02-21-2013 10:59 PM - edited 03-16-2019 03:52 PM
Hey Guys!
Whats happening with my CME??? Analog lines went dead after an electric outage!!
Feb 21 15:26:55.663 EKT: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
Feb 21 15:26:57.055 EKT: %DSPRM-5-UPDOWN: DSP 2 in slot 0, changed state to up
Feb 21 15:26:57.323 EKT: %DSPRM-2-DSPALARM: Received alarm indication from dsp (0/1). Resetting the DSP.
Feb 21 15:26:57.323 EKT: %DSPRM-3-DSPALARMINFO: 001C 0000 0080 0000 0005 4900 636F 6465 6364 7276 2832 3232 3429 0000 0000 0000 0000 0000
Feb 21 15:26:57.323 EKT: %DSPRM-3-DSPALARMINFO: codecdrv(2224)
Feb 21 15:26:58.455 EKT: %DSPRM-5-UPDOWN: DSP 3 in slot 0, changed state to up
Feb 21 15:27:01.091 EKT: %SYS-5-RESTART: System restarted --
Cisco IOS Software, 3800 Software (C3825-IPVOICEK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 19:57 by prod_rel_team
Feb 21 15:27:01.103 EKT: %SNMP-5-COLDSTART: SNMP agent on host P00-7400-01 is undergoing a cold start
Feb 21 15:27:01.415 EKT: %DSPRM-5-UPDOWN: DSP 4 in slot 0, changed state to up
Feb 21 15:27:01.431 EKT: %SSH-5-ENABLED: SSH 2.0 has been enabled
Feb 21 15:27:01.704 EKT: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.10.10.42 port 514 started - CLI initiated
Feb 21 15:27:01.704 EKT: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.0.129.172 port 514 started - CLI initiated
Feb 21 15:27:02.912 EKT: %LINK-5-CHANGED: Interface GigabitEthernet0/0, changed state to reset
Feb 21 15:27:03.008 EKT: %LINK-5-CHANGED: Interface GigabitEthernet0/1, changed state to reset
Feb 21 15:27:03.140 EKT: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
Feb 21 15:27:04.008 EKT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
Feb 21 15:27:04.480 EKT: %DSPRM-5-UPDOWN: DSP 5 in slot 0, changed state to up
Feb 21 15:27:04.480 EKT: %DSPRM-2-DSPALARM: Received alarm indication from dsp (0/1). Resetting the DSP.
Feb 21 15:27:04.480 EKT: %DSPRM-3-DSPALARMINFO: 001C 0000 0080 0000 0005 4900 636F 6465 6364 7276 2832 3232 3429 0000 0000 0000 0000 0000
Feb 21 15:27:04.480 EKT: %DSPRM-3-DSPALARMINFO: codecdrv(2224)
Feb 21 15:27:10.992 EKT: %C5510-4-NO_RING_DESCRIPTORS: No more ring descriptors available on slot 0 dsp 1.
Feb 21 15:27:12.368 EKT: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
Feb 21 15:27:14.512 EKT: DSP0 flex_vic_config_ack Failed. ret code = 0x0080
Feb 21 15:27:14.512 EKT: pak len 24 0 18 0 0 0 8C 0 0 0 80 0 80 0 80 0 80 0 80 0 80 0 80 0 80
Feb 21 15:27:14.516 EKT:
Feb 21 15:27:14.516 EKT: DSP0 flex_vic_config_ack Failed. ret code = 0x0080
Feb 21 15:27:14.516 EKT: pak len 24 0 18 0 0 0 8C 0 0 0 80 0 80 0 80 0 80 0 80 0 80 0 80 0 80
Feb 21 15:27:14.516 EKT: %DSPRM-5-DSP_VIC_CONFIG_NAK: Received VIC config NAK from DSP(0/0), resetting the DSP.
Feb 21 15:27:15.696 EKT: %SDSPFARM-6-REGISTER: mtp-2:mtp001e4a2fa991 IP:10.74.222.251 Socket:1 DeviceType:MTP has registered.
Feb 21 15:27:15.904 EKT: %HWCONF-6-REGISTER: hwconf-1:cfb001e4a2fa991 IP:10.74.222.251 Socket:2 DeviceType:HW Conference has registered.
