CME/CUE IOS compatibility matrix confusion
norm.trees
Have used the following link to ensure that the IOS, CME version and CUE versions are correct.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
This does not seem up to date though, as there are many later versions of IOS 124-11.XW?.bin released and not mentioned in the matrix.
Andy advice regarding compatibility would be appreciated.
N.
paolo bevilacqua
Hi, the matrix is valid for all the XW releases.
Similarly, a matrix for the XZ release would cover all subsequent version unless otherwise noted.
Please rate post if it helps!
Thanks for that, what is the most stable XW to date? Think I will stay with XW so I can use all the existing phone loads etc.
XW8 is the latest and is what should be used unless contrary positive information exist.
Will give it a try!!!
thanks again!
