CME SIP phones no outbound calls / SCCP phones fine
ripcisco
This is a new deployment on CMEv10. We are using 8945 phones in SCCP and 8831's in SIP mode (not offically supported - check the attached config to get 8831's registered to your CME). We are using SIP trunks here in the Uk.
My 8945's can make and receive calls through the SIP trunks and locally to the 8831's no problem.
My 8831's can make on-net calls to the 8945's and to each other fine. They can not make or receive calls through the SIP trunks.
Please see attached debugs - 'debug voice dial-peer all' & 'debug ccsip message'
I attach debugs for a working outbound call from an 8945 and a failed outbound call from an 8831. Also a sh run.
I noticed in the dialpeer debugs that the call appears to be only sending one digit to the Telco - i was dialing 907777777777 but only the 9 is sent to the telco.
Any help appreciated.
Paul.
Adam Thompson
Level 4
Level 4
Paul,
When you make a successful call from one of the SCCP phones over the SIP trunk, what codec is being negotiated?
My thought is it is going to be g.729.
In the SIP trace you are seeing this:
Apr 24 12:53:02.711: //121/2B931E5B8174/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 488 Not Acceptable Here
Via: SIP/2.0/UDP 10.50.0.82:5060;branch=z9hG4bK3140C
To: <sip:07777777777@10.128.0.57>;tag=3607332896-607526
From: "Kitchen" <sip:01568592281@213.218.197.240>;tag=317CCC-17AC
Call-ID: 3440CB21-CAE611E3-817BC1AA-9CC01F93@10.50.0.82
CSeq: 101 INVITE
Allow: CANCEL, ACK, INVITE, BYE, OPTIONS, NOTIFY, INFO, REFER, SUBSCRIBE, PRACK, UPDATE, MESSAGE, PUBLISH
Contact: <sip:07777777777@10.128.0.57:5060>
Reason: Q.850;cause=65
Content-Length: 0
A 488 response usually points to a codec mismatch. You would be seeing this because your 8831 phones are hard-coded to use g.711u
HTH,
Adam
SwathyEdayath
Hi, Did you resolve this issue . do you remember . We are facing the same problem.
Hello Swathy,
I have same issue and I cannot solve it
I cannot make outbound call with x-lite and CIPC
PIX-CME-R1#show run
ip dhcp excluded-address 192.168.10.1 192.168.10.99
ip dhcp pool Voice-Data
network 192.168.10.0 255.255.255.0
option 150 ip 192.168.10.1
default-router 192.168.10.1
dns-server 8.8.8.8 192.168.10.1
option 66 ip 192.168.10.1
ip domain name pix
ip name-server 8.8.8.8
no ipv6 cef
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
bind control source-interface GigabitEthernet0/1
bind media source-interface GigabitEthernet0/1
registrar server expires max 600 min 60
early-offer forced
no call service stop
voice class codec 1
codec preference 1 g711ulaw
voice class sip-profiles 1
voice register global
mode cme
source-address 192.168.10.1 port 5060
max-dn 10
max-pool 10
load 7911 SIP11.8-5-4S.loads
authenticate register
tftp-path flash:
create profile sync 0057050002344066
voice register dn 1
number 2001
voice register pool 1
id mac E0DB.55FE.ED1F
number 1 dn 1
dtmf-relay sip-notify
username 2001 password 2001
description 1001
codec g711ulaw
voice translation-rule 99
rule 1 /^9/ //
voice translation-rule 999
rule 1 /..../ /17772843855114/
voice translation-profile CME-INC-1001
translate calling 1
voice translation-profile Callcentric-OUT
translate calling 999
translate called 99
voice translation-profile IN
translate called 7
voice translation-profile LOCAL-OUT
translate calling 9
voice translation-profile OUT
translate calling 6
translate called 8
voice-card 0
ip tcp mss 1300
interface Loopback0
description Management IP
ip address 192.168.99.254 255.255.255.255
interface GigabitEthernet0/0
ip address 177.x.x.x 255.255.255.128
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
ip address 192.168.10.1 255.255.255.0
