Showing results forĀ
Search instead forĀ
Did you mean:Ā
cme connection problem
gevangelista
Good Morning I've a little problem with a cme and fxo card.
well.
I've a callmanager express, that work.
I've also another router  wher are connected all analogic lines and faxes. connected via sip trunk to callmanager express.
On this second router I've installed a fxo card directy connected to a fxs port of an UMTS router.
Our customer want tha all call directed to a mobile devices will be router from callmanager to the fxo port of second router.
I've implemented the following configuration. but the calls doesn't works.
can you help me?
thanks in advance
CCME
dial-peer voice 1340 voip
destination-pattern 89T
session target ipv4:172.16.3.91
dtmf-relay h245-alphanumeric
no vad
second router (with fxo card)
session target ipv4:172.16.3.90
no vad
dial-peer voice 1340 pots
port 0/1/0
T voice-port 0/1/0
no comfort-noise
cptone IT
2 Accepted Solutions
Please post the output of debug voip ccapi inout,
Give us the called number and calling number and exctly as you is dialing
Cheers
Bruno Rangel
"Se vocĆŖ quiser alguĆ©m em quem confiar, confie em si mesmo. Quem acredita sempre alcanƧa"
Renato Russo
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
Is 89 supposed to be stripped as pots dial-peers strip all explicitly matched digits, in your case 89 will both be stripped before sending the call to PSTN.
Can you also post "debug voice dialpeer" from both routers?
Chris
5 Replies 5
Bruno Rangel
Hi try in the second Router shutdown the dial-peer voice 1340 voip.
Let me know if woks...
Cheers
Bruno Rangel
Renato Russo
Cheers
Bruno Rangel
Hi Bruno , now the dial-peer 1340 on second router is shutdowan but doesn't work!
Cheers
Bruno Rangel
Renato Russo
Cheers
Bruno Rangel
Chris
Hi. I've solved!!!
The problem was an old  dial-peer  configured but not used on second  router.
I've put in shutdown this dial peer and now alla works!!!
Thanks for help
giancarlo
