CME - Dial peers to prevent call fraud from unauthorized sources
rajesh.kumar
Level 4
Level 4
CallManager Express 8.0 with E1 PRI and DID numbers.
Also there is CUE module exits in this router. Router IOS is 15.x
How do we configure Dial peers to prevent call fraud from unauthorized sources?
Rgds
Rajesh Kumar
5 Replies 5
clileikis
Level 7
Level 7
Hi Rajesh,
Check out the following document:
https://supportforums.cisco.com/docs/DOC-12228
Hi clileikis
I have gone thorough the link, one you attached.
trust list under, voice service voip is for VOIP calls right.
there is one command : dial-peer no-match isdn disconnect-cause invalid-number
This command will disconect not matching dial-peer or default dial-peer. Do you have any solution for matched dial-peer (phone does not exists, but ephone configured), in that scenario CME should not provide outside dial-tone.
Pls. suggest if anything else need to be configured prevent call fraud.
Rgds
Rajesh Kumar
Hi clileikis
Rgds
Rajesh Kumar
Hi Rajesh,
Have I worked with you on a TAC Case?
you could use
dial-peer voice 1 pots
incoming called-number .T
direct-inward-dial
This should get rid of the secondary dial-tone.
PS: Rate useful posts.!
Thanks for information.
Good you remember me.
Rgds
Rajesh