Feb 21 15:27:19.636 EKT: %DSPRM-3-DSPALARMINFO: DSP (0/1) Host keepalive timeout
Feb 21 15:27:29.132 EKT: DSP0 flex_vic_config_ack Failed. ret code = 0x0080
Feb 21 15:27:29.132 EKT: pak len 24 0 18 0 0 0 8C 0 0 0 80 0 80 0 80 0 80 0 80 0 80 0 80 0 80
Feb 21 15:27:29.136 EKT:
Feb 21 15:27:29.136 EKT: DSP0 flex_vic_config_ack Failed. ret code = 0x0080
Feb 21 15:27:29.136 EKT: pak len 24 0 18 0 0 0 8C 0 0 0 80 0 80 0 80 0 80 0 80 0 80 0 80 0 80
Feb 21 15:27:29.140 EKT: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/0, changed state to up
Feb 21 15:27:29.156 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.164 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.172 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.180 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.188 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.196 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.204 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.212 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.220 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.228 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.236 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.244 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.252 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.260 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.268 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.276 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.284 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.292 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.300 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.316 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.324 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.332 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.340 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.348 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.356 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.364 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.372 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.380 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.388 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.396 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.404 EKT: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/1, changed state to up
Feb 21 15:27:29.404 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.412 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.424 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.428 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.436 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.444 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.452 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.456 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.460 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.464 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.468 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.472 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.476 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.484 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.484 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.492 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.492 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.496 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.500 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.504 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.508 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.512 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.516 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.524 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.524 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.528 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.532 EKT: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
Feb 21 15:27:29.536 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.540 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.544 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.548 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.556 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.556 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.556 EKT: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/2, changed state to up
Feb 21 15:27:29.564 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.564 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.568 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.572 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.576 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.580 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.584 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.588 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.596 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.596 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.600 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.604 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.612 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.620 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.620 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.628 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.628 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.636 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.636 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.640 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.644 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.648 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.652 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.660 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.660 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.668 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.668 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.672 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.676 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.680 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.684 EKT: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
Feb 21 15:27:29.692 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.700 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.712 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.716 EKT: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/3, changed state to up
Feb 21 15:27:29.720 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.732 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.736 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.744 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.752 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.764 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.772 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.776 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.784 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.796 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.800 EKT: Miscellaneous signaling debug data: (ch=4):
0002 0080 ABBA **
Feb 21 15:27:29.804 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.808 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.816 EKT: Miscellaneous signaling debug data: (ch=6):
0003 0080 ABBA **
Feb 21 15:27:29.816 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.824 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.832 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.832 EKT: Miscellaneous signaling debug data: (ch=8):
0004 0080 ABBA **
Feb 21 15:27:29.836 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.840 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.844 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.848 EKT: Miscellaneous signaling debug data: (ch=10):
0005 0080 ABBA **
Feb 21 15:27:29.848 EKT: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
Feb 21 15:27:29.848 EKT: Miscellaneous signaling debug data: (ch=5):
0002 0080 ABBA **
Feb 21 15:27:29.852 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.856 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.860 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.864 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.864 EKT: Miscellaneous signaling debug data: (ch=7):
0003 0080 ABBA **
Feb 21 15:27:29.868 EKT: %LINK-3-UPDOWN: Interface Foreign Exchange Station 1/0/0, changed state to up
Feb 21 15:27:29.868 EKT: %LINK-3-UPDOWN: Interface Foreign Exchange Station 1/0/1, changed state to up
Feb 21 15:27:29.868 EKT: %LINK-3-UPDOWN: Interface Foreign Exchange Station 1/0/2, changed state to up
Feb 21 15:27:29.868 EKT: %LINK-3-UPDOWN: Interface Foreign Exchange Station 1/0/3, changed state to up
Feb 21 15:27:29.872 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.872 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.872 EKT: %LINK-3-UPDOWN: Interface Foreign Exchange Station 1/0/4, changed state to up
