Reception Phone module
mattsaundersmcp
I have a question regarding ordering of user and extension on th ephone module, The only way I can see to do this is move the user down one by one.
Is there a quicker way to do this?
7 Replies 7
Chris Deren
This is very simply with CLI, copy, adjust and paste.
Chris
Thanks for the reply, I am new to all this so I have been told we need to be able to adjust the extensions and users in the call manager web interface
You mentioned ephone so I assumed you have CallManager Express, what system and version do you have?
Chris
We are using the Cisco Unified CM administration, system version 8.6.2.21900
Then you can shift them one by one using "modify button items", or you can perform BAT update of the phones if you have a lot of them.
HTH,
Chris
Do you mean using this section to reorder
Correct.
HTH, please rate all useful posts!
Chris