ip nat inside
duplex auto
speed 100
ip http path flash://CME-8.0.0-GUI
ip nat inside source list PAT interface GigabitEthernet0/0 overload
ip nat inside source static tcp 192.168.10.155 3399 interface GigabitEthernet0/0 3399
ip nat inside source static tcp 192.168.10.66 9080 interface GigabitEthernet0/0 9080
ip nat inside source static tcp 192.168.10.70 9070 interface GigabitEthernet0/0 9070
ip nat inside source static tcp 192.168.10.71 9071 interface GigabitEthernet0/0 9071
ip nat inside source static tcp 192.168.10.178 3389 interface GigabitEthernet0/0 3389
ip nat inside source static tcp 192.168.99.254 22 interface GigabitEthernet0/0 3022
ip nat inside source static tcp 192.168.10.127 3389 interface GigabitEthernet0/0 4489
ip nat inside source static tcp 192.168.10.15 22 interface GigabitEthernet0/0 3122
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 177.x.x.x
ip access-list extended PAT
permit ip 192.168.10.0 0.0.0.255 any
tftp-server 7911_7906-sccp.8-5-4.tar
tftp-server flash:SCCP11.8-4-2S.loads
tftp-server flash:SIP11.8-5-4S
tftp-server flash:SIP11.8-5-4S.loads
control-plane
voice-port 2/0/0
voice-port 2/0/1
voice-port 2/0/2
voice-port 2/0/3
voice-port 2/0/4
voice-port 2/0/5
voice-port 2/0/6
voice-port 2/0/7
voice-port 2/0/8
voice-port 2/0/9
voice-port 2/0/10
voice-port 2/0/11
voice-port 2/0/12
voice-port 2/0/13
mgcp profile default
dial-peer voice 1 voip
translation-profile incoming IN
destination-pattern 2001
session protocol sipv2
session target sip-server
incoming called-number 177xxx
codec g711ulaw
dial-peer voice 99 voip
translation-profile outgoing Callcentric-OUT
destination-pattern 9.T
session target dns:callcentric.com
voice-class sip early-offer forced
dtmf-relay rtp-nte
codec g711ulaw
clid network-number 17772843855114
no vad
sip-ua
credentials username xx password 7 xxx realm xx.com
authentication username xx password 7 xxx realm xx.com
nat symmetric role active
nat symmetric check-media-src
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry register 5
timers register 250
registrar 1 dns:xx.com expires 3600
sip-server dns:xx.com
connection-reuse
gatekeeper
shutdown
telephony-service
max-ephones 58
max-dn 192
ip source-address 192.168.10.1 port 2000
auto assign 1 to 50
cnf-file location flash:
load 7911 SCCP11.8-4-2S.loads
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1
number 1001
ephone-dn 2
number 1002
ephone-dn 3
number 1003
ephone-dn 4
number 1004
ephone-dn 5
number 1005
ephone-dn 6
number 1006
ephone-dn 7
number 1007
ephone-dn 8
number 1008
ephone-dn 9
number 1009
ephone-dn 10
number 1010
ephone-dn 11
number 1011
ephone-dn 12
number 1012
ephone-dn 13
number 1013
ephone-dn 14
number 1014
ephone-dn 15
number 1015
ephone-dn 16
number 1016
ephone-dn 17
number 1017
ephone-dn 18
number 1018
ephone-dn 19
number 1019
ephone-dn 20
number 1020
ephone-dn 21
number 1021
ephone-dn 22
number 1022
ephone-dn 23
number 1023
ephone-dn 24
number 1024
ephone-dn 25
number 1025
ephone-dn 26
number 1026
ephone-dn 27
number 1027
ephone-dn 28
number 1028
ephone-dn 29
number 1029
ephone-dn 30
number 1030
ephone-dn 31
number 1031
ephone-dn 32
number 1032
ephone-dn 33
number 1033
ephone-dn 34
number 1034
ephone-dn 35
number 1035
ephone-dn 36
number 1036
ephone-dn 37
number 1037
ephone-dn 38
number 1038
ephone-dn 39
number 1039
ephone-dn 40
number 1040
ephone-dn 41
number 1041
ephone-dn 42
number 1042
ephone-dn 43
number 1043
ephone-dn 44
number 1044
ephone-dn 45
number 1045
ephone-dn 46
number 1046
ephone-dn 47
number 1047
ephone-dn 48
number 1048
ephone-dn 49
number 1049
ephone-dn 50
number 1050
ephone 1
device-security-mode none
mac-address E0DB.55FE.ED1F
type CIPC
button 1:3