Feb 21 15:27:29.872 EKT: %LINK-3-UPDOWN: Interface Foreign Exchange Station 1/0/5, changed state to up
Feb 21 15:27:29.872 EKT: %LINK-3-UPDOWN: Interface Foreign Exchange Station 1/0/6, changed state to up
Feb 21 15:27:29.872 EKT: %LINK-3-UPDOWN: Interface Foreign Exchange Station 1/0/7, changed state to up
Feb 21 15:27:29.876 EKT: %LINK-3-UPDOWN: Interface Foreign Exchange Office 1/0/8, changed state to up
Feb 21 15:27:29.880 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.880 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.884 EKT: Miscellaneous signaling debug data: (ch=9):
0004 0080 ABBA **
Feb 21 15:27:29.884 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.888 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.892 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.896 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.896 EKT: Miscellaneous signaling debug data: (ch=11):
0005 0080 ABBA **
Feb 21 15:27:29.900 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.904 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.912 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.912 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.920 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.920 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.924 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.928 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.932 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.936 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.940 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.944 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.952 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.952 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.956 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.960 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.964 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.968 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.972 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:29.976 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.992 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:29.992 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:29.996 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:30.000 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:30.004 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:30.008 EKT: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
Feb 21 15:27:30.016 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:30.024 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:30.028 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:30.036 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:30.048 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:30.056 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:30.060 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:30.068 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:30.080 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:30.088 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:30.092 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:30.100 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:30.112 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:30.120 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:30.124 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:30.132 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:30.140 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.152 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.160 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.164 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.172 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.184 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.192 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.196 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.204 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.216 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.224 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.228 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.236 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.248 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.256 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.260 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.268 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.280 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.288 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:30.304 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:30.312 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:30.320 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:30.324 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:30.336 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:30.344 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:30.352 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:30.356 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:30.368 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:30.376 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:30.384 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:30.388 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:30.400 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:30.408 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:30.416 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:30.420 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:30.432 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:30.440 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:30.448 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:34.916 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:34.924 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:34.932 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:34.940 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:34.948 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:34.956 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:34.964 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:34.972 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:34.980 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:34.988 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:34.996 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:35.004 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:35.012 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:35.020 EKT: Miscellaneous signaling debug data: (ch=12):
0006 0080 ABBA **
Feb 21 15:27:35.020 EKT: %LINK-3-UPDOWN: Interface Foreign Exchange Office 1/0/9, changed state to up
Feb 21 15:27:35.020 EKT: %LINK-3-UPDOWN: Interface Foreign Exchange Office 1/0/10, changed state to up
Feb 21 15:27:35.020 EKT: %LINK-3-UPDOWN: Interface Foreign Exchange Office 1/0/11, changed state to up
Feb 21 15:27:35.052 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.060 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.064 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.072 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.084 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.092 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.096 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.104 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.116 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.124 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.128 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.136 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.148 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.148 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:35.156 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.156 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:35.164 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:35.172 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:35.180 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:35.192 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:35.196 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:35.204 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:35.212 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:35.224 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:35.228 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:35.236 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:35.244 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:35.256 EKT: Miscellaneous signaling debug data: (ch=14):
0007 0080 ABBA **
