: //-1/66F277ED9BC2/DPM/dpMatchPeersCore:
Dec 17 18:18:45.195: //-1/66F277ED9BC2/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=12
     2: Dial-peer Tag=10002
     3: Dial-peer Tag=10001
     4: Dial-peer Tag=10003
   Result=SUCCESS(0)
     1: Dial-peer Tag=12
Dec 17 18:18:45.195: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=9011, Called Number=9011, Peer Info Type=DIALPEER_INFO_SPEECH
Dec 17 18:18:45.195: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=12
Dec 17 18:18:45.195: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=NO_MATCH(-1) After All Match Rules Attempt
   Calling Number=9011, Called Number=, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=10001
Dec 17 18:18:45.199: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Dec 17 18:18:45.199: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=12
Dec 17 18:18:45.199: //-1/66F277ED9BC2/DPM/dpMatchPeersCore:
Dec 17 18:18:45.199: //-1/66F277ED9BC2/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=12
Dec 17 18:18:45.199: //-1/66F277ED9BC2/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x49CA3738; count=2
Dec 17 18:18:45.203: //-1/66F277ED9BC2/RXRULE/regxrule_profile_translate_internal: number=1533 type=unknown plan=unknown numbertype=calling
Dec 17 18:18:45.203: //-1/66F277ED9BC2/RXRULE/regxrule_match: No match; number=1533 rule precedence=1
Dec 17 18:18:45.203: //-1/66F277ED9BC2/RXRULE/regxrule_match: No match; number=1533 rule precedence=2
Dec 17 18:18:45.203: //-1/66F277ED9BC2/RXRULE/regxrule_match: No match; number=1533 rule precedence=3
Dec 17 18:18:45.203: //-1/66F277ED9BC2/RXRULE/regxrule_match: No match; number=1533 rule precedence=4
Dec 17 18:18:45.203: //-1/66F277ED9BC2/RXRULE/regxrule_match: No match; number=1533 rule precedence=5
Dec 17 18:18:45.203: //-1/66F277ED9BC2/RXRULE/regxrule_match: No match; number=1533 rule precedence=6
Dec 17 18:18:45.203: //-1/66F277ED9BC2/RXRULE/regxrule_match: No match; number=1533 rule precedence=7
Dec 17 18:18:45.203: //-1/66F277ED9BC2/RXRULE/regxrule_match: No match; number=1533 rule precedence=8
Dec 17 18:18:45.203: //-1/66F277ED9BC2/RXRULE/regxrule_match: No match; number=1533 rule precedence=9
Dec 17 18:18:45.203: //-1/66F277ED9BC2/RXRULE/regxrule_match: No match; number=1533 rule precedence=10
Dec 17 18:18:45.203: //-1/66F277ED9BC2/RXRULE/regxrule_profile_match_internal: Matched with rule 11 in ruleset 1
Dec 17 18:18:45.203: //-1/66F277ED9BC2/RXRULE/sed_subst: Successful substitution; pattern=1533 matchPattern=^1533$ replacePattern=2127823675\1 replaced pattern=2127823675
Dec 17 18:18:45.207: //-1/66F277ED9BC2/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = unknown
Dec 17 18:18:45.207: //-1/66F277ED9BC2/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = unknown
Dec 17 18:18:45.207: //-1/66F277ED9BC2/RXRULE/regxrule_profile_translate_internal: xlt_number=2127823675 xlt_type=unknown xlt_plan=unknown
Dec 17 18:18:45.207: //-1/66F277ED9BC2/RXRULE/regxrule_profile_translate_internal: number=9011 type=unknown plan=unknown numbertype=called
Dec 17 18:18:45.207: //-1/66F277ED9BC2/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
Dec 17 18:18:45.207: //-1/66F277ED9BC2/RXRULE/regxrule_profile_match_internal: Error: ruleset for called number not found
Dec 17 18:18:45.207: //-1/66F277ED9BC2/RXRULE/regxrule_profile_translate_internal: No match: number=9011 type=unknown plan=unknown
Dec 17 18:18:45.207: //-1/66F277ED9BC2/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-target
Dec 17 18:18:45.207: //-1/66F277ED9BC2/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-target number not found
Dec 17 18:18:45.207: //-1/66F277ED9BC2/RXRULE/regxrule_profile_translate_internal: No match: number= type=unknown plan=unknown
Dec 17 18:18:45.207: //-1/66F277ED9BC2/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-called
Dec 17 18:18:45.207: //-1/66F277ED9BC2/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-called number not found
Dec 17 18:18:45.207: //-1/66F277ED9BC2/RXRULE/regxrule_dp_translate: calling_number=2127823675 calling_octet=0x0
        called_number=9011 called_octet=0x80
        redirect_number= redirect_type=0 redirect_plan=0        redirect_PI=0 redirect_SI=0
Dec 17 18:18:45.207: //-1/66F277ED9BC2/RXRULE/regxrule_vp_translate: No profile found in voice port or trunk group for outgoing direction
Dec 17 18:18:45.207: //-1/66F277ED9BC2/RXRULE/regxrule_vp_translate: calling_number=2127823675 calling_octet=0x0
Dec 17 18:18:45.335: //-1/66F277ED9BC2/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
