08-14-2007 10:33 AM - edited 03-14-2019 11:04 PM
Folks:
Is it me, or Cisco? This is the 2nd version of CME that I find I can't access the http://x.x.x.x/ccme.html web page. The reason I ask is I had this bug- CSCsj39556 identified with 12.4.4 XC6 code. I got a special "bug fixed IOS" for this, and all was OK. This weekend I upgraded to version 12.4(15)T1, and I now have the same error, the CME web page displays the text "view window", and there are 2 browser errors. CUE web access works fine.
What say you?
Mark M.
Mark M.
08-14-2007 11:08 AM
firefox doesn't work for sure. No idea about IE 7 as I don't use it. IE 6 it's ok.
08-24-2007 04:38 AM
A quick question regarding your upgrade from 12.4.4XC6 to 12.4(15)T1.
Did you upgrade the gui files and the firmware files for the phones at the same time as the ios ?
08-24-2007 06:37 AM
Mark:
Yes, the using the cme-124-15T.zip
GUI files were updated to the "correct" version supporting 12.4(15)T1 also the fimware files were loaded, and the phone were upgrade to the 8.0 firmware.
Mark M.