Feb 21 15:27:35.260 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:35.268 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:35.276 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:35.284 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:35.292 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:35.300 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:35.308 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:35.316 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:35.324 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:35.332 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:35.340 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:35.348 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:35.356 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:35.364 EKT: %LINK-3-UPDOWN: Interface Foreign Exchange Office 1/0/9, changed state to up
Feb 21 15:27:35.364 EKT: Miscellaneous signaling debug data: (ch=15):
0007 0080 ABBA **
Feb 21 15:27:35.376 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.384 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.388 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.396 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.408 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.416 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.420 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.428 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.440 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.448 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.452 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.460 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.472 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:27:35.480 EKT: Miscellaneous signaling debug data: (ch=13):
0006 0080 ABBA **
Feb 21 15:30:04.248 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.6 on callID 23 GUID=1A96F79F7B4011E28029B681852F2DC7
Feb 21 15:30:11.500 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 22 GUID=19537A5C7B4011E28025B681852F2DC7
Feb 21 15:33:44.123 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 55 GUID=975635D07B4011E28061B681852F2DC7
Feb 21 15:41:55.157 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 127 GUID=BE880FD57B4111E280D2B681852F2DC7
Feb 21 15:44:58.444 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 161 GUID=27131B927B4211E280F8B681852F2DC7
Feb 21 15:47:15.545 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 179 GUID=80A20DDE7B4211E2811DB681852F2DC7
Feb 21 15:50:41.892 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 206 GUID=FB8C88C07B4211E2814EB681852F2DC7
Feb 21 15:55:18.892 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 227 GUID=9BF931517B4311E2817AB681852F2DC7
Feb 21 15:56:10.912 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 244 GUID=C095DF7D7B4311E28194B681852F2DC7
Feb 21 15:56:10.916 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 244 GUID=C095DF7D7B4311E28194B681852F2DC7
Feb 21 15:56:15.905 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 246 GUID=C3225A077B4311E2819CB681852F2DC7
Feb 21 15:56:15.909 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 246 GUID=C3225A077B4311E2819CB681852F2DC7
Feb 21 16:03:32.574 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 294 GUID=B699D6727B4411E281F8B681852F2DC7
Feb 21 16:05:05.904 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.1 on callID 329 GUID=F72619D47B4411E2823FB681852F2DC7
Feb 21 16:07:39.390 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 363
Feb 21 16:07:51.422 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 366
Feb 21 16:10:48.556 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.1 on callID 395 GUID=C362B87A7B4511E282B2B681852F2DC7
Feb 21 16:10:54.492 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 396 GUID=CE37954D7B4511E282B6B681852F2DC7
Feb 21 16:12:08.701 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 405 GUID=F609CF1C7B4511E282C8B681852F2DC7
Feb 21 16:13:09.838 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 420 GUID=1FD1BF677B4611E282E5B681852F2DC7
Feb 21 16:13:10.810 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 419 GUID=15D4F2D97B4611E282E1B681852F2DC7
Feb 21 16:13:13.322 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 419 GUID=15D4F2D97B4611E282E1B681852F2DC7
Feb 21 16:13:13.326 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 419 GUID=15D4F2D97B4611E282E1B681852F2DC7
Feb 21 16:14:42.047 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 429 GUID=5713717A7B4611E282F5B681852F2DC7
Feb 21 16:16:08.972 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.1 on callID 436 GUID=825E58CD7B4611E28303B681852F2DC7
Feb 21 16:23:28.398 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 522 GUID=8FDB48C27B4711E2839CB681852F2DC7
Feb 21 16:33:41.630 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 565 GUID=F5767AD67B4811E283EDB681852F2DC7
Feb 21 16:39:35.886 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 606 GUID=C9B0680E7B4911E2843AB681852F2DC7
Feb 21 16:41:05.395 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 617 GUID=06D474B67B4A11E2844CB681852F2DC7
Feb 21 16:41:10.292 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 619 GUID=099C23557B4A11E28451B681852F2DC7
Feb 21 16:41:30.520 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 627 GUID=10F2D2067B4A11E28465B681852F2DC7
Feb 21 16:44:57.210 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 645 GUID=9052A4867B4A11E28486B681852F2DC7
Feb 21 16:44:57.218 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 645 GUID=9052A4867B4A11E28486B681852F2DC7
Feb 21 16:45:01.518 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 647 GUID=93160CDB7B4A11E2848EB681852F2DC7
Feb 21 16:45:01.522 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 647 GUID=93160CDB7B4A11E2848EB681852F2DC7
Feb 21 16:49:02.177 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 679 GUID=22E168AE7B4B11E284CFB681852F2DC7
Feb 21 16:55:20.590 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 725 GUID=0105C60A7B4C11E2851CB681852F2DC7
Feb 21 16:55:47.462 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 736 GUID=102FA9307B4C11E2852BB681852F2DC7
Feb 21 16:57:14.451 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 762 GUID=3CF631BA7B4C11E2854BB681852F2DC7
Feb 21 16:57:14.455 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 762 GUID=3CF631BA7B4C11E2854BB681852F2DC7
Feb 21 16:57:22.539 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 767 GUID=4694612A7B4C11E28555B681852F2DC7
Feb 21 16:57:42.372 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 775 GUID=586FF7B77B4C11E2855FB681852F2DC7
Feb 21 16:58:04.328 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 782 GUID=5AB15E4F7B4C11E2856BB681852F2DC7
Feb 21 16:58:04.332 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 782 GUID=5AB15E4F7B4C11E2856BB681852F2DC7
Feb 21 16:58:09.240 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 792 GUID=68EA27FF7B4C11E2857CB681852F2DC7
Feb 21 17:00:14.745 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 821 GUID=A86BAA6C7B4C11E285A9B681852F2DC7
Feb 21 17:00:34.782 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 821 GUID=A86BAA6C7B4C11E285A9B681852F2DC7
Feb 21 17:00:34.786 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 821 GUID=A86BAA6C7B4C11E285A9B681852F2DC7
Feb 21 17:01:34.318 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 847 GUID=E2A4A1157B4C11E285DBB681852F2DC7
Feb 21 17:09:02.200 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 901 GUID=E249BC6B7B4D11E2863EB681852F2DC7
Feb 21 17:10:23.837 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 923 GUID=1EB7472D7B4E11E28673B681852F2DC7
Feb 21 17:19:46.027 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.6 on callID 965 GUID=69F295BA7B4F11E286C4B681852F2DC7
Feb 21 17:24:07.298 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 982 GUID=059E20287B5011E286E4B681852F2DC7
Feb 21 17:30:56.731 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 1009 GUID=F7223EE07B5011E28718B681852F2DC7
Feb 21 17:33:06.869 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 1029 GUID=4B2268567B5111E28736B681852F2DC7
Feb 21 17:42:16.855 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 1102 GUID=8650C8107B5211E287B9B681852F2DC7
Feb 21 17:43:13.756 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 1110 GUID=AD6049477B5211E287CBB681852F2DC7
Feb 21 17:45:44.697 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.6 on callID 1130 GUID=07AB2CEF7B5311E287EEB681852F2DC7
Feb 21 17:45:55.402 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 1133 GUID=14E571BB7B5311E287F7B681852F2DC7
Feb 21 17:45:59.174 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 1133 GUID=14E571BB7B5311E287F7B681852F2DC7
Feb 21 17:47:41.371 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 1146 GUID=549DE52A7B5311E28808B681852F2DC7
Feb 21 17:59:18.483 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 1192 GUID=F12A1A2A7B5411E28857B681852F2DC7
Feb 21 18:01:36.405 EKT: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-83:SEPE8393561B0FA IP:10.0.41.178 Socket:45 DeviceType:Phone has unregistered abnormally.