Dec 17 18:18:45.339: //-1/66F277ED9BC2/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x49CA3738; count=3
Dec 17 18:18:45.339: //-1/66F277ED9BC2/RXRULE/regxrule_dp_translate: No profile found in peer 10002 for outgoing direction
Dec 17 18:18:45.339: //-1/66F277ED9BC2/RXRULE/regxrule_dp_translate: calling_number=1533 calling_octet=0x0
Dec 17 18:18:45.339: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=9[01]T, Called Number=, Voice-Interface=0x0,
Dec 17 18:18:45.343: //-1/66F277ED9BC2/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x49CA3738; count=3
Dec 17 18:18:45.343: //-1/66F277ED9BC2/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4CC5697C
Dec 17 18:18:45.343: //-1/66F277ED9BC2/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x49CA3738; count=3
Dec 17 18:18:45.347: //-1/66F277ED9BC2/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4CC5697C
Dec 17 18:18:45.347: //-1/66F277ED9BC2/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x49CA3738; count=3
Dec 17 18:18:45.599: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1533, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=1533
Dec 17 18:18:45.599: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1533
Dec 17 18:18:45.603: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Dec 17 18:18:45.603: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=12
Dec 17 18:18:55.895: //-1/66F277ED9BC2/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
Dec 17 18:18:55.899: //-1/66F277ED9BC2/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x49CA3738; count=4
Dec 17 18:18:55.899: //-1/66F277ED9BC2/RXRULE/regxrule_dp_translate: No profile found in peer 10001 for outgoing direction
Dec 17 18:18:55.899: //-1/66F277ED9BC2/RXRULE/regxrule_dp_translate: calling_number=1533 calling_octet=0x0
Dec 17 18:18:55.899: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=[1-9]..., Called Number=, Voice-Interface=0x0,
Dec 17 18:18:55.903: //-1/66F277ED9BC2/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x49CA3738; count=4
Dec 17 18:18:55.903: //-1/66F277ED9BC2/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4CC59978
Dec 17 18:18:55.903: //-1/66F277ED9BC2/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x49CA3738; count=4
Dec 17 18:18:56.171: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Dec 17 18:18:56.171: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
Dec 17 18:18:56.175: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=12
Dec 17 18:19:06.423: //-1/66F277ED9BC2/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
Dec 17 18:19:06.427: //-1/66F277ED9BC2/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x49CA3738; count=5
Dec 17 18:19:06.427: //-1/66F277ED9BC2/RXRULE/regxrule_dp_translate: No profile found in peer 10003 for outgoing direction
Dec 17 18:19:06.427: //-1/66F277ED9BC2/RXRULE/regxrule_dp_translate: calling_number=1533 calling_octet=0x0
Dec 17 18:19:06.427: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Dec 17 18:19:06.431: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Dec 17 18:19:06.431: //-1/66F277ED9BC2/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x49CA3738; count=5
Dec 17 18:19:06.431: //-1/66F277ED9BC2/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4CC5603C
Dec 17 18:19:06.431: //-1/66F277ED9BC2/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x49CA3738; count=5
Dec 17 18:19:06.435: //-1/66F277ED9BC2/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x49CA3738; count=5
Dec 17 18:19:06.435: //-1/66F277ED9BC2/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4CC5603C
Dec 17 18:19:06.435: //-1/66F277ED9BC2/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x49CA3738; count=5
Dec 17 18:19:06.691: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Dec 17 18:19:06.691: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
     1: Dial-peer Tag=12
Dec 17 18:19:16.936: //-1/66F277ED9BC2/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
Dec 17 18:19:16.940: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Dec 17 18:19:19.480: //-1/66F277ED9BC2/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x49CA3738; count=5
Dec 17 18:19:19.480: //-1/66F277ED9BC2/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4CC5603C
Dec 17 18:19:19.484: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=1533, Called Number=, Voice-Interface=0x0,
Looks like the digits coming to the GW from CUCM are stripped, what does your Route Pattern, Route List and Route Group within Route List look like?
Is your international route pattern such as 9011! set to URGENT, if so uncheck it.
HTH,
Chris
