04-30-2016 09:07 PM - 편집 03-17-2019 06:46 AM
Hello, I'm trying to configure phone encryption on CME 8.6 but the phones do not get registered.
I've tried the following guides, both without success:
https://www.nsa.gov/ia/_files/voip/cucme_securityguidancedocument.pdf
On the 7965/7962 phones Settings >> Security Configuration >> Trust List CTL File is installed (including TFTP Server , Unified CM and CAPF Server certificates), but ITL File is Not Installed.
The phone remains Registering while debug ephone register shows these errors:
May 1 03:52:14.015: New Skinny socket accepted [2] from 1, sub 1 (1 active)
May 1 03:52:14.015: sin_family 2, sin_port 50484, in_addr 10.0.0.11
May 1 03:52:14.019: add_skinny_secure_socket: pid =394, new_sock=0, ip address = 10.0.0.11
May 1 03:52:14.019: skinny_secure_handshake: pid =394, sock=0, args->pid=394, ip address = 10.0.0.11
May 1 03:52:14.023: Start TLS Handshake 0 10.0.0.11 50484
May 1 03:52:14.027: TLS Handshake retcode OPSSLReadWouldBlockErr
May 1 03:52:15.027: TLS Handshake retcode OPSSLReadWouldBlockErr
May 1 03:52:16.027: TLS Handshake retcode OPSSLReadWouldBlockErr
May 1 03:52:17.035: TLS Handshake error -6992
May 1 03:52:17.035: TLS context configuration FAILED for 0 10.10.10.11 5048
날짜: 09-18-2016 12:20 AM
Hello. Have you found a workaround for this issue?
Thank you.
날짜: 09-18-2016 06:41 PM
Not yet, still trying to find a solution...
날짜: 09-21-2016 05:07 AM
Hi, You need network team to check ISE configs on the port or you can do show run interface ....phone port..... to check if its having dot1x configs.
else you can contact security team so that they can add the port into ISE config.
if the phone port is having dot1x config then remove them , just assign voice and access vlan , once the phones register you can again paste in dot1x configs.
날짜: 09-18-2016 03:29 AM
if the phone port are having ISE configs then it can create an issue.
also you can check the dhcp network mask if its correct or no.
and also you need to check the source-address in telephony-service
날짜: 09-18-2016 06:46 PM
Hi salmandhunna1, thanks for your reply!
The dhcp network mask and telephony-service ip source-address are correct.
How can I check if the phone port has ISE configs?
날짜: 09-19-2016 05:44 AM
새로운 아이디어를 발견하고 저장하세요. 전문가 답변, 단계별 가이드, 최근 주제 등 다양한 내용을 확인해 보세요.
처음이신가요? 아래 팁들을 확인해 보세요. 시스코 커뮤니티 사용하기 새 멤버 가이드