Feb 21 18:04:53.407 EKT: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-81:SEP000FFE474FAF IP:10.0.41.177 Socket:3 DeviceType:Phone has unregistered abnormally.
Feb 21 18:21:54.139 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 1269 GUID=157C7C1D7B5811E288EFB681852F2DC7
Feb 21 19:40:46.252 EKT: %CCH323-2-GTWY_REGSTR_FAILED_ALT_GK: Gateway 7400_gw1 failed attempt to register with Alternate Gatekeeper 7400_gw1_P
Feb 21 19:40:46.288 EKT: %CCH323-6-REGSTR: Gateway 7400_gw1 registered with Gatekeeper 7400_gw1_B
Feb 22 08:30:52.997 EKT: %VOICE_IEC-3-GW: SIP: Internal Error (2xx, codec mismatch): IEC=1.1.278.7.109.0 on callID 1319 GUID=A0444A567BCE11E28913B681852F2DC7
Feb 22 08:34:12.407 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 1325 GUID=26461D807BCF11E28919B681852F2DC7
Feb 22 08:48:28.249 EKT: %VOICE_IEC-3-GW: SIP: Internal Error (2xx, codec mismatch): IEC=1.1.278.7.109.0 on callID 1332 GUID=153989207BD111E28922B681852F2DC7
Feb 22 08:49:27.014 EKT: %VOICE_IEC-3-GW: SIP: Internal Error (2xx, codec mismatch): IEC=1.1.278.7.109.0 on callID 1338 GUID=3838FE677BD111E28928B681852F2DC7
Feb 22 08:53:52.577 EKT: %VOICE_IEC-3-GW: SIP: Internal Error (2xx, codec mismatch): IEC=1.1.278.7.109.0 on callID 1344 GUID=D683F0627BD111E2892EB681852F2DC7
Feb 22 08:54:43.929 EKT: %VOICE_IEC-3-GW: SIP: Internal Error (2xx, codec mismatch): IEC=1.1.278.7.109.0 on callID 1350 GUID=F5395ABF7BD111E28934B681852F2DC7
Feb 22 09:12:15.334 EKT: %IPPHONE-6-REG_ALARM: 25: Name=SEP000FFE474FAF Load= 7.0.2.0 Last=Initialized
Feb 22 09:12:18.230 EKT: %IPPHONE-6-REGISTER: ephone-81:SEP000FFE474FAF IP:10.0.41.178 Socket:3 DeviceType:Phone has registered.
Feb 22 09:12:23.102 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.6 on callID 1425 GUID=76E77D267BD411E289B6B681852F2DC7
Feb 22 09:15:06.324 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 1460 GUID=DFB333737BD411E289E2B681852F2DC7
Feb 22 09:18:07.630 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.1 on callID 1498 GUID=47239C367BD511E28A23B681852F2DC7
Feb 22 09:18:26.010 EKT: %IPPHONE-6-REG_ALARM: Name=SEP0016471A6841 Load=CP7912080004SCCP080108A Last=Initialized
Feb 22 09:18:26.162 EKT: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-15:SEP0016471A6841 IP:10.74.222.30 Socket:34 DeviceType:Phone has unregistered abnormally.
Feb 22 09:18:26.162 EKT: %IPPHONE-6-REGISTER: ephone-15:SEP0016471A6841 IP:10.74.222.30 Socket:45 DeviceType:Phone has registered.
