CME Phones showing incorrect time
Sam V. Xavier
Good Afternoon CSC,
We are facing an issue on our Ireland VG where the time on the phone is 1 hour behind the time shown on the router. I have changed the time-zone to make it one hour ahead but still the phone shows the incorrect time.
NTP is configured and synchronized: -
Clock is synchronized, stratum 8, reference is 127.127.1.1
I have done a "create cnf" and then carried out a reset to the phone but its still reflecting incorrect time.
CME version 2800 Software (C2800NM-IPVOICEK9-M), Version 12.4(22)T5
Firmware on the phones: - phone/7945-7965/apps45.8-3-2-27.sbn
We are using only 7965 and 7945.
Please advise how we can fix this issue.
Many Thanks,
Sam Xavier.
7 Replies 7
paolo bevilacqua
You may need to update phone firmware.
Also note you are not using NTP, but just internal clock, that equals to not configuring NTP at all.
kaja_2kj3
Check if the time zone cmd missing under telephony service
islam.kamal
Level 10
Level 10
Dear
kindly find the below configuration
router(config)# clock time EST (type your timezoen)
router(config)# clock summer-time EST
router# Clock (type your date and time).
telephony -service
time-zone 5
time-format 24
date-format dd-mm-yy
Create-cnf
after that reset all your phones , the time will be fixed.
Thank you
please rate if this will help
Hi Sam Xavier
As kaja_2kj3  mentioned set teh timezone under telephony services and create configuration files under Cme.
after that reset all phones it will work.
router updates own clock from NTP server but Ip phones take time and date updates from CME not router.
Check below link:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/troubleshooting/guide/ts_time.html#wp1053981
Hi to all,
I have read all your helpful notes. I need your help on the this problem.
The CME has the below configuration:
clock timezone EET 2
clock summer-time EEST recurring last Sun Mar 3:00 last Sun Oct 4:00
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
telephony-service
time-zone 29
time-format 24
All the IP-Phones 6941 has the correct time but unfortunately all the 79xx IP-Phones have wrong time (missing one hour).
Could you please help me on this?
tnx a lot
Isidoros
Please dont forget phone "type" under ephone-dn, it looks like:
ephone-dn xxx
number xxx
type 79xx
Then reset the phone, you also can check by "show telephony tftp-binding " and looking for item of your phone "SEPxxxx.xml" , it contains the timezone setting for IP Phone
https://supportforums.cisco.com/docs/DOC-13783
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
