CME FXO Usual tone disconnect
Carl Messer
Hi there,
I have an install of a CME with FXO ports going live this week and I was wondering if someone could check over my sound extract and confirm for me that the frequency is 415 and cadence is 510 280. I can't test until the lines go over but just want to make sure as best as I can that it will be a smooth changeover.
Also here is my cptone and voice port config:
voice class dualtone-detect-params 1
 freq-max-deviation 30
 cadence-variation 20
voice class custom-cptone DISCONNECT_CP
dualtone disconnect
frequency 415
cadence 510 280
voice-port 0/1/0
 trunk-group PSTN_TRUNKS 1
 supervisory disconnect dualtone mid-call
 supervisory answer dualtone
 supervisory custom-cptone DISCONNECT_CP
 supervisory dualtone-detect-params 1
 cptone FR
 connection plar opx 100
 caller-id enable
Carl
Harshdeep Singh
Hello Carl,
The parameters are correct but the sum of cadences must be greater than "timeout wait-release" under the voice-port. You can check the timer with the command "show voice port 0/1/0".
eg   if the timer is 1 sec , 510+280=790ms < 1s , hence change the cadence value to '510 280 510 280".
Harsh
Harshdeep Singh
Hello Carl,
Harsh
Sorry Harsh,
I'm still getting problems with this, i've amended as you have said and adjusted my wait release to 1 second but it is still not disconnecting. Any ideas?
Carl
Thanks Harsh,
My issue was the cadence value was incorrect. I managed to correct it and all is well.
Carl