Feb 22 09:20:23.288 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 1506 GUID=994D2F527BD511E28A32B681852F2DC7
Feb 22 09:29:57.038 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 1542 GUID=EDE698F07BD611E28A6EB681852F2DC7
Feb 22 09:36:06.155 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.1 on callID 1581 GUID=C9FCD3D77BD711E28AB1B681852F2DC7
Feb 22 09:36:31.251 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 1585 GUID=E1783F9D7BD711E28ABAB681852F2DC7
Feb 22 09:36:31.255 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 1585 GUID=E1783F9D7BD711E28ABAB681852F2DC7
Feb 22 09:40:16.226 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 1590 GUID=542D37E17BD811E28ACBB681852F2DC7
Feb 22 09:48:34.340 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 1633 GUID=89CA70DB7BD911E28B0AB681852F2DC7
Feb 22 09:49:52.097 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 1657 GUID=BE7064EA7BD911E28B26B681852F2DC7
Feb 22 09:52:22.411 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 1671 GUID=0CEE0AC87BDA11E28B3EB681852F2DC7
Feb 22 09:55:50.970 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 1710 GUID=8F6316CC7BDA11E28B76B681852F2DC7
Feb 22 10:01:31.614 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 1768 GUID=5FC03B267BDB11E28BCCB681852F2DC7
Feb 22 10:04:33.504 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 1786 GUID=CB8519677BDB11E28BF6B681852F2DC7
Feb 22 10:04:33.508 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 1786 GUID=CB8519677BDB11E28BF6B681852F2DC7
Feb 22 10:04:58.185 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 1791 GUID=CF6899C67BDB11E28C01B681852F2DC7
Feb 22 10:06:36.734 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 1809 GUID=0EF34A4A7BDC11E28C24B681852F2DC7
Feb 22 10:06:51.814 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 1815 GUID=1E9A4E877BDC11E28C2DB681852F2DC7
Feb 22 10:06:51.818 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 1815 GUID=1E9A4E877BDC11E28C2DB681852F2DC7
Feb 22 10:07:36.111 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 1842 GUID=37D178007BDC11E28C56B681852F2DC7
Feb 22 10:07:36.115 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 1842 GUID=37D178007BDC11E28C56B681852F2DC7
Feb 22 10:08:20.279 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.6 on callID 1848 GUID=4960C2E37BDC11E28C5EB681852F2DC7
Feb 22 10:08:41.360 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.6 on callID 1852 GUID=58AD70E47BDC11E28C67B681852F2DC7
Feb 22 10:10:18.641 EKT: %IPPHONE-6-REGISTER: ephone-83:SEPE8393561B0FA IP:10.0.41.177 Socket:34 DeviceType:Phone has registered.
Feb 22 10:11:15.274 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 1878 GUID=B0585C667BDC11E28C87B681852F2DC7
Feb 22 10:11:34.618 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 1886 GUID=C6A201097BDC11E28C95B681852F2DC7
Feb 22 10:13:09.055 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 1901 GUID=F98E0F717BDC11E28CACB681852F2DC7
Feb 22 10:13:27.223 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 1906 GUID=069167097BDD11E28CB5B681852F2DC7
Feb 22 10:14:00.540 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 1920 GUID=14B746B27BDD11E28CCBB681852F2DC7
Feb 22 10:15:12.993 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 1935 GUID=42FF92B87BDD11E28CDDB681852F2DC7
Feb 22 10:21:32.802 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 1974 GUID=28C836A67BDE11E28D29B681852F2DC7
Feb 22 10:26:00.877 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 1978 GUID=C4CB19347BDE11E28D34B681852F2DC7
Feb 22 10:26:16.662 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 1984 GUID=D4E7E8DA7BDE11E28D40B681852F2DC7
Feb 22 10:32:44.359 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.1 on callID 2027 GUID=B3799FBE7BDF11E28D8EB681852F2DC7
Feb 22 10:38:35.456 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.6 on callID 2079 GUID=8C2AC7B67BE011E28DDEB681852F2DC7
Feb 22 10:38:43.592 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.6 on callID 2080 GUID=90D234387BE011E28DE2B681852F2DC7
Feb 22 10:41:47.334 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 2094 GUID=ED5427907BE011E28DFCB681852F2DC7
Feb 22 10:42:43.231 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 2118 GUID=1C5A46FE7BE111E28E1CB681852F2DC7
Feb 22 10:46:39.810 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 2166 GUID=A74B97237BE111E28E70B681852F2DC7
Feb 22 10:49:11.560 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 2204 GUID=01BE30AC7BE211E28EAEB681852F2DC7
Feb 22 10:50:20.417 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2212 GUID=2002184A7BE211E28EBBB681852F2DC7
Feb 22 10:50:30.429 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2212 GUID=2002184A7BE211E28EBBB681852F2DC7
Feb 22 10:50:47.997 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2216 GUID=24A713947BE211E28EC4B681852F2DC7
Feb 22 10:50:58.005 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2216 GUID=24A713947BE211E28EC4B681852F2DC7
Feb 22 10:51:43.050 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2242 GUID=573B3E647BE211E28EEFB681852F2DC7
Feb 22 10:51:54.226 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2252 GUID=689F33A47BE211E28EFAB681852F2DC7
Feb 22 10:52:10.998 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.1 on callID 2262 GUID=6AD8A8FD7BE211E28F0DB681852F2DC7
