VoIP migration in Japan
Scott Jones
We're preparing to migrate from an old Nortel system in our Tokyo office to Cisco VoIP.  I'm starting to finalize the equipment for the site, and I realized that Japan, at least at one point in time, had a specific type of PRI (J1 I think).  Has anyone done a similar migration from a TDM system to Cisco, and can you help me understand if they do in fact have a special type of PRI (which means I need a special VWIC...), or if they can use one of the VWIC3-MFT cards?
yahsiel2004
Level 7
Level 7
Scott,
You should be fine. Japan uses the same pri setup as US.
T1 Compliance (Partial List)
• ANSI T1.403
• US (UL 1950, T1)
• FCC Part 68
• CS-03
• Canada (CSA 950, T1)
• US (FCC Part 15 Class B, T1)
• U.K. (BS6301, EN60950, EN41003)
• Canada (CSA C108.8 Class A, T1)
• Bellcore-AT&T Accunet (62411)
• ATT 54016
• Japan (VCCI Class 2, VCCI:V-3/97.04, T1, JATE Green Book, IEC950)
http://www.cisco.com/c/en/us/products/collateral/routers/3600-series-multiservice-platforms/product_data_sheet09186a0080091b9c.html
http://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/data_sheet_c36-609138.html
Yosh
HTH Regards, Yosh
5 Replies 5
yahsiel2004
Level 7
Level 7
Scott,
• ANSI T1.403
• US (UL 1950, T1)
• FCC Part 68
• CS-03
• ATT 54016
Yosh
HTH Regards, Yosh
Awesome.  Thanks Yosh.  I remember hearing about the J1 way back in NetAcad, but haven't come across a deployment where I've had to worry about it until now.
Thanks for the assist!
SJ
Glad I could help out!
Yosh
HTH Regards, Yosh
Confirmed.  I did one recently in Tokyo but it was during a move so we had a new PRI installed, and ported the numbers.  No difference on the PRI than US.
Awesome.  thanks Kevin.
SJ