Feb 22 10:53:34.027 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.6 on callID 2292 GUID=9985AD1D7BE211E28F3CB681852F2DC7
Feb 22 10:54:07.472 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2315 GUID=B8380DAC7BE211E28F65B681852F2DC7
Feb 22 10:54:38.992 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 2325 GUID=C19C43227BE211E28F70B681852F2DC7
Feb 22 10:55:22.277 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 2340 GUID=E0720C217BE211E28F84B681852F2DC7
Feb 22 10:55:29.057 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 2341 GUID=E2BE6FEA7BE211E28F88B681852F2DC7
Feb 22 10:57:11.970 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2370 GUID=260283797BE311E28FB4B681852F2DC7
Feb 22 11:00:46.245 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 2391 GUID=9FF7030E7BE311E28FD6B681852F2DC7
Feb 22 11:01:24.250 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2400 GUID=BCA331EF7BE311E28FE9B681852F2DC7
Feb 22 11:01:37.998 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2405 GUID=C33D478D7BE311E28FF5B681852F2DC7
Feb 22 11:01:42.250 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 2406 GUID=C3FF613E7BE311E28FF9B681852F2DC7
Feb 22 11:01:49.958 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 2413 GUID=CA966A147BE311E2900AB681852F2DC7
Feb 22 11:01:55.678 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2416 GUID=CE571E2B7BE311E29011B681852F2DC7
Feb 22 11:02:09.298 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2419 GUID=D757391B7BE311E2901AB681852F2DC7
Feb 22 11:02:22.898 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2422 GUID=DF3CBBCD7BE311E29023B681852F2DC7
Feb 22 11:02:33.171 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2425 GUID=E51FB6F17BE311E2902CB681852F2DC7
Feb 22 11:06:47.454 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 2457 GUID=7653433F7BE411E29065B681852F2DC7
Feb 22 11:15:55.810 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 2485 GUID=BDF3DBDB7BE511E29095B681852F2DC7
Feb 22 11:17:17.399 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 2510 GUID=EE955F587BE511E290B2B681852F2DC7
Feb 22 11:17:30.939 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 2513 GUID=F6A7716A7BE511E290B6B681852F2DC7
Feb 22 11:18:00.591 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2525 GUID=038761C47BE611E290C5B681852F2DC7
Feb 22 11:19:07.760 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 2553 GUID=2B908B287BE611E290F2B681852F2DC7
Feb 22 11:21:48.090 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2611 GUID=961D84E87BE611E29155B681852F2DC7
Feb 22 11:24:36.985 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 2662 GUID=F477E3127BE611E291ADB681852F2DC7
Feb 22 11:24:46.973 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 2663 GUID=FA8C4F6F7BE611E291B1B681852F2DC7
Feb 22 11:24:52.597 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2675 GUID=02C129267BE711E291C4B681852F2DC7
Feb 22 11:24:59.193 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2680 GUID=082DBAB47BE711E291CFB681852F2DC7
Feb 22 11:25:06.401 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2671 GUID=01538F287BE711E291BBB681852F2DC7
Feb 22 11:25:14.285 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2691 GUID=10DCAA277BE711E291ECB681852F2DC7
Feb 22 11:26:08.626 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2719 GUID=315D17B67BE711E29216B681852F2DC7
Feb 22 11:27:40.967 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2741 GUID=68DD0C6F7BE711E29234B681852F2DC7
Feb 22 11:27:44.283 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2732 GUID=5F6F12B07BE711E2922AB681852F2DC7
Feb 22 11:29:13.612 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.6 on callID 2755 GUID=9EA4EE2F7BE711E2924CB681852F2DC7
Feb 22 11:29:42.273 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 2762 GUID=AA901EC27BE711E2925DB681852F2DC7
Feb 22 11:30:21.717 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 2768 GUID=C212DF627BE711E29261B681852F2DC7
Feb 22 11:30:51.634 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 2784 GUID=D7ACBC9C7BE711E2927BB681852F2DC7
Feb 22 11:30:55.826 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2790 GUID=DC4CD4A17BE711E29289B681852F2DC7
Feb 22 11:31:01.854 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.6 on callID 2799 GUID=DF26D2517BE711E29293B681852F2DC7
Feb 22 11:31:48.490 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2818 GUID=FCE202797BE711E292B1B681852F2DC7
Feb 22 11:33:33.628 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2820 GUID=29B11BC17BE811E292B6B681852F2DC7
Feb 22 11:34:55.373 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 2837 GUID=6AA522977BE811E292D4B681852F2DC7
Feb 22 11:39:49.837 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2889 GUID=1B0343FA7BE911E29323B681852F2DC7
Feb 22 11:39:57.833 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2893 GUID=1F165F147BE911E29330B681852F2DC7
Feb 22 11:41:47.450 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.1 on callID 2897 GUID=58F3CC8D7BE911E2933DB681852F2DC7
Feb 22 11:41:54.098 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2905 GUID=6564A7CE7BE911E2934EB681852F2DC7
Feb 22 11:44:47.245 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 2940 GUID=C8A23F247BE911E29382B681852F2DC7
Feb 22 11:47:15.794 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 2970 GUID=24FBE6A57BEA11E293B5B681852F2DC7
Feb 22 11:50:49.097 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 3000 GUID=9A4F06667BEA11E28FFEE19014E0BC2E
Feb 22 11:50:49.989 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3001 GUID=A1C9C59A7BEA11E293EBB681852F2DC7
Feb 22 11:55:37.037 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3034 GUID=4903C04E7BEB11E29423B681852F2DC7
Feb 22 11:55:55.781 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 3046 GUID=5A930D367BEB11E2943AB681852F2DC7
Feb 22 11:56:01.181 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3049 GUID=5BE187117BEB11E29443B681852F2DC7
Feb 22 11:56:35.117 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3062 GUID=6DAB6B4E7BEB11E29457B681852F2DC7
Feb 22 11:56:35.121 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3062 GUID=6DAB6B4E7BEB11E29457B681852F2DC7
Feb 22 11:56:41.677 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3063 GUID=6F91DF817BEB11E2945BB681852F2DC7
Feb 22 11:56:42.934 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3063 GUID=6F91DF817BEB11E2945BB681852F2DC7
Feb 22 12:02:20.646 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3103 GUID=3E7BE1BD7BEC11E2949AB681852F2DC7
Feb 22 12:02:38.714 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3107 GUID=443116057BEC11E294A2B681852F2DC7
Feb 22 12:05:30.544 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3131 GUID=AB55D4DF7BEC11E294D8B681852F2DC7
Feb 22 12:05:31.800 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3131 GUID=AB55D4DF7BEC11E294D8B681852F2DC7
Feb 22 12:06:01.844 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3144 GUID=BD1F1A567BEC11E294EFB681852F2DC7
Feb 22 12:06:01.848 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3144 GUID=BD1F1A567BEC11E294EFB681852F2DC7
Feb 22 12:08:27.734 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.6 on callID 3157 GUID=1AC1225E7BED11E29501B681852F2DC7
Feb 22 12:15:17.667 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 3205 GUID=08FCD58C7BEE11E29548B681852F2DC7
Feb 22 12:18:26.206 EKT: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 3234 GUID=7F5A20107BEE11E29572B681852F2DC7
Feb 22 12:31:02.675 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.1 on callID 3311 GUID=3A66B92A7BF011E295EDB681852F2DC7
Feb 22 12:31:41.740 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3312 GUID=5567A58B7BF011E295F1B681852F2DC7
Feb 22 12:36:49.367 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 3327 GUID=0AE602EB7BF111E29610B681852F2DC7
Feb 22 12:38:14.808 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (No dialpeer match): IEC=1.1.128.11.5.0 on callID 3350 GUID=3DC05B6E7BF111E2962EB681852F2DC7
Feb 22 12:46:27.998 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Digit collect failed): IEC=1.1.179.11.28.6 on callID 3376 GUID=635930F67BF211E29651B681852F2DC7
Feb 22 12:46:40.299 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3377 GUID=6C21C15A7BF211E29655B681852F2DC7
Feb 22 12:47:10.727 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3381 GUID=805998F07BF211E2965CB681852F2DC7
Feb 22 12:47:10.731 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3381 GUID=805998F07BF211E2965CB681852F2DC7
Feb 22 12:51:39.802 EKT: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3394 GUID=222D16E17BF311E29671B681852F2DC7
02-21-2013 11:33 PM
Paolo,
Am sorry i offended you by marking the answer as useful. I was going to mark all your answers as useful then the final answer as the correct answer
I don't know how the ratings work - i though that the final answer is marged as the correct answer and the rest just helpful answers
I did not mean to offend you - and definately not send you away .
Receive my sincere apologies. I understand your stand and terribly apologise for the misunderstanding in ratings. I know you are very good in Voice, its a pity that i had to be the one to demean your rating as such.
Sincerely,
Faith
02-22-2013 12:35 AM
Thank you for explaining the issue with the rating system, that is happening a lot. No problem, good luck.
02-27-2013 04:55 AM
Just as a feedback, I did what you recommended. Opened the router and blew the pvdms. I even went farther to test each of the pvdms one by one - no change. Tried removing the vic modules and inserting them back. Nothing. So basically i opted for your second recommendation - changing the router. Everything works fine now. Am guessing the main issue was actually the router, but i can test that once i insert the modules nad pvdms in a different router later on.
Thank you for your help.
Faith
03-29-2013 10:28 AM
I got this error "Miscellaneous signaling debug data" when I reloaded my router.
Although it just showed the log after reboot and my FXO port showed green light, my analog line was dead.
I have replaced my router, resumed all services. But I still don 't know the root cause of this log.
12-18-2013 03:32 PM
greetings elwinmkanyika.
i'll see one time a kind of this error...
in that oportunity, a pvdm2 module was fried with the outage (don't know why), but when we change it ... all goes fine after !!
seen the error log i put my money bet in the pvdm slot 0, i bet this one is damaged.
best regards
